Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 11-14-2012, 11:08 PM   #1
TickTack
Member#: 100353
Default 2006 STI, Borg Warner 8375, Built Motor, E85, 500whp+
Well I wasn't planning on posting anything because the car is still 'incomplete', but what the hell, it's practically winter here, the car is stuck in the garage and I'm itching. I knew the small pump would be my limiting factor this fall, but wanted to get the it on the road and broken in before snowfall. I'll get the fuel pump situation sorted out over the winter and get all tuned up nice and early in the spring. NF may chime in here, but this was after just a handful of pulls and I'm confident that we left plenty on the table this time around.
Event: Road Dyno
Ambient Temp: 60F
Elevation: 1000ft
Weather: Clear
Track and Conditions: Flat road
Tires: 255/40r17 RS-3
Car: 06 STI
Tuner: NF
Dyno Info: VD
Transmission: 2006 STI
Gear: 4rd
Peak HP at RPM: 506whp @ 7190 RPM
Peak Torque at RPM: 424wtq @ 5340 RPM
Target Boost: 26psi
Target AFR:
Fuel: E85
Engine/Power Modifications: See Below
Engine:
- Fresh 2.5L shortblock
- Fresh balanced/lightened crankshaft
- Manley 99.75mm forged pistons
- Manley Turbo Tuff I-Beam rods
- ACL main/rod bearings
- Vigilant Motorsports Built
- BC springs w/ Ti retainers
- GSC S2 cams
- ARP L19 head studs
- 11mm oil pump
- Gates racing timing belt
- Borg Warner twinscroll 83-75
- Fobia twinscroll headers/uppipe
- 2x Turbosmart Compgate 40mm external wastegates
- Turbosmart Race-port 50mm BOV
- GrimmSpeed MBC/BCS hybrid
- Treadstone 28 x 10.5 x 4.5in sti core
- GrimmSpeed ported intake manifold (rotated)
- GrimmSpeed phenolic spacers
- GrimmSpeed gasets all around
- Custom 2.75in charge piping
Drivetrain:
- ACT XT-SS Clutch, 6-puck sprung disc
- Factory STI 6spd Short Shifter
- Torque Solution Tranny Mount
- Torque Solution Engine Mounts
- Torque Solution Pitch Stop Mount
- Street: BBS w/Hankook R-S3 255/40R17
Fuel:
- Five-O 1600cc top feed injectors
- DW300 in-tank pump
- 3L+ surge tank in engine bay (winter 2012/2013)
- Aeromotive 1000hp A1000 stealth pump (winter 2012/2013)
- Aeromotive billet fuel pump speed controller (winter 2012/2013)
- Aeromotive top feed fuel rails
- Aeromotive A1000 -6 FPR
- more AN fittings than you can shake a stick at
Misc:
- omni 4bar MAP sensor (converting to speed density)
- odyssey pc680, relocated to trunk
- rotated intake manifold (AC delete?)
- new ported top feed TGVs
- countless other random bits
TickTack is offline   Reply With Quote
Old 11-15-2012, 01:00 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You need spec b gears
Old 11-15-2012, 01:05 AM   #3
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Says the man with spec B gears
Where could one find a set, or the whole transmission, rather?
Old 11-15-2012, 01:05 AM   #4
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
OP, let's see a speedometer video of this thing! Car looks sick BTW
Old 11-15-2012, 09:14 AM   #5
TickTack
Member#: 100353
Haha, spec b gears fall into the 'want' bucket. I need pads, rotors, lines, better seats and wider wheels.
Car's away for the winter, so it'll be a long wait until spring for some cool video!
Old 11-15-2012, 09:39 AM   #6
Ballistic1350
Member#: 156877
04 sti
Unless I missed it, what are you tuned on?
Ballistic1350 is offline   Reply With Quote
Old 11-15-2012, 09:46 AM   #7
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I just got done reversing my intake manifold too... did you have to trim the gussets on your hood? I know I did and I think mine is lower than yours. I did have 8mm spacers though.
Did you rotate throttle body? Looks great! More pictures if you have them!
Layvon is online now   Reply With Quote
Old 11-15-2012, 09:56 AM   #8
Ballistic1350
Member#: 156877
04 sti
Lol I just looked for them in his members gallery thread... and consequently asked for some pics
Old 11-15-2012, 10:10 AM   #9
TickTack
Member#: 100353
COBB Speed Density
I didn't, it's a tight fit, but there's clearance. I used the GrimmSpeed 8mm spacers and a custom throttle body spacer to rotated the throttle body 90deg.
Sorry guys, I haven't taken too many pics of it! Here's a dump of a few that I have. I'll try to take a few this weekend. Appreciate the interest!
And lastly, my throttle body spacer. I sold the extras, but if anyone still has interest, I could make a few more.
Here's a couple videos. The first is of my first spin around the block, the second is during break in.
Old 11-15-2012, 10:44 AM   #10
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Looks great! This is a fun car!
Are you going to sell the DW300, or are you keeping that to feed the surge tank?
Old 11-15-2012, 10:46 AM   #11
Ballistic1350
Member#: 156877
04 sti
Mind giving more specifics on your turbo? a/r and such
Old 11-15-2012, 11:03 AM   #12
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Boost plot!
Old 11-15-2012, 11:16 AM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Rallispec!
Old 11-15-2012, 11:25 AM   #14
TickTack
Member#: 100353
I'll probably keep it to feed the surge tank. I know a walbro would do the trick, but I'd rather save the hassle.
Sure, it's a Borg Warner S300SX 8375, T4 divided, .91 a/r w/ 3" v-band turbine outlet.
Originally Posted by Zee Biker View Post
Boost plot!
I'll see what I can dig up!
Old 11-15-2012, 12:19 PM   #15
TickTack
Member#: 100353
Boost plot.
Old 11-15-2012, 12:21 PM   #16
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Well if you want to trade, I have a perfectly good Walbro
Old 11-15-2012, 12:28 PM   #17
Nuke209
Member#: 108089
NF Performance
Needz moar boozt
Old 11-15-2012, 01:01 PM   #18
05subysti
Member#: 268190
2005 STi
RWD, 18x10.5/12.5s
man this car is awesome. after the winter fuel upgrades and just several more lbs of boost.
this car could be in the high 500s if not break the 600 barrier.
Old 11-15-2012, 01:24 PM   #19
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Any photos of the Fobia setup out of the car (without or without the motor attached)?
Old 11-15-2012, 01:40 PM   #20
TickTack
Member#: 100353
Sounds good, I'll let you know.
Originally Posted by Nuke209 View Post
Needz moar boozt
That's what my tuner says too, weird.
We'll see! Either way, it should be a good time.
This is a pic from fobia, I think. Not sure if I have any of my own. Probably at home on my laptop.
Here's a funny one of the turbo next to my stock vf39 that I found while looking, though.
Old 11-15-2012, 03:35 PM   #21
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Boost plot.
Awesome, thanks!
Plans to rev it higher? The head looks like it was built for more...
Old 11-15-2012, 03:44 PM   #22
Nuke209
Member#: 108089
NF Performance
Awesome, thanks!
Itll be revving to 8k but not right now. Goal is 30psi . Needs more fuel before I cam raise boost and rev his higher :0
Old 11-15-2012, 04:13 PM   #23
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
did you raise the fuel pressure at all?
Old 11-16-2012, 08:30 AM   #24
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Very nice. Love the license plate lol
shadowmd is offline   Reply With Quote
Old 11-16-2012, 10:07 AM   #25
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Interesting. I didn't know you could keep AC with reverse manifold.
Very sick setup btw.
mrjcotten is offline   Reply With Quote
