Mid Atlantic Impreza Club
Closed Thread
Old 11-14-2012, 10:52 AM   #3476
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
Originally Posted by God&Sme View Post
Yeah I reckon they are. Today when I went to get it aligned the dude was trying to pull out the crazy positive camber n popped out my axle I was in wreck tho so there must be something else that's bent bc in order to get camber in spec the links are crazy extended n popped out the axle. They suggested that the strut may be bent
N those purple bushings are made by SuperPro. 65bucks from IIR and w/a $15 pitman arm pullet I didn't need a press. Pretty simple once u get all Hulk on those crazy tight bolts. At least I dist break any tho
Thanks for the tip about the bushings. I had a small accident with mine years ago (slid the rear wheel sideways into a curb during a snowstorm). The body shop told me that I needed a new knuckle because it was obvious that it had been cracked in a previous accident (I'd rather not get into that one ).
Apparently, instead of fixing it, the first body shop just elongated the bolt holes on the struts, and tried to pull everything into place. No wonder my camber was always off!
Anyways, the crack followed the top seam where the hole for the axle meets with the body of the knuckle causing it to always have a lot of positive camber. None of the shops that did my alignment ever said anything, and because of that shop cutting corners, a small bump into the curb extended the crack so bad that my rear wheel ended up looking kinda like this:
(I know that's a Neon, but I had to share that picture.)
ThatGy is offline
Old 11-14-2012, 12:16 PM   #3477
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
DAAAAAAAAAAAAAAAAAAAAAANG!!!
thats nutso.
yeah from what ive read its probably a bent knuckle/spindle or strut. The struts are brand new so i was hoping its not that, buuuuuuut a knuckles a bit of money n i could probably just throw back on my old strut for the time being if need be...pretty sure i didn't toss em ???
God&Sme is offline
Old 11-14-2012, 12:20 PM   #3478
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
thats nutso.
What kind of struts did you get? I'm going to have to turn my WRX back into a daily driver next year, so I'm shopping for replacements.
ThatGy is offline
Old 11-14-2012, 06:43 PM   #3479
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
just the gr2's, super cheap and from everything i read, like factory spec. Im just running those with some sprint springs, so a moderate drop.
Ive been dying b/c all day it was nice n i ssooooooo badly wanted to go outside, rip off the wheel n find whats bent BUUUUUT i have 2papers to write before saturday
God&Sme is offline
Old 11-14-2012, 09:18 PM   #3480
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
thats nutso.
If the current struts where not on it when the accident happened I would worry about it.
Just search the classifieds for a part out and buy that sides whole assemble ( knuckle, a-arm / the whole setup).
If the knuckle is dent there are more parts that are more than likely bent also.
08WRXNUBE is offline
Old 11-15-2012, 01:25 AM   #3481
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Yeah, I replaced bent lat links and the trailing arm. Im going to check it out soon
God&Sme is offline
Old 11-15-2012, 09:34 AM   #3482
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
So low my rotors scrape..
So I broke the oil feed line to my turbo during the install. Its a vf39 om my 04 2.o wrx block. I'm trying to find a steel braided line fir that turbo can anyone help? I see the one from rallysport ( http://www.rallysportdirect.com/Blou...-Oil-Feed-Line) but that one says its for the Blouch turbo's. If any one has used that on a Vf series turbo let me know. I just don't wana shell out 60$ on a part that wont work. So if some one can shed some light on this ill love you forever. ?
WRX WARRIOR is offline
Old 11-15-2012, 09:41 AM   #3483
jeffie7
Member#: 321791
05 STi
http://www.fastwrx.com/
Is in NVA. They sell a good amount of parts.
jeffie7 is offline
Old 11-15-2012, 09:56 AM   #3484
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
Already talked to Dan they don't have anything.
