Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 11-15-2012, 12:47 PM   #1
carlck19
Member#: 249890
1995 Impreza L wag
white
Default intermittent code 45 on boost
Hi guys I thought I was getting robs knock light but I believe it to be an intermittent code 45 that comes on when i get on the throttle. I checked the past codes with the black connectors and this is the only one that came up. how should i go about fixing this/should i even worry about it?
-Alex
carlck19 is offline   Reply With Quote
Old 11-18-2012, 07:11 PM   #2
carlck19
Member#: 249890
1995 Impreza L wag
white
anyone?
Old 12-10-2012, 07:20 AM   #3
gtu89rx7
Member#: 108029
95 Impreza Outback
EJ20G swapped
it is either your boost sensor or the solenoid right next to it, which switches the sensor from reading manifold pressure to atmospheric. check the vacuum lines for cracks too
gtu89rx7 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 11:42 PM.
