#376 |
Member#: 35076
TXIC
Vehicle:2004 507whp Wagon Silver |
I'm looking to switch out of the GTX3076R w/ .82 to the GTX3576R w/ .63 in hopes that I'll see some better flow from 24-30psi and better low end response. Right now the turbo appears to be out of breathe at around 28psi and 510-525whp. I'm also curious how the response on the new turbine will be in both .63 and .82 configs.
I had the car back on the dyno last week in hopes to see how the turbo would perform in colder weather at 30psi vs warmer weather at 28psi and was a bit disappointed.
#377 |
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
Something is wrong. I just tuned a GTX 30R at 30 psi and its full on at 3600 to 3700 rpm.
The .63 on the 35r is a horrible idea. That turbo requires the larger .82 full high power/boost. The turbo you are looking for is the new GTX 30R with the GT35R hotside. It was released at Sema. C |
#378 |
Member#: 35076
TXIC
Clark - That's the turbo I was looking at replacing this one with. I'm also on stock TGV's and Stock Exh manifolds with unported 2.0L heads. What configuration was the GTX30 you had full boost at 3600?
#379 |
Member#: 178047
SWIC
stock 2.5 heads with a sleeved motor/pistons/rods. You need to get the heads cut. You are leaving ALOT on the table.
#380 |
Member#: 35076
TXIC
I figured as much, if I ever pull the heads off again I'll likely replace them with 2.5L heads and be done with it. So much for chamber matching and a bowl blend being close to 2.5L flow lol
#381 |
Member#: 178047
SWIC
The 2.0 head/2.5 motor is in my opinion the worst combination you could have. I would rather have a 2.0. I have never tuned one I liked and that includes my own. You will get some telling you they made XXX and there is no problem ect. In reality, they just do not realize what they are missing.
C |
#382 |
Member#: 294068
Vehicle:2000 Integra GSR 13.5:1 GT30R 597hp |
Turboge, Im really impressed you are able to maintain 30psi to redline. Are you jacking up the ebc duty cycle with rpm?
#383 |
Member#: 35076
TXIC
Not at all, I'm using a .8bar spring in the WG and only running around 40% duty cycle flat to hit 30psi. This is on a grimmspeed EBCS with 1/4" nipples and vacuum lines.
#384 | |
Member#: 135993
Vehicle:2008 STi AW |
#385 |
Member#: 278519
SCIC
Vehicle:KBiz KeeganLB 30rSTI phatron tuned |
looking for a comparison between the gt3076 .82 vs the gtx3576 .82, vs gtx3076 .82
#386 |
Member#: 337852
Question to Jeff
I understand that gtx3076 .82 spool quicker than gtx3582 .63 and made same power up to 30psi but will the gtx3582 .63 perform better ( than gtx3076 .82 ) on - bigger engines - up to 35psi - rev limiter 7000 approx thanks in advance |
#387 |
Member#: 178047
SWIC
.63 is way to small for any of the turbos for the 2.5 motor. The information is right on Garrets website for all to see. Anyone using the .63 is leaving serious power on the table.
C |
#388 | |
Member#: 337852
Most of the tuners also don't recommend .63 but why Garrets keep making them? for what cars ( engine cc ) ? leaving serious power on the table? I thought we are talking about 30-40hp on top ( .63 vs .82 ) |
#389 |
Member#: 178047
SWIC
They make the .63 housing for lower flowing engines. The .63 is listed for 1.5 to 2.0 ltr engines. Or if you had two turbos on a V6 or V8 engine, You would want both turbos to have the small 63 housings.
C |
#390 | |
Member#: 337852
Why twin .63 works better than twin .82 on V6 and V8?? |
#391 |
Member#: 178047
SWIC
A dissertation on turbine flow and dynamics is out of the scope of this perrin thread. I suggest you go to turbobygarrett.com and read the Turbo 101 information to get started. You can learn alot on that one website.
C |
#392 |
Member#: 337852
Thanks for help Clark!
#393 |
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
#394 |
Member#: 337852
#395 |
Member#: 48350
Vehicle:04 WRX |
#396 |
Member#: 278519
SCIC
also want more info, all I could find was this :
in this thread on iwsti, page 14, but whole thread is about it, not sure of mods, fuel, or anything else, he has a few low boost plot above this one, pg 14 http://www.iwsti.com/forums/2-5-lite...stions-14.html I would also like more info, not sure if its wrth swapping out my basically brand new 30r .82, for this, Id swap to v band on the down and uppipes to help the seal/ spool be as good as possible, & my block is now built for it, along with headwork cams and all I prob wont see many good gains with them on my 30r, 1700+ is alot without others being the guinea pig first |
#397 | |
Member#: 239945
Vehicle:06 STi GTX3576R CGM |
#398 |
Member#: 182375
SWIC
Vehicle:08 Sti Wrbm |
My prediction is 35r performance. 35r boost threshold and 35r power. The compressor maps look similar basically the same although the gtx30r wheel has to spin faster to produce the same results because it's smaller. So it may be that it actually lags slightly more on the 35r turbine than a 35r compressor would. Personally I'm going to run an HTA 3582 because they seem to have lower boost threshold than a normal 35r and make the same power.
#399 | |
Member#: 103631
Vehicle:2004 STI Black |
there's an evom comparo that shows the 3576 to spool faster than the gtx3076 which doesn't quite make sense since the 3076 has the smaller turbine wheel. I would love to see an actual Subaru comparison. I think the performance gain would be greater on our cars though as we typically benefit from the larger turbines. Just a few thoughts. I feel the 71mm wheel is a better match for 60mm turbine for our cars than the new 76mm wheel is. I wonder if the 3576 is the same. |
#400 | |
Member#: 269226
http://www.motoiq.com/magazine_artic...p-details.aspx |
| Thread Tools | |
| Display Modes | |
| Got some new toys for the car. Pics inside... | shady | North West Impreza Club Forum -- NWIC | 11 | 03-23-2009 09:25 PM |
| My new 107hp toy.. short Video inside | RC0310 | Member's Car Gallery | 23 | 03-29-2007 11:56 PM |
| My new toy,WOOT *pic inside*. | joe r | North West Impreza Club Forum -- NWIC | 23 | 10-16-2006 10:06 PM |
| Imprezaf's new toy! (pssst STi inside!) | ZoomnWRX | Tri-State Area Forum | 29 | 06-26-2003 09:05 AM |
| Did you guys see my new toy? I know Goosey has... | JGard | Off-Topic | 21 | 09-29-2002 10:30 AM |
