#2526 |
Street's closed, pizza boy
Member#: 17301
MAIC
Vehicle:is the "dark side" 06 Evo #7 STU, 05 Saabaru |
Runway courses, not quite as fun in a boost buggy.
#2527 |
Member#: 192173
Vehicle:2006 STU prepped STi Sponsored by Agile Auto |
The course wasn't that bad, just not good for PAX. And it was bad in an Evo STU car with stock Recaros. Subies have cruise control and I have Sparco Evo seats. Win and win.
![]() Thanks John! *looks at flights to Austin* |
#2528 |
Member#: 17301
MAIC
#2529 |
Member#: 234424
Vehicle:2004 Evolution Black |
.... EVO... w/ Cruise control...
http://forums.nasioc.com/forums/show....php?t=2401426 "Best.... Mod...... Ever.." ~ Simpsons comic-book-guy ![]() |
#2530 |
Member#: 172670
South East
Vehicle:2011 STI 5-door 2013 F150 Ecoboost |
.846? Who's starting the group buy on rape kits?
#2531 |
Member#: 192173
Show up with the cruise control mod and I'll protest you...just saying.
![]() I haven't seen the PAX adjustments, but did we move up more or less relative to the average? |
#2532 |
Member#: 90357
Tri-State
Vehicle:2006 Corey's EVO & 1993 Mazda RX7 |
Thanks bdi. Nice running with you again Josh. If you're feeling crazy, there is a Meadowlands race Sunday Nov 18.
#2533 |
Member#: 70634
Moved up more than average. See Brian's chart in the pax thread. We need an STU group buy on steaks and Hoosier hats to send to Rick. I heard it worked for the BSP guys...
#2534 |
Member#: 192173
Yeah, I've seen the chart since then. Not sure what we did wrong. Only thing I can think of is that Bryan's performance in STX makes him believe that in theory STU in an M3 should be relatively faster than STX? And not sure how BSP got a gift seeing as they were faster than SM. Whatever, it is what it is.
#2535 |
Member#: 230741
Vehicle:06 STI OBP |
I think the ES Chicago boys paid off Rick too!
#2536 |
Member#: 330833
Vehicle:04 WRX silver |
I recently got an 04 WRX, and have started autocross this season. The only mod that pushes my car into the STU class are 17x9 wheels, otherwise it seems to me I will always be outclassed by the STIs and EVOs. Does anyone have an opinion as to whether I would be better off trading the wheels (RFP1s) to go down to STX? Thanks,
Barry |
#2537 |
Member#: 23954
TXIC
Vehicle:06 STI FTW '11 Legacy 3.6R |
Definitely get 8" wheels and move to STX.
#2538 |
Member#: 147776
NWIC
Vehicle:'02 Impreza WRX '85 Toyota Corolla |
Hey guys, have a tire size question.
I have an ESP prepped WRX, and mainly run in local events in road tire classes, as I don't have the means for r-comp tires yet. Since you guys typically run 17x9 wheels and are limited to street tires, I thought this area would be more appropriate to ask. Since I'm in ESP, I'm also on 17x9 wheels. I tend to stick with star specs as a great all round aX tire for my climate. Which size Dunlop star spec would you go with? 245/40 (actually didn't see this size on tire racks site), 245/45 or 255/40? Maybe even wider? The 255/40 is wider, but the 245/45 is taller... keep in mind, I have a 5 speed. Thanks |
#2539 |
Member#: 197920
MWSOC
Vehicle:2005 Legacy GT ABP |
245 is the limit for AWD cars in ST* classes.
Most of us run 245/40 Starspecs or RS3's. Tirerack has discontinued the Direzza Starspec I and will be introducing the Starspec II early next year. You'll be in STX by the way being a WRX |
#2540 | ||
Member#: 141991
MWSOC
Vehicle:08 STi AW 06 Saabaru 2.5i |
I would run as wide and small (diameter) tire as possible. A 9" wide wheel is plenty wide to handle a 265 or wider, but you may run into clearance issues. Since you are in ESP though, I believe you can modify your fenders for tire clearance...so go nuts. A smaller diameter tire will also help with the tall gears of the 5 speed. |
#2541 |
Member#: 147776
NWIC
Correct, that's what I'm asking.
What about sidewall strength? Wouldn't it be better to have a slight stretch on street tires to strengthen them up? |
#2542 | |
Member#: 141991
MWSOC
But I think that a wider tire will yield you a larger contact patch, thus better grip (and allow for faster times). I'm sure you could calculate the break even point between a wider tire that provides more grip vs the slight loss of response. You could create a test to show how the variables (contact patch and responsiveness) have an effect on the result (time). Without actually coming up with metrics and testing this, my (slightly educated) guess would be that more contact patch and subsequently more grip will allow for fast times when compared to a slightly more responsive tire. Alternatively, a proper sized tire for a 9" wheel will provide the best of both worlds (contact patch and responsiveness). I believe tire rack (and searching here on nasioc) will provide you with the best tire width for a 9" wheel. Keep in mind that the size can vary by manufacturer (Star specs typically run wide). |
#2543 |
Member#: 147776
NWIC
I've ran 245/40 and 255/40, but I changed alot on the car (suspension, diff, engine, steering rack, ...) before switching to 255s, so I couldn't tell you if I felt a difference...
Not sure if I should stick with 255, go back to 245, or try 265 or larger... However, it looks like they might not even make the new Z2 in a 265 size... |
#2544 |
Member#: 215344
MWSOC
Vehicle:2004 STU STi Sponsored by TiC! |
Get two sets of wheels.. 255's on one set.. 245's on the other..
![]() The 265 Z1 Star Specs almost seemed too fat for 17x9's IMO. |
#2545 | |
Member#: 141991
MWSOC
However, autox is a game of tenths of seconds, so we generally try for all we can get Yazel - I'm running 265 Federal RSR's on my 18x8.5's and they seem to fit fine. Star specs do run wide tho... |
#2546 | |
Member#: 147776
NWIC
I might not even have an option of 265 if I stick with Dunlops... I'll have to wait and see when they are released. |
#2547 | |
Member#: 215344
MWSOC
Lol I know. Hence the wink face! But yea I think I remember seeing that expected sizes chart for the Z2 and no 265 under the 17" category. |
#2548 | |
Member#: 208152
TXIC
Vehicle:2007 STI LTD #576 Urban Gray Metallic |
#2549 |
Member#: 234424
I ran 255/40 in SMS locally one year (Street mod street tire) then went to STU in 2011, same wheels, but 245/40 Z1s.. incredible difference, and speaking with a tire tech with Goodyear (Dunlop parent company)... the 255 uses a different carcus and compound than the 245. sizable weight difference too if you notice. (3-4lbs/tire).
Don't ask specifics of the difference, I have known and trust the guy a while, so I didn't dig for every last detail. ![]() |
#2550 |
Member#: 147776
NWIC
Are you saying you liked the 245 or 255 better?
That's interesting, because the wear I saw from the 255 was a bit different looking than the 245... the 255s started to look like used hoosiers towards the middle of the season, and I want to say they didn't last as long. |
| Thread Tools | |
| Display Modes | |
| Air Force Guys Check-in (other branches welcome) | joosrsx | Off-Topic | 293 | 05-01-2010 10:36 PM |
| northwest connecticut guys check in | 09wrxtorrington | New England Impreza Club Forum -- NESIC | 6 | 08-12-2009 02:46 PM |
| New Guy Checking In | mmormino | Newbies & FAQs | 3 | 02-14-2009 12:07 PM |
| New guy checking in | amfj231 | Newbies & FAQs | 7 | 12-22-2008 09:13 PM |
