Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 11-15-2012, 05:37 PM   #1
wookieda
Member#: 326265
Default rough idle after hitting wild animal
So i hit a coyote..
Poor thing didn't survive the impact..
anyway, since the incident, the car runs really rough.. I'm suspecting vacuum leak..(I really hope it is as simple as that).. or knicked fuel line? no leak or anything tho.
I took this vid of boost guage at idle..
https://www.youtube.com/watch?v=bRJ9...e_gdata_player
what do you guys think?
wookieda is offline   Reply With Quote
Old 11-15-2012, 09:11 PM   #2
legacydreamz
Member#: 92423
still locked in freezer
Looks like a hard enough impact to pop an already loose hose or finish off a dying sensor. Any codes?
legacydreamz is offline   Reply With Quote
Old 11-15-2012, 09:26 PM   #3
wookieda
Member#: 326265
I haven't looked for a code. i should, even tho no CEL yet..
Old 11-15-2012, 09:27 PM   #4
paulpat
Member#: 237145
02 WRX
12 FXT
Coyote ghost? Dirty Maf sensor soaked with blood? Fur in the iacv?
Can you log the car at all? Like with rom raider? I don't think there is any important thingsin that area besides electrical stuff. Maybe ur grounding a wire now and putting more load on the alternator?
paulpat is offline   Reply With Quote
Old 11-15-2012, 11:50 PM   #5
OK Houston
we have an Uncle
oooohhh....skipped tooth/teeth on the timing belt mebee!!!!!
happens like that sometimes
Old 11-16-2012, 04:16 PM   #6
wookieda
Member#: 326265
yeah i 'm not sure.. i have to see an adjuster for my insurance company as they will determine if i had infact hit an animal, not something else.. anyways they are going to be reluctant to fix the engile idle issue unless i can prove to them that this happend after hitting the animal.
Checked for vacuum leaks yesterday.. no leaks that i could find .. re-tightened all the rings and hoses. took off TMIC and re-tightened everything also. Thinking it could be something electrical.. besides the spark plugs/wires. it could be the coil pack :s
Ohhhh the fun never ends.
Old 11-16-2012, 04:46 PM   #7
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
as an insurance adjuster i will tell you this:
-the cracked lip looks too low to be Wylie E. himself.
-there is always blood/fecal matter/fur left behind.......unless you wash the car for some reason
GL
AliBenn is offline   Reply With Quote
Old 11-16-2012, 09:18 PM   #8
wookieda
Member#: 326265
GL
I'm here to get opinions on my rough idling issue, not about your professional opinion on rahter i hit an animal or not. it was a small coyote/stray dog and i have taken enough photos and record of calling police and calling my insurance company on the spot to worry about the claim.
and i was not speeding to hit the thing and explode it all over my car.
http://img856.imageshack.us/img856/9920/641n.jpg
Old 11-17-2012, 03:12 PM   #9
paulpat
Member#: 237145
02 WRX
12 FXT
Homer simpson voice: ugggggghhhhhhm. Dinnnnnnneeeerrrrrr
Old 11-18-2012, 09:54 PM   #10
sonicwrxpa
Member#: 148111
2003 wrx
sonic yellow
Yeah, I have been unlucky enough to hit a large dog, deer, and small bear all with my suby. :-((( The only animal trace left was hair from the deer that was stuck In the seal of my tire/rim. No blood at all.
Check for lose vac lines or maybe just clean your iacv. Could just be dirty and have nothing to do with the coyote.
sonicwrxpa is offline   Reply With Quote
Old 11-19-2012, 09:12 AM   #11
bplumley70
Member#: 330040
2003 wrx
wrb
i hit a deer last year. knocked my timing chain off a notch. i dont know how it was possible but it did indeed mess with the idle. something to check out
bplumley70 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 11:19 AM.
