#1 |
Member#: 100353
Well I wasn't planning on posting anything because the car is still 'incomplete', but what the hell, it's practically winter here, the car is stuck in the garage and I'm itching. I knew the small pump would be my limiting factor this fall, but wanted to get the it on the road and broken in before snowfall. I'll get the fuel pump situation sorted out over the winter and get all tuned up nice and early in the spring. NF may chime in here, but this was after just a handful of pulls and I'm confident that we left plenty on the table this time around.
Event: Road Dyno Location: Minneapolis, MN Ambient Temp: 60F Elevation: 1000ft Weather: Clear Track and Conditions: Flat road Tires: 255/40r17 RS-3 Car: 06 STI Tuner: NF Dyno Info: VD Transmission: 2006 STI Gear: 4rd Peak HP at RPM: 506whp @ 7190 RPM Peak Torque at RPM: 424wtq @ 5340 RPM Target Boost: 26psi Target AFR: Fuel: E85 Engine/Power Modifications: See Below ![]() ![]() Engine: - Fresh 2.5L shortblock - Fresh balanced/lightened crankshaft - Manley 99.75mm forged pistons - Manley Turbo Tuff I-Beam rods - ACL main/rod bearings - Vigilant Motorsports Built - BC springs w/ Ti retainers - GSC S2 cams - ARP L19 head studs - 11mm oil pump - Gates racing timing belt - Borg Warner twinscroll 83-75 - Fobia twinscroll headers/uppipe - 2x Turbosmart Compgate 40mm external wastegates - Turbosmart Race-port 50mm BOV - GrimmSpeed MBC/BCS hybrid - Treadstone 28 x 10.5 x 4.5in sti core - GrimmSpeed ported intake manifold (rotated) - GrimmSpeed phenolic spacers - GrimmSpeed gasets all around - Custom 2.75in charge piping Drivetrain: - ACT XT-SS Clutch, 6-puck sprung disc - Factory STI 6spd Short Shifter - Torque Solution Tranny Mount - Torque Solution Engine Mounts - Torque Solution Pitch Stop Mount - Street: BBS w/Hankook R-S3 255/40R17 Fuel: - Five-O 1600cc top feed injectors - DW300 in-tank pump - 3L+ surge tank in engine bay (winter 2012/2013) - Aeromotive 1000hp A1000 stealth pump (winter 2012/2013) - Aeromotive billet fuel pump speed controller (winter 2012/2013) - Aeromotive top feed fuel rails - Aeromotive A1000 -6 FPR - more AN fittings than you can shake a stick at Misc: - omni 4bar MAP sensor (converting to speed density) - odyssey pc680, relocated to trunk - rotated intake manifold (AC delete?) - new ported top feed TGVs - countless other random bits
#2 |
Member#: 3687
MWSOC
Vehicle:MY99 GF4 JDM 6spd NF Performance |
You need spec b gears
#3 |
Member#: 316296
Vehicle:2006 STIROID GT3794@30psi |
#4 |
Member#: 316296
OP, let's see a speedometer video of this thing! Car looks sick BTW
#5 |
Member#: 100353
Haha, spec b gears fall into the 'want' bucket. I need pads, rotors, lines, better seats and wider wheels.
Car's away for the winter, so it'll be a long wait until spring for some cool video! |
#6 |
Member#: 156877
Tri-State
Vehicle:04 sti TS borg s300 FMW |
Unless I missed it, what are you tuned on?
#7 |
Member#: 195711
MWSOC
Vehicle:STi 04/05/06/07 JBP / OBP for now |
I just got done reversing my intake manifold too... did you have to trim the gussets on your hood? I know I did and I think mine is lower than yours. I did have 8mm spacers though.
Did you rotate throttle body? Looks great! More pictures if you have them! |
#8 |
Member#: 156877
Tri-State
Lol I just looked for them in his members gallery thread... and consequently asked for some pics
#9 | ||
Member#: 100353
COBB Speed Density
![]() ![]() ![]() ![]() ![]() And lastly, my throttle body spacer. I sold the extras, but if anyone still has interest, I could make a few more. ![]() Here's a couple videos. The first is of my first spin around the block, the second is during break in. |
#10 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
Looks great! This is a fun car!
Are you going to sell the DW300, or are you keeping that to feed the surge tank? |
#11 |
Member#: 156877
Tri-State
Mind giving more specifics on your turbo? a/r and such
#12 |
Member#: 166005
MWSOC
Vehicle:2005 Saab 92x Beaten Silver |
Boost plot!
#13 | |
Member#: 3687
MWSOC
#14 | |
Member#: 100353
Sure, it's a Borg Warner S300SX 8375, T4 divided, .91 a/r w/ 3" v-band turbine outlet. I'll see what I can dig up! |
#15 |
Member#: 100353
Boost plot.
#16 |
Member#: 261612
#17 |
Member#: 108089
MWSOC
Vehicle:2003 WRX NF Performance |
Needz moar boozt
#18 |
Member#: 268190
TXIC
man this car is awesome. after the winter fuel upgrades and just several more lbs of boost.
this car could be in the high 500s if not break the 600 barrier. |
#19 |
Member#: 261612
Any photos of the Fobia setup out of the car (without or without the motor attached)?
#20 | ||
Member#: 100353
Sounds good, I'll let you know.
![]() That's what my tuner says too, weird. ![]() Quote:
![]() Here's a funny one of the turbo next to my stock vf39 that I found while looking, though. ![]() |
#21 |
Member#: 166005
MWSOC
#22 | |
Member#: 108089
MWSOC
. Needs more fuel before I cam raise boost and rev his higher :0 |
#23 |
Member#: 56203
Tri-State
Vehicle:00 RSTI Coupe |
did you raise the fuel pressure at all?
#24 |
Member#: 193222
MAIC
Vehicle:05 Wrx 1.5xtr 6spd 2.5 hybrid 367whp/363wtq |
Very nice. Love the license plate lol
#25 |
Member#: 241953
MAIC
Vehicle:02 hybrid/6speed 01 2.5 RS sedan |
Interesting. I didn't know you could keep AC with reverse manifold.
Very sick setup btw. |
