#76 |
Member#: 284694
NESIC
Vehicle:2006 VF39 WRX 274/319 @ EFI Logics |
I think it'd be safe to say you'll need an aftermarket clutch. Especially if you get the larger turbo.
#77 |
n00b Moderator
Moderator Member#: 140114
MAIC
Vehicle:06 18G Semi Built SGM WRX |
The clutch will be fine for just a VF39.
#78 |
Member#: 267793
MWSOC
Vehicle:2007 WRX 320HP/320TQ CGM |
What about the 43 and 48? Is the VF39 the most in reliable of the 3 you'd think?
#79 |
Member#: 97135
NWIC
#80 |
Member#: 267793
MWSOC
Lol who cares its a forum where we discuss learn and help others out, not like he's the president of these United States
Again, refer to my post about bickering & there being more important things in life But when will I be upgraded from scoot newbie? I've been here two years with countless threads and posts....? |
#81 | ||
Member#: 97135
NWIC
#82 | |
n00b Moderator
MAIC
I love these responses now when I post. Quote:
555 = specialist 5000 = guru |
#83 |
Member#: 267793
MWSOC
I'm just saying....and oh okay it's whatever just wondering. Looking around for VF39 or 43 and sti tmic but nobody has any for sale on here! Turbo for >450 shipped and sti tmic >250 shipped none out there in good condition!
#84 | ||
Member#: 132389
BAIC
Vehicle:2006 WRX Wagon SGM 2003 SV1000S --> my DD |
Here's what is going on: - The OP's car has 86K miles, the cylindric/round fuel filter inline with the pump is dirty and needs changing and the pump itself has become tired pushing fuel through a dirty and clogged fuel filter. The sock filter that is plunging into the fuel is also dirty as well. - So, at the very least, the OP will need to change both the sock filter and the cylindric/round fuel filter but, while he's in there, he should take this opportunity to upgrade the fuel pump as well. - With a VF39/VF43/VF48, depending on *boost target towards redline* and *depending on target AFR towards redline*, the stock fuel pump will not be able to provide enough fuel !! I repeat it again, depending on boost target and depending on target AFR, the stock fuel pump will not make it. Let's give a specific example. I'm running 15.5 psi of boost from a VF43 from 5500RPM to 6800 RPM and my target AFR is 10.7:1. Guess what ? The stock fuel pump couldn't do it. I was only getting 10.9:1~11.1:1 AFR at best. My 02 wideband sensor was perfectly calibrated, the stock fuel pump with 40K miles on the clock just couldn't deliver enough fuel. So, OP, change your fuel filters and UPGRADE that fuel pump while you're in there. |
#85 |
Member#: 267793
MWSOC
Yes on top of the sti tmic and turbo I'm doing fuel pump. I do the fuel filter as preventative maintenance anyways since I always change that when I buy a car!
Thanks ![]() Mike |
#86 |
Member#: 284694
NESIC
#87 |
Member#: 267793
MWSOC
Tuner said he's going to do a winter tune so ill have less torque, around 310/310, but for spring ill be at 320/340ish
#88 | |
Member#: 106116
NESIC
Vehicle:2006 WRX Ltd Wagon CGM, VF39 Brentuned |
OP, you can keep the stock clutch until it starts to slip. No sense in replacing a clutch that is holding. The question arises when you need to replace it. At that point opinions differ. A new stock clutch will hold the torque and be easiest to drive. You just won't get 90k miles out of it like you could at stock torque levels, and clutch jobs are expensive. An aftermarket "Stage 1" clutch (like those from ACT or Exedy) will hold the torque and theoretically last longer. But the pedal will be heavier, and they can chatter. I personally went with an Exedy Stage 1 street clutch and a stock flywheel. It engages smoothly and is easy to drive. But the pedal is heavier and I hear a grinding noise at about 2200-2400 RPM under heavy acceleration. Under normal acceleration it is quiet. Long story short, stick with the stock clutch for now and do research when it comes time to replace it. If you do go upgraded, don't go heavier than "Stage 1". My $.02, not the Bible. |
#89 | |
Member#: 208817
Tri-State
Vehicle:2006 WRX TR Stg2++ CGM |
#90 | |
Member#: 132389
BAIC
Again, the only thing that matters is AFR target at redline and boost target at redline because that's what is going to define the maximum amount of fuel required by the engine. With 15.5 psi at redline and a target of 10.7:1, my IDCs are well into the 90% range with a Walbro. Without the Walbro, IDCs were flirting with 100% and AFR target of 10.7:1 was not reached. EDIT: I wish people would also mention boost target towards redline as mentioning the maximum amount of boost in the midrange does not say much... Last edited by neg_matnik; 11-16-2012 at 02:04 PM. |
#91 |
Member#: 214050
MWSOC
Vehicle:2007 WRX World Rally Blue |
How do you guys feel about headers w/ uppipe? Actually debating on whether on installing them or just selling them (they are UEL) because they did put a hole in my wallet. People are all for modding to Grimmspeed port & polish manifold w/ crosspipe and uppipe and saying it makes a difference but buying aftermarket headers w/ uppipe makes no difference. Also, I always thought that porting would make you lose spool too.
