Old 11-15-2012, 03:14 AM   #1
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Exclamation Please help!!!
Today I was driving to work, and my car was acting as it should. I was on the highway for about 10 miles, and when I went to pass someone to get to the off ramp I noticed my car had a drastic power loss. I got to work and hoped it was a glitch of some sort, and hoped it would be fine on the ride home. It wasn't. Now my car feels like it has the power of a 94 civic. It still accelerates and gets to to highway speeds, but it doesn't do it like it should. There is no kick to it. I started noticing a "whine" type noise last week, I don't know if that is related. Also yesterday I put some stp oil treatment in the engine, but the car ran fine afterwards all last night, and also ran fine 95% of my was to work. Also the exhaust seems louder, please help!?!?!?
Car has maddad whisperer catback, invidia divorced dp, invidia up pipe, spt intake, and Cobb ap. car is a 2005 wrx wagon
Zwilks14 is offline   Reply With Quote
Old 11-15-2012, 03:21 AM   #2
rushdylan
Member#: 337170
2003 wrx
well you say it's louder, did your up pipe break? causing the turbo to basically not work.
rushdylan is offline   Reply With Quote
Old 11-15-2012, 03:35 AM   #3
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
I didn't hear anything break, how could I check? Also forgot to add no cel
Old 11-15-2012, 09:54 AM   #4
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Seized turbo? No boost=no power. Squealing noise was the turbo eating itself?
Old 11-15-2012, 10:09 AM   #5
NoGraffix
Member#: 276209
I am Rub
Function>Form
Do you here an almost whistling noise when you try to get into boost? If so you might just have a rather large vacuum leak. If you aren't making any boost then you likely fried your turbo.
The best way to diagnosis this would be to get some logs of the car and see if it's making boost (a boost gauge could do this too). You should also look into doing a vacuum leak test. Do a visual inspection of the engine and see if any hoses popped off or if there are any obvious leaks that you could repair.
NoGraffix is offline   Reply With Quote
Old 11-15-2012, 10:15 AM   #6
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Have your turbo checked out.
Navendra94 is offline   Reply With Quote
Old 11-15-2012, 10:18 AM   #7
EdgeAutosport.com
NASIOC Storefront Vendor
Member#: 329319
Agreed! If you were hearing an abnormal squeal before , that could have very well been the turbo whine of death. The fact that there is no cel with that kind of power loss points to this as well.
EdgeAutosport.com is offline   Reply With Quote
Old 11-15-2012, 10:23 AM   #8
DanFromOmaha
Member#: 332087
2002 WRX wagon
Would the turbo still spin? Because I was about to say if its seized, maybe you could tell by not hearing a turbo whistle.
DanFromOmaha is offline   Reply With Quote
Old 11-15-2012, 12:59 PM   #9
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
do you think its possible to blow the turbo? my car only has 77,000 miles on it?
Old 11-15-2012, 01:00 PM   #10
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
it was making the whine noise even when not in boost, if that helps
Old 11-15-2012, 01:03 PM   #11
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
should i bring my car to a subby dealer, or a smaller mechanic? im just worried the dealer will be a dick beacause of the mods i have
Old 11-15-2012, 01:28 PM   #12
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
not makind boost, not even 1 psi, i could only get .9 psi, and when i shut off the car and lifted the hood, it sounded like a tick or drip noise coming from turbo area? also my maddad catback sounds like a n1?
Old 11-15-2012, 01:36 PM   #13
EdgeAutosport.com
Member#: 329319
Depends on how bad the failure is. If its seized, it won't spin at all, but chances are its still spinning and that is whats making the whining noise.
It is definitely possible for the turbo to blow with that many miles. You could check yourself by taking the downpipe off (or at least taking it off the turbo and moving it out of the way a little) and trying to spin the turbine. If it spins freely and there is no shaft play then your problem is somewhere else, but I bet your problem is the turbo...
Old 11-15-2012, 01:36 PM   #14
NW Rex02
Member#: 314030
2002 wrx
check to see if your exhaust is still even bolted up. It might be just chillen there on the hangers but with no bolts or gaskets. blown turbo shouldnt make the catback that much louder.
NW Rex02 is offline   Reply With Quote
Old 11-15-2012, 01:39 PM   #15
V8sPFFF06sti
Member#: 236314
2015 WRX
my 2005 gti blew its turbo at 25k miles. the only mod i had was a intake. so someone already answered it, yes it can
V8sPFFF06sti is offline   Reply With Quote
Old 11-15-2012, 01:41 PM   #16
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
there is no more whine noise, that was like a week or so prior to this happeneng, now there is no noise. i just drove the car down my street, i couldnt even get to 1 psi of boost
Old 11-15-2012, 01:42 PM   #17
Jspike
Member#: 149575
94? GD
Personaly it sounds like an exhaust leak. Maybe at the header or the uppipe. A preturbo exhaust leak will kill any chances of boosting it also makes a whinning noise. It would also explain why your exhaust is louder. Crawl under there and check the tighteness of your exhaust bolts also check the O2 sensors and the preturbo sniffer to make sure everything is tight and there are no leaks.
Jspike is offline   Reply With Quote
Old 11-15-2012, 01:43 PM   #18
Jspike
Member#: 149575
94? GD
Never mind my post then. Most likely the turbo. Remove it and check the shaft.
Old 11-15-2012, 01:45 PM   #19
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
so you dont think it could be exhaust issue?
Old 11-15-2012, 01:59 PM   #20
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
I am thinking the turbo's exhaust side wheel probably ate itself and went out through the muffler. That would explain the noise as it was coming apart, and then the complete lack of boost. The exhaust would also be slightly louder with no turbine wheel in the turbo.
ResidentR is offline   Reply With Quote
Old 11-15-2012, 02:07 PM   #21
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
you guys think i should take it to a tuner shop or the stealership
Old 11-15-2012, 02:18 PM   #22
NW Rex02
Member#: 314030
2002 wrx
just buy a used tdo4 from the classifieds
Old 11-15-2012, 02:22 PM   #23
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Either take off the downpipe like previously suggested to check if the turbine still spins or bring it to a mechanic if you're not comfortable doing it yourself. If and only if that's the culprit, you can start looking into buying a used/new one.
Old 11-15-2012, 02:29 PM   #24
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
If it is the case that the turbo is gone, I would suggest that this is an awesome time to consider upgrading to a vf39.
Old 11-15-2012, 02:33 PM   #25
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
if i do that upgrade, is it bolt on and im good to go, or do i have to buy more parts too?
