Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 11-09-2012, 06:02 PM   #2076
sc00by4life
Member#: 97135
Originally Posted by Slow Scoobie View Post
What kind of fender mods will I be looking at with a 17x9 +25 or +35 offset wheel? On a 08-10 body style sedan With a 235/45 tire.
roll all around, pull depending on height. not to mention the suspension modification needed to get away with minimal fender mods.
both of those offsets are too low for that wheel on the narrowbody.
Old 11-09-2012, 07:24 PM   #2077
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Thanks for the info man, but I forgot to mention im on coilovers if that affects anything.
Slow Scoobie is offline   Reply With Quote
Old 11-09-2012, 07:55 PM   #2078
sc00by4life
Member#: 97135
which means it'll take even more work if you are low.
you'll need rear lower control arms to get enough camber adjustment.
Old 11-09-2012, 08:19 PM   #2079
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
You know it lol...Damn im looking at the 17x9 grids, I want to keep the wheel face as concave as possible, but if gonna need to change out control arms I rather get somthing with a higher offset. Whats the lowest offset you think I could get away with to keep the face concave?
Old 11-09-2012, 08:46 PM   #2080
sc00by4life
Member#: 97135
the +42 grids have the same face, pretty sure they are offered in 5x100 as well.
You'll still need to roll all around with a 235/40, but should be a little bit more "plug and play".
Old 11-09-2012, 08:57 PM   #2081
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Thanks for all the help. Luckily though I had all 4 fenders rolled previously for my current wheels. Just the new wheels are 1.5inchs wider with a different offset so I just wanted to consult a knowledgeable person.
Old 11-15-2012, 11:03 AM   #2082
GYR0
Member#: 303517
2011 WRX Ltd. Sedan
SSM
Looking to pick up some snow tires for my stock '11 WRX:
17" diameter
7" width
5x100
42 offset
With 225/45R17 tires.
Thoughts?
Thank you!
GYR0 is offline   Reply With Quote
Old 11-15-2012, 01:14 PM   #2083
Suboto
Member#: 81981
2005 WRX Wagon
I could use some help. I'm doing a STI Brembo to 05 WRX wagon swap. The wheels i have are the Rota SDR +53 wagon fitment wheels. Will these wheels work? I've read the wagons have a different hub than the sedans so I'm confused about the offsets. Thanks,
Suboto is offline   Reply With Quote
Old 11-15-2012, 03:51 PM   #2084
sc00by4life
Member#: 97135
17" diameter
7" width
5x100
42 offset
Thoughts?
Thank you!
225 is too wide for those wheels. 205/50/17 and done.
are you doing ONLY the brembo conversion and keeping the 5x100 hubs? sedan and wagons have identical hubs, but different length arms/links/sways that connect everything.
if you're doing a brake swap, the only thing you need to worry about is if the wheels will clear the brakes. Otherwise they will fit just like they do now.....
Old 11-15-2012, 05:00 PM   #2085
rallyracersti
Member#: 147522
2015 wrx
Wrb
i found this website rimsntires.com/specs.jsp
rallyracersti is offline   Reply With Quote
Old 11-16-2012, 11:33 AM   #2086
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Umm, no.
Perhaps you mis-read what he said, but 225/45 is not too wide for 17x7.
Maybe you just meant it's not preferable because of the advantages of a narrower snow tire. I'd probably prefer the 205/50 for a snow, but 225/45 fits and works just fine
Breezio is offline   Reply With Quote
Old 11-16-2012, 12:19 PM   #2087
GYR0
Member#: 303517
2011 WRX Ltd. Sedan
SSM
Thanks. Would I run into any issues with the wheels fitting? From the info at the beginning of the thread it looks like its outside of the sweet spot..
Old 11-16-2012, 12:43 PM   #2088
Suboto
Member#: 81981
2005 WRX Wagon
I am keeping the 5x100 hubs, just adding the brembos. Will a +53 offset wheel clear a bremboed wagon? Im confused over it. Read that the same Rota SDR +53 wheel will not clear a STI sedan but the Rota SDR +48 will. Should I use a 5mm spacer?
Old 11-16-2012, 12:46 PM   #2089
sc00by4life
Member#: 97135
Originally Posted by Breezio
Umm, no.
225 is a bit pinched on that size. Sure it fits, but it ain't ideal.
Old 11-17-2012, 12:49 AM   #2090
Breezio
Member#: 234357
2009 WRX
You have a 3g'rd gen widebody, the info at the start of this thread doesn't really pertain to your car.
I don't know for certain, but I can't imagine +42's with 225's having any issues on a widebody. I have 235's on +45mm wheels without any issues on a narrowbody.
It is certainly at the limit in my book, but it's also the OEM size. *shurg*
Old 11-18-2012, 03:33 AM   #2091
ryangrz18
Member#: 316342
2009 2.5i
pearl white
ok guys been reading these forums for a bit now trying my best to
get a clear answer but still not sure. was told from a dealership that
the 045 msr 18x8 5x100 35 offset with 225/40 r18 tires would fit my
2009 impreza 2.5i. no alterations n hoping not to. is this gonna work?
thnx. ryan
ryangrz18 is offline   Reply With Quote
Old 11-18-2012, 01:19 PM   #2092
Breezio
Member#: 234357
2009 WRX
My understanding is that you could (would?) rub in the rear with that setup. Might depend on what tires you went with. I'm not sure, You might want to ask around in the 08-10 narrow body wheel thread.
Old 11-18-2012, 01:35 PM   #2093
ryangrz18
Member#: 316342
2009 2.5i
pearl white
ok thnx
Old 11-18-2012, 08:47 PM   #2094
GYR0
Member#: 303517
2011 WRX Ltd. Sedan
SSM
Awesome. Thanks for the info!
Old 11-25-2012, 08:18 PM   #2095
Afrobandit
Member#: 322141
2012 WRX
WR Blue
I have the 2012 wrx, my winter wheels i just bought are 215/60/R16 wheels from a forester. My stock rims say 52 (instead of the expected 53) on the backside of the rim. So I have a 17x7 (offset +52 or +53) and i am switching to a 16x6.5 with a +48 offset. I dont appear to have any rubbing issues, but does this sit savy with the wheel bearings, or is that stressing them to much?
Afrobandit is offline   Reply With Quote
Old 11-26-2012, 04:05 PM   #2096
sc00by4life
Member#: 97135
That'll be really close to the spring perch....
Old 11-27-2012, 12:03 AM   #2097
Breezio
Member#: 234357
2009 WRX
Ruffly .6" an inch taller then stock... Certainly is a pretty tall tire.
With them being narrower and a few mm's farther out on offset. Tuff to say on the spring perch as sc00by said.
Though there is no need to worry about the wheel bearings.
Old 11-27-2012, 02:35 AM   #2098
Afrobandit
Member#: 322141
2012 WRX
WR Blue
thanks guys!
Old 12-03-2012, 09:58 PM   #2099
subi21
Member#: 338346
2010 Wrx
I have a stock suspension 2010 wrx and was looking at getting some 18x8 or 9.5 with a 35mm offset. Would It fit as of now? I'm looking at lowering it one some teins in the near future.
subi21 is offline   Reply With Quote
Old 12-03-2012, 10:09 PM   #2100
sc00by4life
Member#: 97135
those are some big differences. and you didn't list offsets. or desired tire size.
stock suspension? you wont get 18x9.5's to work without some form of fender modification or stupid stretch (which looks retarded if you arent fender on rim low).
research more. seriously. you need to.
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 07:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 05:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 09:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 09:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 03:59 PM
