Old 11-14-2012, 10:19 PM   #1
BAJAHumbug
Member#: 134935
2004 BAJA-T, 4EAT
pearl/silver
Default "Engine Restore" in a can
ALL:
I have some recent experience that may be of some help.
My '04 BajaT with 124,xxx miles was actually running well and just thought maybe with those miles some "engine restore" couldn't hurt and may make the cruck better. I had changed the oil about 1,500 miles ago and the level was down a pint or so and I thought I'd top it off with the engine restore in a can.
So, Friday morning I add a can of engine restore to the oil just before I leave for work. On my drive home from work my engine light comes on and of course my cruise control stops working, which is a by product of the CEL. I continue driving ~ 50mph and after a couple of miles i start hearing a squealing/scraping noise and the baja's performance drops precipitously. I manage to limp it home where I read the code; which is P0011- (Bank 1 Timing over-advanced or system performance).
I researched that code online and discovered that it usually refers to the VVT oil control valve solenoid not working properly. The squealing noise with loss of performance seems to be a symptom of a failing turbocharger.
One of the steps to consider for the P0011 code is to drain the oil replace the oil filter, refill oil and run at idle for ~5 minutes drain and repeat. Seemed a logical first step rather that tow it to dealer and wait for a 4-$5,000 invoice.
Well, I did all of that saturday morning and lo and behold after the two oil and filter changes and a refill with Rotella T6 and a purolator PL14610 filter all seems normal during a test drive. Whew, dodged a bullet!
Conclusion. . .
Apparently the particles/powder that are in the "engine restore" are not compatible with a VVT turbocharged engine. However, nowhere on the can does it caution against using in same.
I'm guessing that the particles interfere with the proper operation of the oil control valve throwing the P0011 code. And those same particles do not play well with the turbocharger bearings.
So, be cautious when using any kind of oil treatment that has any kind of particles/powder in it. I will certainly not be doing anything like that again.
HTH.
-steve
BAJAHumbug is offline   Reply With Quote
Old 11-14-2012, 10:25 PM   #2
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Old 11-14-2012, 11:43 PM   #3
Type2
Member#: 200436
2004 Forester XT
You got lucky. And of course, you don't need to hear it, but never do that again.
Type2 is offline   Reply With Quote
Old 11-15-2012, 12:29 AM   #4
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Is it possible that it knocked some carbon buildup or sludge or something loose causing a clog somewhere? That seems more likely to me.
Old 11-15-2012, 01:24 AM   #5
i think ya done roasted the whole thing
prepare for a whole new motor soon
Old 11-15-2012, 08:36 AM   #6
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Km with u scotty
BlackFighter is offline   Reply With Quote
Old 11-15-2012, 08:38 AM   #7
apexslider
Member#: 168101
15 BRZ Limited
SS
A squealing/scraping noise? How long did the motor run like that? Your sure all is well? I'm with Uncle Scotty on this one, some permanent damage may have been done. Scraping noises are never good. If you still have your old oil filter, I would cut it open and inspect it.
apexslider is offline   Reply With Quote
Old 11-15-2012, 08:47 AM   #8
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Don't get fooled by Snake oil.
Drive the car for a full OCI and then get the oil analyzed.
Ernest is offline   Reply With Quote
Old 11-15-2012, 12:05 PM   #9
Paidfor
Member#: 267815
Be in awe
dont hate .)
Engine restore? o man.......Thats some thick **** homie
Thicker than 80w90.......good for a ole wore out buick but these subies are finicky as hell
Old 11-15-2012, 08:28 PM   #10
tunertype
Member#: 335033
2009 wrx
Dark Gray Metallic
Doesn't that engine restore stuff cause clogs not remove them? Thought it was to stop oil burning/leaking, meaning it causes clogs on purpose.
tunertype is offline   Reply With Quote
Old 11-16-2012, 05:33 PM   #11
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
The restorer is thick as molasses which is designed to plug leaks and even make up for worn out rings by effectively increasing compression. The turbo requires a constant flow of oil and it's hard to flow this molasses through the feed line and chra in the same manner as your standard 5w30 or 5w40. The same goes for the AVCS solenoid I'd guess.
FCmaniac is offline   Reply With Quote
Old 11-16-2012, 08:49 PM   #12
rdieder
Member#: 257818
2007 STi
Yup it clogs on purpose, I wouldnt use it on a turbo car or anything you care about. I've met a few mechanics that were told to use the stuff on old beat smokey cars while prepping for resale.
rdieder is offline   Reply With Quote
Old 11-16-2012, 10:02 PM   #13
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Try some seafoam. That's more of the product your looking for
Slimsti is offline   Reply With Quote
Old 11-16-2012, 11:40 PM   #14
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I just assumed it was like sea foam...
Old 11-17-2012, 10:19 AM   #15
Tripintaz
Member#: 245218
2013 STI Limited
What on earth possessed you to put that garbage in your car? SMH
I'm glad it appears you didn't do any fatal damage.
Old 11-17-2012, 03:31 PM   #16
rob1n1
Member#: 276425
2013 335is
Alpine White
If there was a Darwin Award for Subaru owners... This would be my nomination.
Old 11-19-2012, 06:58 PM   #17
rebornS14
Member#: 338337
1997 S14
SUBARU ACTUALLY HAS THEIR OWN ENGINE OIL FLUSH SYSTEM
PART # SOA868V9290
saids its "specially formulated and safe for Turbo-Charged Engines"
rebornS14 is offline   Reply With Quote
Old 11-19-2012, 07:55 PM   #18
FCmaniac
Member#: 142029
2013 Forester
^^ oil system flush and an oil additive meant to plug leaks and swell seals are two completely different things for different purposes
Old 11-21-2012, 12:14 AM   #19
Bikelok
Member#: 254851
2002 WRX wagon 5mt
124,000 miles is not all that much to start futzing with stuff like that. I don't like any additives or "fixes" at all. Just take care of it in the first place.
A well maintained engine should go a whole lot more than that without worries.
Bikelok is online now   Reply With Quote
Old 11-21-2012, 08:47 AM   #20
Bottom Feeder
Member#: 2808
Just thin it out with some Slick 50 and you'll be fine.
Bottom Feeder is offline   Reply With Quote
