Old 11-14-2012, 11:50 PM   #1
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Default swapping Ring and Pinion questions for 6 speed swap
So I am doing a 05 USDM 6 speed swap into a 03 WRX and planning on keeping 03 hub and axles for now.
So I need to swap the 3.90 ring and pinion from a R180 I have into a R160 replacing the 3.54 along with the flange to Drive Shaft.
This is from a R160 that I swapped out due to spider gear whine. Just in case I beat it up. Disassembly was actually pretty easy. Gear puller to get flange off, bearing stays popped right off and I whacked out the pinion gear with a rubber mallet.
So the question is if I use only the ring and pinion gear from the R180 put it in the R160 and put everything back together in the same fashion it came out the preload on the bearings will stay the same right? Or will the Backlash be off? I am not planning to change anything but the ring and pinion.
Here is the R160 disassembled.
There isn't any info on doing this anywhere. We need to get some info up.
Old 11-15-2012, 05:36 AM   #2
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Originally Posted by sackytar View Post
So I need to swap the 3.90 ring and pinion from a R180 I have into a R160 replacing the 3.54 ......There isn't any info on doing this anywhere. We need to get some info up.
Because the ring and pinion swap is not possible due to parts incompatibility.
/close
JarHarms is offline   Reply With Quote
Old 11-15-2012, 07:23 AM   #3
sackytar
Member#: 149262
PrimerGrey
Really. Are the ring gears different sizes?
Old 11-15-2012, 07:33 AM   #4
d0000000000000d...just find the right rear end and stop screwin around
Old 11-15-2012, 08:00 AM   #5
sackytar
Member#: 149262
PrimerGrey
And now I see says the blind man. Physically different All together.
Mods please delete this black hole of a thread!
Old 11-15-2012, 11:46 AM   #6
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
There are 3.9:1 Ring and pinion gears from other R160's that you could swap in to your existing diff though.
And you have all ready done about half of the work, so that might be something else to consider...
FlatironsTuning.com is offline   Reply With Quote
Old 11-15-2012, 11:55 AM   #7
sackytar
Member#: 149262
PrimerGrey
Funny I was on your website today looking at aftermarket lsd units. The duffs spider gears are hit up. But I have one in the vehicle now though. If I could just find some ring and pinion gears for an r160.
Old 11-15-2012, 06:27 PM   #8
there are a few diffferent cars that had the 3.90 gears...find out which ones and find one in a boneyard and
Old 11-15-2012, 09:52 PM   #9
some dude
Member#: 100300
06 WRX
Look at all that T6 in the background. Yummmmy.
Old 11-16-2012, 11:27 AM   #10
sackytar
Member#: 149262
PrimerGrey
Man I have been researching every crap hole of a junk yard in a150 mile radius. No luck.
I will be at 3 different LKQ self serves all day tomorrow. Looking. Of course they do not inventory cars or parts in the lot.
T6 is all used!
Old 11-18-2012, 09:11 AM   #11
DCCDPro
Member#: 227549
Look at older Legacy diffs, many of those were 3.90.
DCCDPro is offline   Reply With Quote
Old 11-25-2012, 10:02 AM   #12
sackytar
Member#: 149262
PrimerGrey
Found an older legacy diff. Now I need your controller!
