Old 11-08-2012, 12:52 PM   #1
cbazq271
Member#: 330175
Default motor mount help
well I have read every post about changing motor mounts. I am changing the mounts on 05 sti. I am trying to put group N mount in now. After one full day and buying every possible type of 14 mm wrench, I finally got the left side off. Now I have spent half of today just trying to get the left rear bolt back in? I haven't even tried the driver side yet. All the post here tell you how to get the bolts out. But how do you get the bolts started back in? I have the pitch stop out and the motor jacked up as far as possible. Anyone living in the Glenfalls, NY area want some money and has done a mount swap before, PM me. I will pay to have these changed, but the car is not drivable. Chad
cbazq271 is offline   Reply With Quote
Old 11-08-2012, 02:00 PM   #2
cbazq271
Member#: 330175
Never mind, I got them. I have been trying to do it the way everyone said. Going at it from the rear of the motor. I have my complete exhaust out, so I could get to them right from the front of the motor, super easy. I just needed to go from a different direction. Now onto replacing my oil pick-up.
Old 11-15-2012, 06:47 AM   #3
icmfamous2
Member#: 337941
lmao I still can't get my rear bolts in either lol I used the torque solutions motor mounts and I still can figure it out lol
icmfamous2 is offline   Reply With Quote
Old 11-15-2012, 08:18 AM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Pics? You might have to put the rear in with the motor jacked up and off the crossmember..
Old 11-15-2012, 04:03 PM   #5
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Yes, this is how the rear bolts are accessed.
Old 11-15-2012, 04:20 PM   #6
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
Here's a quick DIY guide I used when doing my mounts: http://www.iwsti.com/forums/how-inst...ne-mounts.html. They are a pain to install but well worth it in the end!
V8Slayer is offline   Reply With Quote
Old 11-15-2012, 07:54 PM   #7
icmfamous2
Member#: 337941
thanks I'll give it a try...
Old 11-15-2012, 09:56 PM   #8
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Jack the motor up as high as you can get it. WATCH the lower radiator hose, at about 2.5" inches of lift you will start to tension it. Loosen the two bolts for the trans mount, remove either the forward or rear bolt from the pitch stop, and then obviously the motor mount bolts and lifting the engine will be much easier.
mechatricity is offline   Reply With Quote
Old 11-16-2012, 12:16 AM   #9
icmfamous2
Member#: 337941
thanks mission is complete it sucked too lmao thanks for the help
