#1 |
Member#: 278236
International
Vehicle:'06 sti varies with the seasons |
I have an 06 STI that I bought modded from the previous owner. It is currently tuned to 21 psi and uses a MBC for boost control. My question is, is it safe to turn the boost down to say about 18 psi by adjusting the MBC, or would I also need to get the car tuned again since the current tune is set to 21 psi?
#2 |
Member#: 274499
NESIC
Vehicle:2007 CGM VF'd WRX 12.9 @ 105mph |
You'll be fine, just turning it down.
#3 |
Member#: 311781
Vehicle:2003 WRX w STI V8 |
lower away, it can only get safer.
#4 |
Member#: 278236
International
Great, just what I was hoping for. Thanks for the help guys.
#5 |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
Depends on who tuned it.. In some cases tuners only do it for a small variance of 1-2 psi.... unless they tuned it for stages like 10,15,21 psi then you could hit AFR's that arent desirable as well as too much/too little timing.
#6 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Some tuners just set the car to target boost and get the car running correctly there, while the other parts of the table haven't been touched. Lowering the boost could throw you into an untuned region of your map, if so then anything could happen...too much timing, too little timing, too much fuel, too little fuel, etc. If the car was tuned properly for all conditions up to and including the final target boost, then you'd be fine, but there's no guarantee that it was. |
#7 | |
Member#: 311781
#8 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
Just for the record: Tuners who don't tune for part-throttle suck at their job.
Cars that can't run safely at part-throttle are time bombs. |
#9 |
Member#: 51961
RMIC
#10 |
Member#: 140444
NWIC
I don't doubt it.
#11 |
Member#: 159743
Quarter throttle and full throttle with less boost are different stories though :-) whats fun is tuning the newer STI's and setting up different boost maps for I, S and S# then having to tune it all those times. But when its done... holy crap does it make it fun :-)
#12 |
Member#: 140444
NWIC
#13 | |
Member#: 274499
NESIC
Seems like it would make a difference to me. |
#14 | |
Member#: 268354
NESIC
Vehicle:02 WRX 05 LGT Slow Automatics |
I personally havent noticed a measurable difference, but in theory the two conditions would be slightly different from one another (more heat and pumping loss at higher boost, lower throttle). |
#15 |
Member#: 159743
If you turn down the boost say 2psi or 3psi to run it "safer" you might go from hitting the normal 3.5 down to a peak of 3 now. at half throttle you may only see the 2 load range... i think they are different in tuning... when i think of 1/4 thorttle i think of just barely in boost... my setup may be different then others but... that's all i ment. We are all agreeing here anyways. :-)
#16 |
Member#: 278236
International
Thank you guys for all the great information. I decided that I will just leave it alone for now use my foot to control the boost. Although, I will slightly be adjusting it lower since its getting colder, thus causing the boost to creep up slightly.
#17 | |
Member#: 140444
NWIC
Obviously if the load is different, that matters. That's not the point.The point is that the very same boost levels (and the load cells) that you get at part-throttle can be achieved at WOT if you play with WGDC or an MBC. And I don't see why you'd need to retune for the difference. If I remember right, WOT pulls at 30% throttle give me exactly the same boost as WOT pulls at 100% throttle and 0% WGDC. I actually did some experimentation to figure that out, because I figure it doesn't matter what the WGDC is boost levels lower than whatever you get with 0% WGDC, or at throttle levels lower that whatever it takes to make that much boost. |
#18 | |
Member#: 274499
NESIC
Methinks this statement needs a revision. |
#19 |
Member#: 51961
RMIC
#20 | |
Member#: 321715
Tri-State
Vehicle:03 WRX PSM |
#21 |
Member#: 140444
NWIC
WOT pulls at 30% is, um, wrong.
I just meant "pulls" at 30% throttle. Or, 30%OT pulls, I guess? I got curious one day, and revised my DBW tables to cap them at progressively lower throttle openings until I got down to WG boost levels, and 30% was it. So with my foot to the floor, the throttle plate went to 30%, and I got 10 or 11 psi, which is the same boost I get with WOT (really WOT this time) and 0% WGDC. That's with an ATP 3076 and the IWG and actuator that it came with. I'm sure it would vary with different turbos and WGs and WG springs. Am I making sense yet? |
