Old 10-29-2012, 06:29 PM   #1176
MatrixPooK
Member#: 268609
I know they took way too long Marty but for all the parts we've had custom built these are by far the best fitting least problematic parts yet!
Seems they use 930 Porsche CVs and shafts with custom made flanges...nice!
PooK
MatrixPooK is offline   Reply With Quote
Old 10-29-2012, 06:31 PM   #1177
04trailsti
Member#: 179170
PooK
you just jinx'd it. lol
04trailsti is offline   Reply With Quote
Old 10-29-2012, 06:33 PM   #1178
MatrixPooK
Member#: 268609
Your right! Damn.....
Old 10-30-2012, 06:33 AM   #1179
badermatic
Member#: 295750
2014 TR-82 EXO CAR
Candy red frame/blk body
Congratulations! Those look great. Still waiting on mine.
badermatic is offline   Reply With Quote
Old 10-30-2012, 07:18 PM   #1180
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
What car did the rear suspension parts come from? (wishbones, uprights, etc)
Old 10-30-2012, 10:45 PM   #1181
TheGnome
Member#: 60897
1998 2.5 RS
PooK
Finally!! They look great!!
TheGnome is offline   Reply With Quote
Old 10-30-2012, 11:41 PM   #1182
subuexo
Member#: 297285
pontiac solostice/saturn sky
subuexo is offline   Reply With Quote
Old 10-31-2012, 12:07 AM   #1183
NSFW
Member#: 140444
05 Stage Free LGT
Funny thing is, it kinda looks like the rears on this car might have been the fronts on the donor.
Should make toe-in easy to adjust.
Old 10-31-2012, 08:45 AM   #1184
subuexo
Member#: 297285
you are correct
Old 11-11-2012, 03:37 PM   #1185
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
MatrixPook,
are you using the sky/solstice front knuckles in the rear with the rear sky/solstice wheel bearings? I am curious if they are interchangeable.
Also, did you just have the subaru splines for the tranny and the bearing splines for the pontiac flanged so that you could bolt an axle bar in between?
thanks, looks good.
Ben
PHATsuby is offline   Reply With Quote
Old 11-11-2012, 04:24 PM   #1186
PHATsuby
Member#: 13617
2001 Legacy GT back
I did a little searching and it looks like the rear knuckles also have that "steering knuckle" for a tie rod attachment, so I'm assuming you just used the rear knuckles and rear hubs correct?
Is the upright aluminum or steel?
thanks!
Ben
Old 11-11-2012, 07:08 PM   #1187
roger280zx
Member#: 265665
Looking forward to seeing this thing at the track. No road events? Just Autox?
roger280zx is offline   Reply With Quote
Old 11-12-2012, 08:23 AM   #1188
MatrixPooK
Member#: 268609
thanks!
Ben
Yes, The uprights and hubs are just as they would sit on the Solstice/Sky.
They are aluminum.
PooK
Old 11-12-2012, 08:52 AM   #1189
PHATsuby
Member#: 13617
2001 Legacy GT back
They are aluminum.
PooK
Great thanks for info! Can you comment on the interchangeability of the hubs themselves and the geometry of the uprights.
Basically, I'm wondering if either the geometry of the front and rear are the same minus the brake mounting, or if the front upright will allow the rear hub to bolt into it. I am wondering the best way to design an awd setup around this suspension. I'm not looking to compete with your cars in anyway just FYI, just want to build my own car in the future and you know this information first-hand so I want to ask the source.
thanks!
Ben
Old 11-14-2012, 06:17 PM   #1190
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
Syn Green w/carbon fiber
Default Headlight update
I stopped in and met w/Danny today. After consideration of the Hella projector lights I'd previously bought
we decided that building a custom fiberglass housing for these units (3.25" lense) would end up leaving us with a HUGE piece that was too big for the small frontal area of the car.
So, I ordered a pair of these which are about 4" wide. The housing is metal so that'll be stripped down and powder coated black.
Then Danny will fabricate a mount and install the head lights and move to the back of the car with the installation of the tail lights.
