#1 |
Member#: 311781
Vehicle:2003 WRX w STI V8 |
So story goes like this. Car was fine (so to speak) and I had my clutch go out on me. I replaced the clutch and put everything back together. Now I have a lean spot in my tune that I can't get rid off. I though alright, I might have a leak.
Got my TMIC tested and my BOV was leaking. So I lapped the piston and put a new O-Ring and retested. Its seals perfectly now. I also added 2 more washers to make it stiffer. I then tested my motor. No leaks there either. I have looked at the tune a million times and there is nothing that shows it should lean out. If it makes any sense my A/F correction drops to zero when it leans out. Maybe the BOV is opening at partial throttle and letting a small amount of air out? though that would make the tune richer as metered air is escaping. Any ideas would be nice. Thanks!
#2 |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
can you pm me and send the rom over? it always helps to have two sets of eyes. :-)
#3 |
Member#: 48943
MAIC
Vehicle:2004 95%*STi Blu/Gld www.dcawd.com |
Check your MAF, might need a little cleaning. Also, copy your MAF scaling and check for any odd spots. You might just be noticing the lean condition now, but it might have existed for a long time. How lean are you getting?
#4 |
Member#: 311781
#5 |
Member#: 311781
Stock MAF table. MAF was recently cleaned.
#6 |
Member#: 48943
MAIC
Stock intake then?
#7 |
Member#: 311781
#8 |
Member#: 311781
Well the lean spot is gone. Not sure if it was my fuelling map tune or the engine compensation map tune I started working on. It's gone none the less.
#9 |
Member#: 151260
MAIC
Vehicle:2005 Sti 423whp/422wtq on 93 |
Did you disconnect the battery when you replaced the clutch?
This may sounds dumb, but maybe your ECU just relearned the proper correction after it was reset when you repaced that clutch? I am kind of curious just as a fmi, and I like threads with conclusive answers.... |
#10 | |
Member#: 311781
#11 |
Member#: 283968
MWSOC
Vehicle:2003 WRX MBP |
fwiw, the only thing the ECU "learns" are long term fuel trims, and knock correction
both of which if tuned properly, should not be affecting the engine |
#12 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
VTA BOV?
If yes, the it may be opening intermittently in vacuum. Stiffer springs or moar shimz should help. |
