Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 11-07-2012, 08:02 PM   #1
coalslaw
Member#: 324808
2006 IWL Stg2
Default Exhaust popping. normal?
Im curious to know why my friends's 03 wrx makes this popping sound atleast every first gear or every other gear. he drives very lightly, shifts at lowest RPM possible. everytime he finishes a gear or two, his exhaust would " PPFT!!" is this a result of unburned fuel entering exhausts?
personally, I find his exhaust is too loud (proly catless), can smell enough fuel when your outside of the car. hes got sti injectors, vf 34, bov, cai, tbe, new 03 tranny and supposedly st1 clutch but no tune at all. he keeps relying on the accessport vf34 maps. his car shudders enough at take off, the gear would throw back making "ACKK!!" sound when I switch from Neutral to first at idle stops. he tells me to shift to 2nd then first everytime because of the short shifter.... He recently bought the car and im assuming the prev owner neevr tuned it either....any suggestions?
coalslaw is offline   Reply With Quote
Old 11-07-2012, 08:09 PM   #2
WrxWrb
Member#: 287477
02 Wrx Wagon WRB
EVO III 16g=Fun
Tune it and take off the bov.
WrxWrb is offline   Reply With Quote
Old 11-07-2012, 08:49 PM   #3
coalslaw
Member#: 324808
2006 IWL Stg2
thats what i suggssted too. what about the other issues?anyone know causes/fixes?
Old 11-07-2012, 09:06 PM   #4
04sedantyson
Member#: 233011
2004 04 sedan
I had a VTA bov, mine did it all the time. took it off after a week, went away
04sedantyson is offline   Reply With Quote
Old 11-10-2012, 10:38 AM   #5
coalslaw
Member#: 324808
2006 IWL Stg2
what about the tranny/clutch? any reason why it would studder at take off? or refuse to switch from neutral to first?
Old 11-10-2012, 01:15 PM   #6
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Not going into first sounds like what my old bug would do. It hand no syncro on first so you had to stick it in second then first. Since it sounds like it was beat hard so I wonder if the PO jammed it straight into first at speed too many times and the syncro is just totally hashed.
He does actually have a "tune" just not a protune. The Cobb OTS maps aren't horrible, not that great though. I've been running the VF39 map for years. Your friends popping issue is 100% due to his retarded BOV. Get rid of that and it'll be fine.
bushflyr is offline   Reply With Quote
Old 11-14-2012, 07:14 PM   #7
coalslaw
Member#: 324808
2006 IWL Stg2
thanks. i hope he reads this and makes the right choice for the longevity of his wrx.
Old 11-15-2012, 06:43 PM   #8
rhymeboy89
Member#: 286744
subarus love to backfire (pop) a little i believe. I got a opensource tune with a stock bpv and it still backfires even though the air/fuel ratio is perfect.
rhymeboy89 is offline   Reply With Quote
Old 11-15-2012, 10:31 PM   #9
paulpat
Member#: 237145
02 WRX
12 FXT
Yeah syncros with second and first..... double clutching or rev matching slightly helps alot.
Or do what I did and upgrade to a transmission with syncros 6mt. Lol
paulpat is offline   Reply With Quote
Old 11-16-2012, 12:05 AM   #10
jhayesvw
Member#: 326502
2003 WRX Wagon
I have a protune and stock BPV and my car likes to pop a bit if I get on the gas and then clutch it when coming to a stop.
jhayesvw is offline   Reply With Quote
