![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 287981
Tri-State
Vehicle:2007 sti black |
I have a question. First here's some details. 2007 sti has a 2010 front brake system and I want to change it back to the original system. Now my question is how and where can I get the original part and how to fix it
#2 |
Member#: 97135
NWIC
1.) you need to make better, more descriptive thread titles instead of just "question". that doesn't get people to click your thread to even give you an answer.
2.) 2010 WHAT front brakes. 2010 sti front brakes? the only real difference is the color and possibly the rotor size (a difference of a few mm). it makes no sense as to why you'd want to go back to stock, as you'll spend a bunch of money to get the exact same product you already have. |
#3 |
Member#: 287981
Tri-State
It's because I ordered 07 suspention and I put them on my car and the front ones won't go on because its to big where the bottom of the suspention where it goes to the axel
#4 |
Member#: 72891
MAIC
Vehicle:2004 WRX SDN JBP 96 SVX -2012 Fiesta |
Calipers and rotors are the same (except the color). You have another problem and it's not the brakes.
#5 |
Member#: 287981
Tri-State
What could it be? Do you know
#6 |
Member#: 72891
MAIC
#7 |
Member#: 254851
Vehicle:2002 Wrx wagon 5mt PSM |
It sounds like he is trying to put WRX struts on a STi. Not sure though.
OP how about some pictures or at least tell us the problem using the correct names for what you are talking about. |
#8 |
Member#: 287981
Tri-State
I have a 07 sti and the knukle is to big
#9 |
Member#: 97135
NWIC
#10 |
Member#: 287981
Tri-State
Nothing is bent or damaged. I wanted to know how to switch it out back to the original 07
#11 |
Member#: 71875
Vehicle:98 2.5GT my wheels fit |
You have the original 07 stuff. The struts are wrong.
#12 | |
Member#: 97135
NWIC
you already have the hubs that originally came on your car....Swapping parts will do NOTHING for you. SOMETHING is wrong, and it aint the hubs. most likely is you got the wrong struts. judging by your responses, you might just want to take it to a shop and let the pro's handle it...... |
#13 |
Member#: 254851
What kind of struts are they? I'm sure they sent you wrx struts or perhaps you ordered the wrong struts.
Only the 2004 STi can use wrx struts. 2005-07 STi's can NOT use wrx struts. |
#14 |
Member#: 287981
Tri-State
I bought the car with bc 2010 sti struts and I found this out when I ordered tein suspension for my 07 sti and the front ones are to small n the knuckle was to big
#15 | |
Member#: 97135
NWIC
Stop posting as confirm via part numbers you got the right struts. It is not your hub unless something is bent or broken.... |
#16 |
Member#: 287981
Tri-State
But that's the thing nothing is broken or bent. I'm just trying to find out how can I fix this problem and how to get my 07 tein front suspension on
#17 | |
Hoodbridge!
Moderator Member#: 560
MAIC
Vehicle:2006 STi, '11 A4 Crystal Gray, Silver |
There is NOTHING WRONG WITH YOUR 07 PARTS. You need to get the correct version of coilovers that fit your '07 knuckles. |
#18 |
Member#: 287981
Tri-State
Oh ok
#19 |
Member#: 287981
Tri-State
So the wrx has the same size and the sti has different diamaters for the front
#20 |
Member#: 39086
NWIC
Vehicle:2004 STi White |
Again, is it a WRX Tein front strut, or a STI? The WRX has narrower mounting clevis than the '05-'07 STI.
One way, or another it sounds like you have the wrong struts. Your knuckles are fine. |
#21 |
Member#: 135007
Vehicle:2002 Wrx Sedan Aspen White |
Listen to Web Foot STi. The mounting clevis on a 07 Wrx (5x100) is different on an 07 Sti (5x114). The STi is bigger.
#22 | |
Hoodbridge!
MAIC
You need to contact the whoever sold you the Tein coilovers and tell them they sent you the wrong version. Tell them you need STI coilovers, not WRX coilovers, and exchange them. |
#23 |
Member#: 287981
Tri-State
Ok thank u very much and sorry for all of the confusions and aggravations that has been caused
#24 |
Member#: 287981
Tri-State
Now why are they bigger than the back. Thats my other question
#25 |
Member#: 135007
beefier wheel bearing and greater strength.
