Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 11-15-2012, 07:21 PM   #1
Warlo3k
Member#: 325957
2012 WRX Sedan
Default 2012 WRX ECUFlash Newbie, need help...
This is my first time with open source tuning. I figured I would start with just learning to use the software. I can not get ECUflash to read my ecu, and I have lost hope with figuring it out on my own. P.S. Logging works fine.
Heres what I have done:
Installed ECU flash
Made a folder in the "C:\Program Files\OpenECU\EcuFlash\rommetadata\subaru" folder called Impreza 2012 WRX
Put this file "2012UsdmWrxMt-AE5K500L_v1" from http://www.romraider.com/forum/viewt...hp?f=34&t=8053 and also replaced the base32bit in the base folder with the one specified in the thread.
I plug in the Openport 2.0 to the OBD port and my USB port
I click on 'Read"
I select 2007+ Can Subarus
I make sure the car is to on, but not started, and click ok
I get this:
[18:08:21.465] J2534 API Version: 04.04
[18:08:21.465] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[18:08:21.465] Device Firmware Version: 1.11.3298
[18:08:33.412] kernel get version
[18:08:33.642] SSM2 init
[18:08:33.672] SSM2 ECU ID is FFFFFF81 12 58 50 07
[18:08:33.682] Requesting Seed...
[18:08:33.692] Sending Key...
[18:08:33.702] interface close
[18:08:33.712] interface close
for the love of god what am i doing wrong.... Thanks for the help
Warlo3k is offline   Reply With Quote
Old 11-16-2012, 11:41 AM   #2
Warlo3k
Member#: 325957
2012 WRX Sedan
Update: I think I may have figured it out. I have an access port pro tune installed on my ecu. It's probably locked the ecu from being read.
Old 11-16-2012, 02:58 PM   #3
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 480whp 468wtq
that would be it
freddy121389 is offline   Reply With Quote
Old 12-12-2012, 09:58 PM   #4
OneLostFellow
Member#: 338960
so how do you unlock it
OneLostFellow is offline   Reply With Quote
Old 12-12-2012, 10:06 PM   #5
Warlo3k
Member#: 325957
2012 WRX Sedan
You cant read an ECU thats been tuned by an accessport. People would steal the maps otherwise. You would need to install the stock rom to be able to read the ECU.
Old 12-12-2012, 10:14 PM   #6
OneLostFellow
Member#: 338960
other then getting that same message. How else do you tell if it been tuned? with the car off, my tuner port just runs thru the colors
Old 12-12-2012, 10:15 PM   #7
Warlo3k
Member#: 325957
2012 WRX Sedan
What year do you have? Does connecting the green test mode connectors apply to your year?
Old 12-12-2012, 10:18 PM   #8
OneLostFellow
Member#: 338960
2011 wrx
Old 12-12-2012, 10:22 PM   #9
Warlo3k
Member#: 325957
2012 WRX Sedan
Did you install the ecu definitions for the 2011 WRX into ecu flash?
Old 12-12-2012, 10:24 PM   #10
OneLostFellow
Member#: 338960
believe so
Old 12-12-2012, 10:26 PM   #11
OneLostFellow
Member#: 338960
followed all the instrucitons
Old 12-12-2012, 10:26 PM   #12
OneLostFellow
Member#: 338960
and all i get is the same thing as above
Old 12-12-2012, 10:27 PM   #13
Warlo3k
Member#: 325957
2012 WRX Sedan
That would be my guess either the definitions are not properly installed or you have a tune on your car that locks the ecu.
Did you buy your car used? Otherwise you would know what tune would be on your car. If it was pro tuned, I have heard some pro tuners still lock the ecu with an open source tune.
Old 12-12-2012, 10:32 PM   #14
OneLostFellow
Member#: 338960
thats what im thinking also, i bout it used
Old 12-13-2012, 10:19 AM   #15
Warlo3k
Member#: 325957
2012 WRX Sedan
A real easy way to tell, almost all pro tunes, including accessport, raise the fuel cut of the car. Can you car rev to 7k rpms? If so, you have a tune on your car. The car can only rev to I believe 6250 or 6500 factory. Do a pull in your car, if you can go into the redline, your tuned and your ECU is locked because of it.
Old 08-08-2013, 10:53 AM   #16
jlotz22
Member#: 364751
Anyone know of any stock maps? could only find one and its in metric?
jlotz22 is offline   Reply With Quote
Old 08-08-2013, 11:03 AM   #17
jlotz22
Member#: 364751
i mean definitions* thats what should determine if its in standard or metric?
Old 08-08-2013, 11:13 AM   #18
mbhammerbro
Member#: 344521
2013 STi
So you have an accessport protune but no accessport?
mbhammerbro is offline   Reply With Quote
Old 09-10-2013, 12:29 AM   #19
leemwalls
Member#: 325396
2014 WRX Hatch
WR Blue
I'd try uninstalling ecu flash reinstall from scratch and see how it works.. I've had to go about it that way.. start fresh.
leemwalls is offline   Reply With Quote
