Old 11-15-2012, 12:23 PM   #1
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Default Can't tune out a lean spot.
So story goes like this. Car was fine (so to speak) and I had my clutch go out on me. I replaced the clutch and put everything back together. Now I have a lean spot in my tune that I can't get rid off. I though alright, I might have a leak.
Got my TMIC tested and my BOV was leaking. So I lapped the piston and put a new O-Ring and retested. Its seals perfectly now. I also added 2 more washers to make it stiffer. I then tested my motor. No leaks there either.
I have looked at the tune a million times and there is nothing that shows it should lean out.
If it makes any sense my A/F correction drops to zero when it leans out. Maybe the BOV is opening at partial throttle and letting a small amount of air out? though that would make the tune richer as metered air is escaping.
Any ideas would be nice.
OC_Nooby is offline   Reply With Quote
Old 11-15-2012, 01:55 PM   #2
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
can you pm me and send the rom over? it always helps to have two sets of eyes. :-)
Bamofo is offline   Reply With Quote
Old 11-15-2012, 03:46 PM   #3
sabreofsd
Member#: 48943
2004 95%*STi Blu/Gld
www.dcawd.com
Check your MAF, might need a little cleaning. Also, copy your MAF scaling and check for any odd spots. You might just be noticing the lean condition now, but it might have existed for a long time. How lean are you getting?
sabreofsd is offline   Reply With Quote
Old 11-15-2012, 05:05 PM   #4
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Is this the development of my new nasioc Bestie?!
Coming your way...somehow.
Old 11-15-2012, 05:06 PM   #5
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Stock MAF table. MAF was recently cleaned.
Old 11-15-2012, 06:23 PM   #6
sabreofsd
Member#: 48943
www.dcawd.com
Stock intake then?
Old 11-15-2012, 07:19 PM   #7
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Stock intake then?
stock intake to an AMR 3", the turbo inlet should not have an affect, I don't think?
Old 11-16-2012, 05:11 PM   #8
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Well the lean spot is gone. Not sure if it was my fuelling map tune or the engine compensation map tune I started working on. It's gone none the less.
Old 11-28-2012, 11:59 PM   #9
Bizko1288
Member#: 151260
2011 BMW 135i
__________
Did you disconnect the battery when you replaced the clutch?
This may sounds dumb, but maybe your ECU just relearned the proper correction after it was reset when you repaced that clutch? I am kind of curious just as a fmi, and I like threads with conclusive answers....
Bizko1288 is offline   Reply With Quote
Old 12-04-2012, 11:12 AM   #10
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I did not disconnect the battery.
Old 12-04-2012, 01:48 PM   #11
rocketperson7
Member#: 283968
MBP
fwiw, the only thing the ECU "learns" are long term fuel trims, and knock correction
both of which if tuned properly, should not be affecting the engine
Old 12-10-2012, 03:24 AM   #12
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
VTA BOV?
If yes, the it may be opening intermittently in vacuum. Stiffer springs or moar shimz should help.
