Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 11-14-2012, 05:41 PM   #1
Viral E
Member#: 242246
2002 Impreza WRX
Default It's time to play "Guess that Sound"!
So after a good solid afternoon of searching NASIOC for WRXs of my model year with similar conditions, I came to the conclusion that my sound was at least different enough to justify a separate thread. If this is an easy answer and I simply overlooked something, well... I tried.
I got into my car one morning two months ago, started it up, and finished my phone call as I began to buckle up. When all of a sudden...
Conditions of the symptom:
- 2002 WRX - 170K miles - Original engine, no rebuild
- Ambient Temperature: Both Cold and Hot (-10 F to 80 F)
- Duration: A little more prominent at start-up but still present after complete warm-up (Intensity is reduced perhaps 10-20% after warm up)
- Sound matches RPM's almost exactly (1 sound per RPM or 1 sound per 2 RPM)
- Most audible at idle in gear and neutral with clutch both in and out, but slightly more audible under load when accelerating from 750-1800 RPM's then falls off quickly after that
- Tone is incident to a small knocking sound almost like a clicking
- Sound appears to be coming from driver's side (90% certain)
- Sound appears to be coming from front of engine (50% certain)
- Sound is barely audible and you wouldn't notice it unless you were listening for it like I was. Once you hear it though, it is distinct enough to catch every time it happens.
Given the symptoms I've compiled a list of possibles, some of which are much more likely than others:
Rod Knock
Bearing failure (perhaps one of the journals?)
Idler pulley
Loose Bolt
Bad Alternator (Bearing or pulley)
Bad AC Belt Tensioner
Piston Slap
Engine Knock
Unfortunately I can't just tear apart my engine on a whim, nor can I afford to have a shop tear it apart without being absolutely certain of what I'm getting into (to put it bluntly, I'm broke, in between a rock and a hard place, with no way out). Suggestions would be most appreciated or even things I didn't consider. I'm working on getting a logging cable so I can check AFR's soon to make sure engine knock isn't a possibility.
Viral E is offline   Reply With Quote
Old 11-14-2012, 05:50 PM   #2
rocketperson7
Member#: 283968
MBP
sounds like lifter tick, you have solid lifters, it happens
Old 11-14-2012, 05:52 PM   #3
wrxlaunch
Member#: 181298
02 , Vf43 Inside..
12 seconds at a time
How is the maintenance of the car...up to date?, which oil do you use, have you checked the compression?
Old 11-14-2012, 06:15 PM   #4
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
You need to make a clip, like this:
http://soundkey.com/index.php?option...id=62&autoplay
(Funny that the first upload of an engine problem sounds exactly like a WRX with exhaust mods??)
For me this was play in the crank bearing/spun crank bearings, apparently a common woe for this car/motor.
It started off pretty subtle and got very loud without much driving.
When it was subtle I could keep it away by keeping the engine under load and once the RPMs were up it'd die off.. only to return as I'd let the engine load drop and the RPMs dropped.
I have a video I recorded of it on my camera if needed?
420WRX is offline   Reply With Quote
Old 11-14-2012, 06:27 PM   #5
Viral E
Member#: 242246
2002 Impreza WRX
Car originally had Mobil 1 used for nearly 60K miles before I got it, and i started using Rotella T6 (5w-40) when I got it, HOWEVER the noise started before I switched to T6. I have the Carfax and according to it, the car was in an accident around 95K but I'm unsure of the extent of the damage. Nothing in the block was replaced (I know that).
All other maintenance is indeed up-to-date, and compression is good in all cylinders sitting around 156-160 for all four of them.
EDIT: Listened to your sound clip and mine sounds absolutely nothing like that. It's WAY softer and much less "booming". Rather, mine is more like a click... but not high-pitched.
Old 11-15-2012, 12:50 PM   #6
420WRX
Member#: 27752
Sorry that was posted as an example, not my clip at all, I was just wondering if there's any good sound clip sites to link to and then found an engine noise clip so that was perfect.
Old 11-15-2012, 01:01 PM   #7
420WRX
Member#: 27752
This clip is VERY close to the sound I had:
https://www.youtube.com/watch?v=SvxaR7HSmWc
(Especially the 'clack' sound as he comes off the throttle, that's tell-tale)
This clip is a good example of a similar sound caused by a tensioner:
https://www.youtube.com/watch?v=UmZ1F8V8pc8
Old 11-15-2012, 01:10 PM   #8
Viral E
Member#: 242246
2002 Impreza WRX
Listening to these clips you're posting, I almost feel guilty for even mentioning my sound. Mine is barely audible compared to those massive clackings and clankings. It's a VERY light knock. I'll post a sound clip as soon as I can. I just have trouble getting my hands on good recording equipment (I've got an archaic cellphone so that one is out)
Old 11-15-2012, 01:18 PM   #9
420WRX
Member#: 27752
It's good! You really don't want the sound that's in the first video.. I'm still paying for that one as you could probably guess from my 'vehicle' info.
Old 11-15-2012, 01:28 PM   #10
jaysh
Member#: 133200
06 STi
jaysh is online now   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 05:56 PM.