#92 |
Member#: 267793
MWSOC
The stock fuel pump is fine, I'm replacing it as a precautionary measure since it seems to be the general consensus. I don't plan on upgrading further than VF and tmic so it should be fine. My clutch is perfect now, even after 30-40 pulls since I've bought it! Ill go stage 1 clutch after it starts slipping, no point to replace it until then though yes!
#93 |
Member#: 267793
MWSOC
How will 5 speed trans and diff hold up with 320whp 340wtq? Give or take and what's safe? And will an hks bov hold 20psi?
#94 |
n00b Moderator
MAIC
We cannot answer that question, FAR too many variables.
#95 |
Member#: 267793
MWSOC
Assuming I never launch or red line it besides maybe once a month. A Wrx with 88k miles running strong with 240whp and 320wtq, somebody can from personal experience having the VF setup on a Wrx with stock trans and diff...
#96 |
Member#: 254130
NWIC
Vehicle:2004 STI Hurr hurr |
They break on stock power. Nobody really knows how long it will hold. It could blow on the first pull or could hold for 5 years.
#97 |
n00b Moderator
MAIC
No, there are simply FAR too many variables to say. Will it last? Probably. Will it fail? There is a chance. Lot's of people have a similar setup to yours on their WRX's and don't have problems, others do. The question you are asking simply cannot be answered with full honesty. If you are simply looking for a number, 20 years.
Edit: Forgot to mention the whole "glass transmission" argument is a lie. These are essentially the same transmissions that have been used by Subaru for nearly 20 years in Japan and make equal or more power when modded. My 18G and trans have done just fine, and I can beat on it pretty good. You'll hear more of ringland failures then trans failures. |
#98 |
Member#: 255114
Tri-State
Vehicle:2007 wrb wrx wagon e85 vf43 ewg |
^This.
07 WRX Wagon, 64k miles Stock trans. - gears, clutch, flywheel. VF43, DW 750cc injectors, STi tmic, Invidia catless 3" exhaust, Cobb Tuning SF itake, tuned by Sean Ivey. Made 321awhp / 343awtq @ 21psi. Clutch slips in 4th at WOT in low RPMs. Otherwise it's fine. If you're going to be on a stock 5 speed, don't shift much below 2,500 RPMs. Lower RPMs = more load on your clutch / trans = shorter life span. Barring 6,500 RPM dumps, no-lift shifts, and other completely unnecessary driving habits on the street, the stock drivetrain will handle the power no problem. EDIT: looked at the dyno sheet again, max boost was 21psi. Last edited by scoobasaurusrex; 12-05-2012 at 06:52 PM. |
#99 |
Member#: 267793
MWSOC
^^^ thanks! And no problem with fuel pump? I was thinking vf39, sti tmic, fuel pump and tune
With the and sr intake already installed! Can't WAIT to boost hard that's a lot of power for a 20 yr old haha |
#100 | |
Member#: 255114
Tri-State
And yeah you think that's fast... Try having a liter bike as a 20 year old ![]() |
