Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 11-13-2012, 04:01 PM   #1
mt1101
Member#: 291990
2003 BUGEYE WAGON
Default Anyone near queens please help
I need someone who can help me inspect the clutch install this local transmission shop performed on my car. Pm me ASAP if you can help. Thanks.
mt1101 is offline   Reply With Quote
Old 11-13-2012, 04:21 PM   #2
rice h8r
Member#: 94524
What exactly is wrong?
rice h8r is offline   Reply With Quote
Old 11-13-2012, 04:39 PM   #3
mt1101
Member#: 291990
2003 BUGEYE WAGON
They installed new clutch kit and car slips when cold and only grabs once heated up which is after a while of driving. Car shifts and works fine other than that. I took the car back and told them something went wrong on the install and the more I talk to them the more I worry they will just mess it up again. They are going to drop the Trans and have me come by to see.
Old 11-13-2012, 06:39 PM   #4
trife86
Member#: 301368
PBP
Doesn't sound like clutch itself I would say check out the master or slave..
trife86 is offline   Reply With Quote
Old 11-13-2012, 07:12 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Hydraulics won't make the clutch slip, just the opposite (incomplete disengagement).
There isn't much to inspect externally, it probably does have to come apart. You'll have to give the shop a chance to make it right, worst case you may need to have a different shop fix it and document any problems for use in getting the original shop to pay directly or in small claims court.
Mulder is offline   Reply With Quote
Old 11-13-2012, 07:25 PM   #6
mt1101
Member#: 291990
2003 BUGEYE WAGON
My fault for not just towing it to a reputable Subie shop. I figured a transmission shop would know better. Anyway I saw my car parked outside so I know they haven't touched it yet. I want them to honor their work but I don't know if that's even worth it. Argh! I really can't catch a break. The car is so close to complete minus this stupid clutch issue.
Old 11-13-2012, 07:30 PM   #7
jthatch12
Member#: 321715
03 Big 16G WRX
take it back to the transmission shop. if they messed up they should also fix it
Old 11-13-2012, 07:58 PM   #8
mt1101
Member#: 291990
2003 BUGEYE WAGON
It sucks because the shop owner keeps leaning on it not being the clutch that is the problem. How would that even pass in court? He even drove my car with me in it and confirmed the car is slipping. Bottom line his shop did the clutch job and there is no way I'm paying for this. But it feels like I need another witness to get my point across or someone from here to show them what's up in case their techs are missing something. I'll have a reward of course.
Old 11-13-2012, 08:52 PM   #9
mt1101
Member#: 291990
2003 BUGEYE WAGON
Interesting find on another thread I should check on the axles as they are known to pop out.
Old 11-13-2012, 09:02 PM   #10
AZP Installs
Member#: 40160
As others have said, the original shop should fix it for you.
HOWEVER, I see you have a 2003. Did you provide the parts or did they? We have seen on more than 1 occasion where the 02 and 03 transmissions are VERY finicky on which flywheel/clutch combo is used. We've had to re-do a few using OEM parts specific for the VIN of the car we were installing.
So any details you can provide would help us help you out.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 11-13-2012, 09:58 PM   #11
mt1101
Member#: 291990
2003 BUGEYE WAGON
Car is an 03 and had the BA tranny but swapped with a rebuilt AA. Car drives fine minus the whole cold weather slip deal. The clutch kit is new ksb03 exedy oem with act streetlight flywheel. I am going to pray it is just the axles. It kind of makes sense if heat affects the expansion of the axles tightening up onto the diff? Or has this whole ordeal got me going mad? Guess I'll find out in the AM.
Also, I plan on visiting azp just because I always hear good things.
Old 11-13-2012, 11:09 PM   #12
mt1101
Member#: 291990
2003 BUGEYE WAGON
Old 11-13-2012, 11:17 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You didn't mention whether the speedometer is going up when it slips. If it does then it probably is the axles, a slipping clutch doesn't do that.
Old 11-13-2012, 11:44 PM   #14
mt1101
Member#: 291990
2003 BUGEYE WAGON
Speedo def not going up
Old 11-13-2012, 11:48 PM   #15
mt1101
Member#: 291990
2003 BUGEYE WAGON
If it is just my axles, I am celebrating. Keep you posted.
Old 11-14-2012, 08:06 AM   #16
AZP Installs
Member#: 40160
Interesting. It could be the axles. Keep us posted.
-Mike Paisan
Old 11-14-2012, 04:57 PM   #17
mt1101
Member#: 291990
2003 BUGEYE WAGON
Holy crap it was the rear right axle that popped out!!! Car is beautiful now. Time to get tuned! Thank you NASIOC and google.
Old 11-15-2012, 09:43 PM   #18
AZP Installs
Member#: 40160
Cool, glad you got it worked out!
-Mike Paisan
Old 11-16-2012, 12:22 AM   #19
mt1101
Member#: 291990
2003 BUGEYE WAGON
well just as luck would have it I was going up a hill and pushed it just slightly and sure enough the axle popped out again!? this sucks.
Old 11-16-2012, 01:15 AM   #20
mt1101
Member#: 291990
2003 BUGEYE WAGON
Old 11-16-2012, 08:46 AM   #21
X Mon
Member#: 156443
2006 WRX Wagon WRB
2001 Forester S, EJ205/5m
The clips can tend to stay in the differential, rather than coming out on the axle. If you can't get it to seat fully (I've seen this more than one time before), try putting a large hose clamp over the CV stub. Use a drift punch on the worm gear portion of the clamp to drive the axle into place.
X Mon is offline   Reply With Quote
Old 11-16-2012, 08:53 AM   #22
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Since it's the rear axle it's unlikely the shop had anything to do with it, as they wouldn't touch that when doing the clutch. Just an unfortunate coincidence.
Old 11-16-2012, 09:32 AM   #23
mt1101
Member#: 291990
2003 BUGEYE WAGON
Thanks for replies. It is so frustrating ...I literally went from radiator leak to gearbox fail to axle problems all within past couple months.
Old 11-16-2012, 09:55 AM   #24
mt1101
Member#: 291990
2003 BUGEYE WAGON
I've also heard that the clips stay on the diff and you basically just try to pop them back in...however, that only lasted a few days so I'm going to have to look inside to see what's up with the clip.