Old 11-15-2012, 09:59 AM   #3485
stlouise
Member#: 334309
Today, nothing. Tuesday went to IAG for the first time for maintenance. Two thumbs way up - great service, met some cool people. It was a good day off.
stlouise is offline
Old 11-15-2012, 01:13 PM   #3486
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
Bump this. Called IAG they are going to make me one. Performance shops FTW.
Old 11-15-2012, 03:50 PM   #3487
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Not my car but I painted my snow plow today
lilblue619 is offline
Old 11-15-2012, 04:07 PM   #3488
STiWanabe
Member#: 41447
---- _________
so MachV doesnt have one but IAG can MAKE one? That kinda says something
STiWanabe is offline
Old 11-15-2012, 04:29 PM   #3489
infinite012
Member#: 74392
2015 Forester
Tire rotation complete. I also regreased my front sway bar bushings (sort of).
infinite012 is offline
Old 11-15-2012, 04:54 PM   #3490
voltic
Member#: 310385
Chapter/Region: HIIC
2016 BRZ Limited
Series.HyperBlue
Didn't technically do anything to my car today, but someone left these sitting around on my doorstep.
voltic is offline
Old 11-15-2012, 06:48 PM   #3491
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
No motor No Trans :-(
I think they left that at the wrong door. Looks like mine. :-(
What ya got there ?
marios03wrx is offline
Old 11-15-2012, 06:53 PM   #3492
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
Haha yeah I know right. When I was talking to Mach v they said they wouldn't."custom" make one to work with my banjobolt and specific turbo. And not wanting to take the risk, I called IAG and they said they have a Vf laying arround and they could make one specificly for the vf39. Same price. So buy one that has a 50% of not fitting/working right, or pay the same for something the fit to my spesific model, yeah that got my vote.
What ya got there ?
About to say the same thing lmao.
Old 11-15-2012, 09:01 PM   #3493
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
What ya got there ?
Blouch Dom 1.5 XT-R, 10cm turbine housing, 2.4" Inlet and ID 1000's with conversion harnesses. Last week my inlet, fuel pump, AFR equipment, and spark plugs arrived.
Hopefully I'll see an intercooler tomorrow.
voltic is offline
Old 11-15-2012, 09:26 PM   #3494
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
replaced the car's battery. after ~6 years, the OEM battery finally gave out
replaced it with an Optima Red top.
roccer is offline
Old 11-15-2012, 10:02 PM   #3495
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
@ Voltic - I have the same Perrin V2 inlet.. love it. Install was way better than the V1 and Gimmick
Here is a pic from the sideskirts I painted and put on the other day:
Smurftastic is online now
Old 11-15-2012, 10:32 PM   #3496
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
NICE!!!! Is that 10cm side twin or single scroll?
Mario
Old 11-15-2012, 10:39 PM   #3497
infinite012
Member#: 74392
2015 Forester
Just got the quad hella horns wired up again and the car on jack stands to prep for diff fluid flush tomorrow.
Old 11-15-2012, 10:45 PM   #3498
skatin707
Member#: 251552
2014 FXT
Same here. I love that inlet
skatin707 is offline
Old 11-15-2012, 10:51 PM   #3499
voltic
Member#: 310385
2016 BRZ Limited
Series.HyperBlue
Mario
Single, I spent like 5 months doing my homework on all this and ended up deciding that twin scroll was silly expensive. Still haven't figured out why.
Just curious, what do you do about the relay? My first one corroded. This time I basically dipped the bastard in liquid electrical tape.
Glad to know the install shouldn't be too terrible, though I imagine when I do the turbo I'll be doing it, so crap will be torn apart anyway.
Might be in over my head, never done a turbo before. Oh well, should at least be entertaining to observe.
voltic is offline
Old 11-15-2012, 11:40 PM   #3500
jeffie7
Member#: 321791
05 STi
Last weekend was the 2nd axle seal, driving the car today I noticed that smell again.....
Rear seal between the transmission and drive shaft is leaking
MOFO#@$#@$#@$#$@@#$$#
all 3 seals in 1 month.
jeffie7 is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
