Old 09-10-2011, 05:02 PM   #26
Krazematik
Member#: 279076
my AT oil temp started to flash right after i installed my turbo inlet... so how much is a brake switch and how does it look like?
Krazematik is offline   Reply With Quote
Old 10-21-2012, 08:40 AM   #27
02 banana owner
Member#: 232546
Blaze yellow
So I know this is completely wrong year car and way different situation. Ive got an 02 wrx. I did a complete swap over to auto. . So things that were changed is this: transmission, driveshaft, rear dif, pedal assembly, shifter assembly, under dash harness (Have to, 5spd harness doesnt have the plugs for the auto), instrument cluster, ecu. I am sure there is some stuff missing but simply put you would never know the car wasnt an auto from the factory. My problem is the same flashing A/T fluid temp hot. Fluids are at the right levels. Car seems to drive fine. Just dont know what the problem is. Oh, my brake lights work like a charm.
02 banana owner is offline   Reply With Quote
Old 10-21-2012, 11:37 PM   #28
Big Joe
Member#: 3722
2002 WRX Wagon
HTML Code:
Did you swap out the radiator for the AT cooling lines?
Big Joe is offline   Reply With Quote
Old 10-26-2012, 08:54 PM   #29
smoovjames
Member#: 335698
That's not good ! Hahahahaha I had similar problem with my dsg 09 turbo jetta after bolt ons and a stage 2 flash and a lot of beating under warranty .. u should probly beat on it more ! Or get a k20A swapped Honda so it can take the abuse, and hopefully it wont get stolen like mine did . Then u end up getting a subaru and loving it because its the best of all worlds - Awd turbo manual winning
smoovjames is offline   Reply With Quote
Old 11-16-2012, 05:40 AM   #30
02 banana owner
Member#: 232546
Blaze yellow
Joe, yes tranny lines were installed(OEM).
Ok so I figured out my turboxs tuner was causing the flashing light. Evidently the tcu and ecu communicate. The TCU limits torque taking readings from the ECU. I really need to find someone with a good base tune for a 4EAT.
AT oil temp light flashing chuckles Transmission (AT/MT) & Driveline 53 08-04-2014 10:29 PM
At oil temp light flashing. Auto Gnome Newbies & FAQs 0 10-03-2010 04:51 PM
AT Temp light flashing e30polak Transmission (AT/MT) & Driveline 1 06-04-2008 03:26 PM
AT OIL TEMP Light flashes WorldTour Legacy Forum 5 07-31-2003 03:57 PM
AT OIL TEMP light flashes at startup... BoardRider Legacy Forum 3 04-21-2003 09:31 PM
