Old 11-12-2012, 10:44 PM   #76
3mlwhly
Member#: 217648
01 2.5rs
nice!!!
3mlwhly is online now   Reply With Quote
Old 11-13-2012, 08:54 AM   #77
lgt2000
Member#: 140073
2005 LGT
Red
Thanks guys. We are hoping to finish building the subframe this week and start working on the transmission mounting
lgt2000 is offline   Reply With Quote
Old 11-15-2012, 12:00 PM   #78
TyConway
Member#: 193189
02 wrx
id suggest throwing a throttle body on the intake manifold, from what it looks like, the engine is too far forward, your gonna have hood clearance issues/ and no where to run a cold air intake without interfering with the radiator.
TyConway is offline   Reply With Quote
Old 11-15-2012, 02:07 PM   #79
lgt2000
Member#: 140073
2005 LGT
Red
I will have to check that out. Still waiting on my LS2 TB but the engine is sitting as far back as it can, the only modification I could do would be to drop it down. My plan is to run a right angle silicone couple out of the TB and then run a pipe toward the drivers side fender
Old 11-15-2012, 02:07 PM   #80
lgt2000
Member#: 140073
2005 LGT
Red
Also I am going to cut the hood and weld on a bump similar to 07-08 350z so that I have clearance
Old 11-15-2012, 07:54 PM   #81
TyConway
Member#: 193189
02 wrx
ahh dont cut the hood... Just from the first pics, looks like it can go back 3 inches easily. But its a chore putting a v8 in any Subaru . I know i moved mine as far back as possible, even my gear shifter lines up ( t56 out of a camaro) doesn't have the adapter to move the shifter to the rear. Even with mine as close to the firewall as possible, its still tight on my radiator, just have a 1/4 of clearance from the crank pulley to the radiator fan shrouds.
Old 11-16-2012, 10:01 AM   #82
lgt2000
Member#: 140073
2005 LGT
Red
I see what you are saying and will have to snap some pics for you so you can check it out and make some recommendations.
Right now the drivers side head is about 3/8" from the clutch master so that would have to be relocated and once you get that close there could be brake booster interference as well.
I am also running cts-v accessories which if I remember correctly are about 3/4" closer to the block than f-body accessories
Old 11-17-2012, 09:11 PM   #83
lgt2000
Member#: 140073
2005 LGT
Red
Did some more work on the subframe today. Will probably pull it out after thanksgiving to finish reinforcing it and paint it. We also threw in the stock radiator and fans and mocked up the water pump and the pictures below show that there is plenty of space in front of the motor
Old 11-21-2012, 01:03 PM   #84
gioioi
Member#: 288236
wow, nice
gioioi is offline   Reply With Quote
Old 11-21-2012, 04:44 PM   #85
TyConway
Member#: 193189
02 wrx
which clutch master cylinder are you going to run? Im gonna have to modify my firewall for a custom mount to move mine back just a little bit for a wilwood. My stock one fits barely. But im not sure if its gonna work for a pressure plate rated to hold 750 ftlbs of torque. But you should have any brake booster interference.
Old 11-21-2012, 11:40 PM   #86
lgt2000
Member#: 140073
2005 LGT
Red
I have not decided on a clutch master just yet but am measuring by the stock one and the corner of the cylinder head sits about 3/8" away from it now.
Old 11-28-2012, 09:35 PM   #87
TyConway
Member#: 193189
02 wrx
what did your water pump come off of? notice the pulley is skinny and the water outlet is in a different place...
Old 11-29-2012, 10:00 PM   #88
lgt2000
Member#: 140073
2005 LGT
Red
Its from an ls3 crate engine. There is a seller on ebay that has them all the time for around $100. It lines upvwith ls3 corvette or cts-v acessories. It sits alot closer to the block than the f-body acessories
Old 11-29-2012, 11:40 PM   #89
TyConway
Member#: 193189
02 wrx
yea i realized after i asked you, may have to round me one up... but realized my front drive setup (corvette) isn't going to work with the harmonic balancer (ls1), spacing is different... Just love finding out I have to spend more money.
Old 11-30-2012, 01:32 AM   #90
lgt2000
Member#: 140073
2005 LGT
Red
Old 12-01-2012, 09:37 PM   #91
TyConway
Member#: 193189
02 wrx
I was gonna run the corvette front drive kit, but the alternator hits my coil pack since im using holly valve covers, and also my harmonic balancer doesn't align with that drive system as well. gonna go with ls1 front drive setup now.
Old 12-02-2012, 09:36 AM   #92
lgt2000
Member#: 140073
2005 LGT
Red
Yeah, I can understand where you are coming from. We have spare brackets and pulleys just for that reason because we tested a few different combos
Old 12-02-2012, 09:38 AM   #93
lgt2000
Member#: 140073
2005 LGT
Red
Old 12-04-2012, 03:00 AM   #94
TyConway
Member#: 193189
02 wrx
You need a stand alone harness... got a guy local to me that builds them. All new wire and connectors... can't beat the price and we use them at the restoration shop that we help out when doing lsx swaps in old cars. I'll pm you.
Old 12-26-2012, 11:48 PM   #95
cruzanspeed
Member#: 160141
07 APS SS45 wrx
SRR (repaint)
Nice Build!!!
cruzanspeed is offline   Reply With Quote
Old 01-11-2013, 09:56 PM   #96
lgt2000
Member#: 140073
2005 LGT
Red
Thanks, sorry for no updates, took a little break for the holidays but will be back soon
Old 01-12-2013, 01:18 AM   #97
TyConway
Member#: 193189
02 wrx
soundling like me... subarus and lsx swaps take some time!
Old 01-20-2013, 11:47 AM   #98
army21b
Member#: 228116
2008 FXT Sports
AW
sub'd!
army21b is offline   Reply With Quote
Old 02-12-2013, 08:27 AM   #99
lgt2000
Member#: 140073
2005 LGT
Red
Sorry for the lack of updates guys. I have been moving into a new shop so a lot of tools and parts have been packaged up.
We did manage to make a lot of progress on the subframe and steering rack mounts. Below you will see a picture of the rack mounted in the subframe with the steering rack moutn and brace seeting upside down on the mockup motor.
You will also see the steering rack mount complete and painted and the subframe about 90% complete. We still have to add a few reinforcement pieces to the subframe this week and then it will be painted and in the car.
Old 02-12-2013, 08:35 AM   #100
lgt2000
Member#: 140073
2005 LGT
Red
Message Board Statistics All times are GMT -4. The time now is 09:35 PM.
