#1 |
Member#: 293057
Ok I have a 02 wagon stage 2 spt intake and full exhaust. And tuned. My car will get stuck in open loop for what I can tell "no reason" or at least one I can't figure out. It usually only happens above 60. I can be driving down the highway at 70mph and about 75-90 load and and it will be fine in closed loop and then for no reason it will pop into open loop no change in load not going into boost or change in speed. Now if I were to slow down bery slowly keeping load the same, as soon as I get under 60mph it would pop back to closed. Even if I let off the throttle completely and then slowly get back on to maintain speed it will still be stuck in open loop. The only way to get it out of open loop is to drop to 4th and floor it and do a decent pull.
I have my tune set with no delays and the speed parameters are set higher. Everything else is pretty stock in the closed loop to open loop tables major changes have been made to the open loop fuel tables though pretty typical. Anyone have any ideas?!? It's driving me nuts anything I do doesn't seem to help no matter what it always gets stuck in open loop. The car seems to get crappy mileage too.. Always seems like it's working to hard to maintain speed and is always on the verge of boost at 75-80 mph Please help ![]()
#2 |
Member#: 293937
Vehicle:2004 WRX Black |
I'm not 100% sure but if you have your delay set to all zeros it doesnt take much to get into open loop. I would change the delays to a low value but not zero and see if that fixes the situation.
Hope someone else chimes in and confirms or denies the advice....good luck |
#3 |
Member#: 293057
The delay goes both ways.. It will delay it from going back to closed loop also. Alot of the newer Wrx's don't use delays from the factory. So I'm 99% sure it's not hurting me any. After I changed them to 0 the car drove alot better before it woul hit 7 psi or so before it would hit open loop and drop from 14.7. So if any thing 0 delay is helping me. It's almost like its going into a secret safe mode.
I've also realized that its rpm rather than speed based. It's only at or above 2500rpm I've noticed it at speeds of like 25-35 while I'm accelerating Thanks for your input though!!! |
#4 |
Member#: 334798
SCIC
its worth a try to set the delays to a low value, not zero.
im not confident if this will fix the problem but it is worth a shot. |
#5 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
look over rpm and speed threshold for open loop
#6 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
I'm not very familiar with 16-bit, but 32-bit ECUs will drop into OL when the Primary Open Loop (POL) Fueling table specifies an AFR richer than the threshold in the "Minimum Active POL Enrichment" table. (If switches immediately if the delays are all zero.)
If your ECU has a "Minimum Active POL Enrichment" Table then compare that value to the POL cells in the cruise area. You probably just need to make the 14.7 region extend to slightly higher loads. |
#7 | |
Member#: 124282
NWIC
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
#8 |
Member#: 268354
NESIC
Vehicle:02 WRX 05 LGT Slow Automatics |
Did you zero every CL/OL delay table..? Its been a while since I've played with the CL to OL delay. I know where I want it now so I always use that, but if I remember the car should always be in CL in negative MRP unless you're setting it like NSFW specifies.
#9 | |
Member#: 293057
I logged fueling final base, and watched it as it switched.. Again at 2400 rpm it would switch from 14.7 base fueling to 13.99 and my wbo2 will read about 13.4 I can't seem to find a lead or anyone else who has this problem. I've also ha this same exact problem even when I had delays. I keep looking for a 2400 rpm switch of some kind but nothing is standing out. Also all my coolant temp compensation and load rpm table are all zeros out. Along with I've tried setting "Minimum Active Primary Open Loop Enrichment really low, like 13.5 and it will still do the same exact thing. |
#10 |
n00b Moderator
South East
#11 |
Member#: 124282
NWIC
If your delays are zero'd, it is following the OL Fuel Table. Simple as that.
And no, no stock vehicle uses all zero'd delay values from the factory. Stop making claims as such. |
#12 | |
Member#: 293057
You don't need to be rude either... I'm just asking for help. And I've tried all the tried suggestion before. Like I've said I've researched cl/op function intensively. And seen how it all works. |
#13 |
Member#: 293057
Try it yourself. Change all delays to 0 and log cl/ol status. 7 being warm up 8 is closed loop and 10 is open loop. Yeah 0 delays makes it easier but that's only what they are... Delays not a switch there are many other criterias that have to be met to switch to open loop, those of which I won't go into.
#14 |
Member#: 124282
NWIC
NSFW already told you the same (correct) thing. But fine, continue believing as you wish.
#15 |
Member#: 293057
Yeah.. And he is correct in what he's saying. Exactly what I'm saying to.. It will go into open loop when your primary open loop tables calls for a Afr that is richer than the minimum actiive pol. Which it's working just fine. That's not the same thing as " always in open loop" those are a few of the "other parameters" I was talking about. Again if you read what he said correctly.. He states (If switches immediately if the delays are all zero.) meaning exactly what I said.. Not always in open loop but will switch immediately once parameters are met. Again that's not the problem I'm having. Constant speed and at loads where it's targeting 14.7 even in my ol table it will all of a sudden drop way richer that even my ol table is targeting.. Such as
2600 rpm and .80 load wbo2 reading 14.8-15.1 the. No changes in speed or load it will kick down to 13.0-13.99. Shouldn't be a delay problem, cause it did this with delays too as stated earlier. |
#16 | ||
Member#: 268354
NESIC
Also, I'm not sure how lance was being rude ![]() Quote:
#17 | |
Member#: 293057
I've tried changing pretty much every table I can think of with no results at all. |
#18 |
Member#: 293057
Ill post A tune when I can
#19 |
Member#: 217458
VIC
Vehicle:2010 DGM WRX Limited 1997 White STI Hatchback |
I'm keeping an eye on this, I'm noticing excessive open loop fueling on my car too.
#20 |
Member#: 293057
Yeah mines got a mind of its own. I even have Carberry that coded his own Rom (carberry rom) on it and he is at a loss of words too. He thinks it's a corrupted tune at this point. I'm starting over on a fresh tune and trying that's. I patched. Launch control into my current tune and that might have done it. We will see I'm uploading my new tune in the morning and im going to test it out.