Tomorrow I'll go meet with the guys at TIC to discuss moving the car to them to finish up the wiring and mechanicals. The hopes are that our painter can have the body panels and scoop painted by the time that the car returns from TIC so that it can be completed no later than January 2013.
Hopefully this means that the car build is finally going to progress so my MEH begins to fade away.
hipowernut is offline   Reply With Quote
Old 11-14-2012, 07:36 PM   #1191
subuexo
Member#: 297285
are those dot approved ? where did you find them? they are a variation of the units used on the razor.
Old 11-14-2012, 07:45 PM   #1192
PHATsuby
Member#: 13617
2001 Legacy GT back
You decapitated Johnny 5!
JK, I think they look cool
Ben
Old 11-14-2012, 08:12 PM   #1193
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
Doubt they are DOT stamped - I'm just going to roll the dice at this point.
Got them here -
http://www.ebay.com/itm/200822602950...84.m1439.l2649
Don't think they are related to the razor units other that they are also a side by side design.
Not my first choice. I also thought about E.T. and Johnny 5 but I knew I didn't want 5" round frog eye lights or paying $$$ to have someone design me some one-off HID units that would take 6 months (or longer with my luck).
Old 11-14-2012, 11:20 PM   #1194
superhawk44
Member#: 20264
05 LGT arrestmered
07 Aprilia Tuono
Wall-e.
superhawk44 is offline   Reply With Quote
Old 11-15-2012, 02:40 PM   #1195
ScubyPhilly
Member#: 213303
2009 Impreza 2.5i
ScubyPhilly is offline   Reply With Quote
Old 11-15-2012, 05:18 PM   #1196
badermatic
Member#: 295750
2014 TR-82 EXO CAR
Nice headlamps! I will be going that route as well once the vehicle is registered.
Pook - Did you have any difficulty putting on the Solstice axle spindle nut after installing the drive shaft shop axles?
Old 11-15-2012, 06:36 PM   #1197
MatrixPooK
Member#: 268609
No, The splines are tight!! Semi press fit same as the Solstice.
You have to put some anti seize on them then use the nut to pull the shaft into the hub.
Air tools or a big breaker bar.
Pook
Old 11-16-2012, 07:57 AM   #1198
badermatic
Member#: 295750
2014 TR-82 EXO CAR
Yes. I did have some difficulty pulling the splined ends through the hub, as well. The splines were definitely tight. But after a little blood, sweat, and a little muscle I got them though and they mated well. My issue is the thread on the axle & its interaction with the nut. They don't seem to want to play nice.
Sorry to hijack the thread.
Old 11-16-2012, 08:56 AM   #1199
MatrixPooK
Member#: 268609
Oh, Very sorry.
The nuts they sent with the axles threaded right on. maybe a bur on the threads of the flange shaft?
If thats the case they sell a thread file, you pick the pitch and file out the bur (may have to call Drive shaft shop unless you have a pitch gage out of a tap and die set.
PooK
Old 11-16-2012, 09:02 AM   #1200
MatrixPooK
Member#: 268609
thanks!
Ben
No problem, The geometry between the front and rear uprights is exact, The ONLY difference is the lugs to mount the calipers.
The neat part is the hubs have only one part number for the whole car. there is no difference between front/rear/right/left. They are pre-loaded so no need for a stub shaft to hold the bearings together on the fronts but are splined and just waiting for a 4wd setup IMHO!
PooK
FS: 2003 EVO 8 Track/Street car. bhhamblin RMIC Private Classifieds 11 02-20-2010 12:37 PM
Better Track/Street Car E36 M3 or WRX? dpspeed Motorsports 71 05-20-2008 11:04 PM
WTT: M3 Track/Street Car redefinedWRX Private Vehicle 'For Sale' Classifieds 17 11-28-2007 04:54 PM
Anyone have a 06 wrx? not TR Dszerox Mid Atlantic Impreza Club -- MAIC 14 05-02-2007 09:57 AM
I want to trade my 06 STI Black Trunk for an 06 WRX or TR trunk in the socal area skubydew16 Private 'Wanted' Classifieds 0 07-25-2006 09:37 PM
