Old 11-16-2012, 01:59 AM   #1
xTourniquet
Member#: 177477
2006 WRX Limited
Default What is in my coolant reservoir?
My coolant reservoir has some sort of weird black crap in it, and it is impossible to wash out. Any ideas what it could be?
This substance is covering the whole interior of the tank....
xTourniquet is offline   Reply With Quote
Old 11-16-2012, 06:58 AM   #2
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
Gunk buildup from the cooling system over the years, fairly common.
Old 11-16-2012, 07:14 AM   #3
noside
Member#: 241254
2010 STI
its normal happen to mine after about a year of ownership.
You can get a lot of it out if you just take the res off and blast it with brake cleaner.
noside is offline   Reply With Quote
Old 11-16-2012, 10:59 AM   #4
xTourniquet
Member#: 177477
2006 WRX Limited
Thanks! I didn't know if it was something I should be concerned with or not.
Old 12-01-2012, 08:04 AM   #5
Nereaga
Member#: 339393
Would you suggest a new rad or a flush for this?
Nereaga is offline   Reply With Quote
Old 12-01-2012, 08:44 AM   #6
Boostedbob
Member#: 336241
08 Sti
OPB
I know Subaru puts some weird stuff in the coolant as well, just a heads up I had the same black crap, but I also had oil in my coolant ended up warping my heads with a "blown" HG.
Not saying yours is but just keep it in mind.
Boostedbob is offline   Reply With Quote
Old 12-01-2012, 10:12 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
aw, 1,000,000 whp 2 aw tq
its a plastic part, just rinse it with water, no need for blake parts cleaner.
Old 12-02-2012, 10:06 PM   #8
ZOMBIE RX7
Member#: 213871
2007 WRX TR
UGM
Super common. Just had mine flushed and now it's fine.
ZOMBIE RX7 is offline   Reply With Quote
Old 12-02-2012, 11:30 PM   #9
OK Houston
we have an Uncle
brake cleaner on the wrong things makes them disintegrate
you might have got lucky once.....brake cleaner is NOT an all purpose cleaner and should NOT just be sprayed around like water
Old 12-02-2012, 11:48 PM   #10
esteve
Member#: 28716
2006 STI
Yeah, that's Subaru coolant conditioner/stop leak (aka Holt's Radweld) making a big mess of the overflow tank. Mine looked just like that. If you don't know about it like if it's your first Subaru, then you can easily mistake it for a HG problem or something.
esteve is offline   Reply With Quote
Old 05-16-2013, 04:06 PM   #11
shello007
Member#: 195405
2003 Wrex Wagon
Midnight Blue
Any update on this situation. After cleaning, did the problem return?
shello007 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 04:48 PM.
