Old 11-15-2012, 02:45 PM   #1
carfizzi_07sti
Member#: 287981
2007 sti
black
Default question
I have a question. First here's some details. 2007 sti has a 2010 front brake system and I want to change it back to the original system. Now my question is how and where can I get the original part and how to fix it
carfizzi_07sti is offline   Reply With Quote
Old 11-15-2012, 02:56 PM   #2
sc00by4life
Member#: 97135
1.) you need to make better, more descriptive thread titles instead of just "question". that doesn't get people to click your thread to even give you an answer.
2.) 2010 WHAT front brakes. 2010 sti front brakes? the only real difference is the color and possibly the rotor size (a difference of a few mm). it makes no sense as to why you'd want to go back to stock, as you'll spend a bunch of money to get the exact same product you already have.
Old 11-15-2012, 03:18 PM   #3
carfizzi_07sti
Member#: 287981
2007 sti
black
It's because I ordered 07 suspention and I put them on my car and the front ones won't go on because its to big where the bottom of the suspention where it goes to the axel
Old 11-15-2012, 04:03 PM   #4
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
Calipers and rotors are the same (except the color). You have another problem and it's not the brakes.
MD04WRX is offline   Reply With Quote
Old 11-15-2012, 04:09 PM   #5
carfizzi_07sti
Member#: 287981
2007 sti
black
What could it be? Do you know
Old 11-15-2012, 04:19 PM   #6
MD04WRX
Member#: 72891
2014 Molten ST
Not sure what your problem is. Are you saying the new strut will not fit onto the knuckle? That the knuckle is too big where the strut bolts on?
Old 11-15-2012, 04:29 PM   #7
Bikelok
Member#: 254851
2002 WRX wagon 5mt
It sounds like he is trying to put WRX struts on a STi. Not sure though.
OP how about some pictures or at least tell us the problem using the correct names for what you are talking about.
Bikelok is online now   Reply With Quote
Old 11-15-2012, 05:03 PM   #8
carfizzi_07sti
Member#: 287981
2007 sti
black
I have a 07 sti and the knukle is to big
Old 11-15-2012, 05:15 PM   #9
sc00by4life
Member#: 97135
and you're sure it isnt a problem with the strut flanges being slightly bent?
if the knuckle is literally too thick, something is wrong with the hub.
Old 11-15-2012, 05:23 PM   #10
carfizzi_07sti
Member#: 287981
2007 sti
black
Nothing is bent or damaged. I wanted to know how to switch it out back to the original 07
Old 11-15-2012, 06:00 PM   #11
jamal
Member#: 71875
98 Legacy GT
my wheels fit
You have the original 07 stuff. The struts are wrong.
jamal is offline   Reply With Quote
Old 11-15-2012, 06:25 PM   #12
sc00by4life
Member#: 97135
you really aren't understanding.
you already have the hubs that originally came on your car....Swapping parts will do NOTHING for you.
SOMETHING is wrong, and it aint the hubs. most likely is you got the wrong struts.
judging by your responses, you might just want to take it to a shop and let the pro's handle it......
Old 11-15-2012, 09:33 PM   #13
Bikelok
Member#: 254851
2002 WRX wagon 5mt
What kind of struts are they? I'm sure they sent you wrx struts or perhaps you ordered the wrong struts.
Only the 2004 STi can use wrx struts.
2005-07 STi's can NOT use wrx struts.
Old 11-15-2012, 09:43 PM   #14
carfizzi_07sti
Member#: 287981
2007 sti
black
I bought the car with bc 2010 sti struts and I found this out when I ordered tein suspension for my 07 sti and the front ones are to small n the knuckle was to big
Old 11-15-2012, 09:50 PM   #15
sc00by4life
Member#: 97135
BC 2010...front only? Because the rears from 08+ are a completely different design.
Stop posting as confirm via part numbers you got the right struts. It is not your hub unless something is bent or broken....
Old 11-15-2012, 09:54 PM   #16
carfizzi_07sti
Member#: 287981
2007 sti
black
But that's the thing nothing is broken or bent. I'm just trying to find out how can I fix this problem and how to get my 07 tein front suspension on
Old 11-15-2012, 10:10 PM   #17
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
You either ordered the wrong parts, or you were sent the wrong parts. You ordered Tein coilovers and received ones that are designed for the WRX, NOT the STI that you have.
There is NOTHING WRONG WITH YOUR 07 PARTS. You need to get the correct version of coilovers that fit your '07 knuckles.
mav1c is online now   Reply With Quote
Old 11-15-2012, 10:12 PM   #18
carfizzi_07sti
Member#: 287981
2007 sti
black
Oh ok
Old 11-15-2012, 10:13 PM   #19
carfizzi_07sti
Member#: 287981
2007 sti
black
So the wrx has the same size and the sti has different diamaters for the front
Old 11-15-2012, 10:15 PM   #20
Web Foot STi
Member#: 39086
2004 STi
Again, is it a WRX Tein front strut, or a STI? The WRX has narrower mounting clevis than the '05-'07 STI.
One way, or another it sounds like you have the wrong struts. Your knuckles are fine.
Web Foot STi is offline   Reply With Quote
Old 11-15-2012, 10:22 PM   #21
ToddMcF2002
Member#: 135007
2014 STi Hatch
Crystal Black Silica
Listen to Web Foot STi. The mounting clevis on a 07 Wrx (5x100) is different on an 07 Sti (5x114). The STi is bigger.
ToddMcF2002 is offline   Reply With Quote
Old 11-15-2012, 10:23 PM   #22
mav1c
Hoodbridge!
Member#: 560
Rear coilovers for an 07 STI and WRX are the same. Up front, the STI has larger knuckles so you need specific STI front coilovers.
You need to contact the whoever sold you the Tein coilovers and tell them they sent you the wrong version. Tell them you need STI coilovers, not WRX coilovers, and exchange them.
Old 11-15-2012, 10:24 PM   #23
carfizzi_07sti
Member#: 287981
2007 sti
black
Ok thank u very much and sorry for all of the confusions and aggravations that has been caused
Old 11-15-2012, 10:25 PM   #24
carfizzi_07sti
Member#: 287981
2007 sti
black
Now why are they bigger than the back. Thats my other question
Old 11-15-2012, 10:33 PM   #25
ToddMcF2002
Member#: 135007
2014 STi Hatch
beefier wheel bearing and greater strength.
