Old 11-14-2012, 04:17 PM   #1
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
Default DBW Tables... Am I doing it right?
I've finally gotten a new laptop! This means I can get back to trying to learn all this tuning business...
Anyway, I've tried to modify the DBW. I wouldn't say it's a drastic change, but it is a change nonetheless, and I want to make sure I'm even modifying correctly before I flash it on to my ECU.
For the "Requested Torque A/B/C/D/E/F" tables, I've simply made it more linear.
These are the changes I've made to those tables:
As for the "Target Throttle Plate Position B/Maximum", I've started slow. I've simply tried to make the modified table a "smoother" stock table. See picture here:
Opinions?
MarcoPolo360 is offline   Reply With Quote
Old 11-14-2012, 05:58 PM   #2
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
This is what i would make it like. Depends on what your looking for though.. Some people with Auto's like to lower the requested torque up top for shifting... PM me and i can make some changes to your rom for future learning :-p
Bamofo is offline   Reply With Quote
Old 11-14-2012, 06:16 PM   #3
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
Those tables look amazing.
Wow, if you could do that it would be great! I'll send the PM now!
Old 11-14-2012, 07:18 PM   #4
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
You can try setting a direct 1-1 relation, makes the car very responsive and direct but you have to have good foot control to make it drive smooth. feels very much like a cable throttle.
Old 11-14-2012, 07:44 PM   #5
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
"cable throttle" is essentially what I'm trying to achieve, so I'll definitely give this a try at some point!
Old 11-14-2012, 07:47 PM   #6
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
I haven't had good luck with this approach. I find using similar to stock values people tend to work the best, maybe ramping them up a little. Similar to what Bamofo posted, just a little less aggressive at lower throttle.
Old 11-14-2012, 08:14 PM   #7
Bamofo
Member#: 159743
07 STI Limited
Something like this ;-)
Old 11-15-2012, 02:11 AM   #8
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
That example you sent me has helped immensely, Bamofo! Thanks!
Thanks for the help guys!
