Old 11-16-2012, 12:52 AM   #1
Scotty_WRX
Member#: 313930
Default Blown 5MT, dealer story and flywheel/clutch questions inside....
Long story semi long.... cliffs at bottom
Purchased at dealer, 2009 Subaru WRX Premium, 72XXXKM when I purchased, about 84XXXKM now. Drove it to work one day no problems, through all 5 gears. Parked it for the day and when I went to leave, threw it in reverse and the car would not budge. Serious chatter from clutch pedal and tranny. Best way to describe is it that it a) felt like the wheels were chocked and the eBrake was on or b) that feeling when a car sits for a long time and the rotors rust to the brake pads and you have to "break" the car free... Threw it in 1st, same feeling. Put it into neutral, got out and looked around saw nothing, popped the hood and looked around and saw nothing. Jumped back in and on the 4th time it finally went into reverse and with a bit of gas it caught power and backed out of my parking spot. Got out, looked again, no visible issues and she was rolling fine in neutral.
Headed up the road, SUPER tranny whine and noise but the car was shifting fine with no chatter or vibrations from 1st to 5th, however did have what I thought at the time was some turbo whine. Call the dealer and say I am on my way. I limp it over in 5th gear and park it. This is tuesday. End of day so they will look at it tomorrow. Next day I get a call saying that the tranny is the culprit and they will take a look at it. Its under warranty so I am not overly worried. (still in 5 year 100,000)
I have not spoken to the tech directly so everything I am saying here is comming from the service rep. Tech pulls the back end of the tranny off and says that some of the gears are uckfayed. I asked if the gearset had broken something lose, if a syncro went or what the problem was and could not get a straight answer. I was never told exactly what let go or what the issue was just something itshay the bed. He says hes going to replace some stuff and see if that fixed it. Get a call thursday saying my car is ready for pickup in the afternoon. I make plans but shortly after I get another call back saying its not ready. Turns out with the snow storm they only got it up through 3rd and not up to speed. When they got it up to speed going faster in 5th the same whine and sounds were there. So, new parts being ordered. New gearset, snycros, bearings ect ect. Its Thursday, no parts till Monday. Rental car time. Monday comes, no parts in yet its a holiday. Tuesday comes, parts in in but a lock washer, yes, a lock washer is not in and they don't have one as its on backorder for the day so I'll have to wait for the tech to do work on Wednesday. Part comes in, tech drops the tranny and gets to work. Get a call today, Thursday, 8 days later, saying that the new gearset did not fix the job and they will be giving me a whole new tranny assembly. 1 week out if instock, 2-3 weeks out if they have to bring one in. Got a '13 Fozzy as a loaner from the dealer.
This is where I need advice; the service guy mentioned to me that the clutch was on its way out, about %40 life left and would need about $1300 in just parts to replace the clutch (no labour cost) I said no, its okay I'll wait. Today when we are talking about the new tranny he says the throwout bearing was seized and they had to replace it. Also the clutch is now slipping in 5th gear. I have never run the car hard enough to make it slip in 1st or second let alone 5th gear. He said he would put in a new OEM clutch if I paid for it ($1100 on todays quote for disc, pressure plate and flywheel) or if I get him a aftermarket one he would install it with no labour cost. When I asked if the flywheel needed doing, he said hed go and ask the tech. Calls me back and says the flywheel is "cracked" and I need a new one.
I guess what I am stumped is that I am wondering if this is a way of the dealer trying to grab some $$ back for this big warranty claim. I am leaing towards no as hes letting me put a aftermarket one in and not charging me labour, so he could and will be making no $. I've never had the clutch slip and now all of a sudden its slipping and it needs replacing? The flywheel is cracked? My tranny just blew up, I blame that and my ittshay clutch on my faulty tranny.... I started to go down the road with him about replacing my clutch and flywheel under warranty but that was shut down quickly by him. Yes, almost 85,000 I don't find it unbelievable to believe that the 5MT's clutch is going but still....
I am leaning towards the Exedy clutch kit (plate, disc, bearing ect for $350) and just having the flywheel resurfaced. Thoughts?
I have not seen the flywheel or the clutch myself as the car has been reassembled and is drivable right now and sitting in the parking lot of the dealer.
Cliffs-
2009 wrx with 84000KM
drove to work, parked. getting ready to go home, throw in reverse and tranny itshays the bed
drive to dealer, they try and fix with 3 patch jobs but eventually say tranny is uckfayed and order me a new 5MT
clutch is now slipping and flywheel is cracked according to dealer.
can put OEM or aftermarket in at my own cost with no labor being charged
Should I get a new flywheel to go with my new clutch or just have it resurfaced? I am only looking for Stage 2 when warranty is up and 300hp/300tq so nothing crazy, its a DD.
Am I being uckfayed by the dealer?
Should the clutch/flywheel be covered under powertrain because my tranny itshay the bed? Dealer will probably be no dice so should I talk to Subaru of Canada?
or is the car uckfayed and should I trade it in for a bicycle?
Thanks for reading.
Scotty_WRX is offline   Reply With Quote
Old 11-16-2012, 03:32 AM   #2
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
They should be doing all that stuff at no charge to you. If not under the 100kkwarranty then under the not selling you aa defective car thing.
bushflyr is offline   Reply With Quote
Old 11-16-2012, 08:23 AM   #3
Scotty_WRX
Member#: 313930
Clutch and flywheel no, everything else yes.
Old 11-16-2012, 08:29 AM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Thanks for reading.
The car is a DD, no need for Stg2...
Replace the clutch and FW with stock or stock replacements (Exedy) and be happy...
The clutch and flywheel are wear items, just like the brakes, they aren't going to cover it, they don't know how you drove it, besides you blew the transmission...
Suck it up, you're getting a fresh trans, you likely needed a clutch anyway..
Old 11-16-2012, 05:46 PM   #5
Scotty_WRX
Member#: 313930
I can get a OEM Exedy and OEM Subaru flywheel for about $700~ to my door from the US give or take some UPS uckyfay and duty OR get a Stage 1 Exedy (EXE 15804) and lightweight flywheel (FF502) locally from Lightspeed for $830..... seem like a pretty easy decision for only $130 more....
Stage 1 is more $ than stock, but the lightweight flywheel is cheaper than OEM so thats where it evens out.... part of me is leaning towards a OEM flywheel and Exedy Stage 1 (EXE 15804) as I have never driven with a lightweight flywheel but am open to anything....
Maybe I'll push more than 300/300....
Old 11-18-2012, 11:00 AM   #6
mj213
Member#: 252218
2002 Forester
Sounds like you're better off with the Exedy OEM equivalent stuff - no Stage 1 etc.
mj213 is offline   Reply With Quote
