Old 11-15-2012, 04:42 PM   #26
Leafy
Member#: 330625
2006 WRX
On the ebay DP topic, my godspeed cam with the rear o2 bung threaded cockeyed and the rear flange doesnt sit flat with my mid pipe flange. I've properly turned off the rear fuel trims so I'm just not using the rear o2. And I just welded in my own bung for a wideband. Still need to fix the flanges.
Old 11-16-2012, 06:18 PM   #27
j_schmitt
Member#: 338084
1999 Honda
Civic
Seems like it would be a waste of money to get a 2.5" when you could get a 3" right away. Wouldn't the 3" give you better performance?
j_schmitt is offline   Reply With Quote
Old 11-17-2012, 11:10 AM   #28
be0tch
Member#: 66206
2005 WRX STi
Unless you're making a lot of horsepower (a lot!) 3" exhaust is more than you need.
I'm talking 450+hp, and maybe even then, you don't need to have a 3" exhaust.
be0tch is offline   Reply With Quote
Old 11-17-2012, 12:06 PM   #29
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Originally Posted by 04ScoobyWtf View Post
You can get a Catless downpipe for 70 on eBay. I got one and it sounds awesome and cheap
I bought one of these just to check it out and they are poorly made. They require alot of work to fix the flow path. where the bellmouth welds to the downpipe there is just a hole and it doesn't flow smoothly into the pipe.
Old 11-17-2012, 01:04 PM   #30
Sir Tolik
Member#: 268015
2007 Subaru WRX STi
Blue mica
Thank you for the replies. I am aiming for a 3" DP. But I just did not want to spend 400$ for a piece of pipe (actually, 1 meter of a pipe costs 30$, so it's a good business to make DP's for Subaru). But if you say that DP's for 100$ are not good (Godspeed, whatever else), then I guess I will have to either buy Invidia or order something to be hand made here directly.
Sir Tolik is offline   Reply With Quote
Old 11-17-2012, 03:05 PM   #31
04ScoobyWtf
Member#: 287974
I'm a eBay dp. No issues for over 2 years. Fitment wasn't bad either and ever had a leak as long as I use a new gasket
04ScoobyWtf is online now   Reply With Quote
Old 11-19-2012, 06:39 PM   #32
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
If you go external wastegate then a downpipe from HKS is $150-175 new. If not going EWG then dont use HKS DP (it has a flat flange over IWG area of turbo). Otherwise, I figured there has to be decent parts from the UK like ScoobySport (exhaust note hall of fame). Downpipe from them is $119 lbs. or approx $250 USD.
http://www.scoobysport.co.uk/
DerickRyoung is offline   Reply With Quote
Old 11-19-2012, 10:46 PM   #33
gurusan
Member#: 258165
2006 WRX Wagon
I bought a megan catless downpipe for 100 on ebay and it fits perfectly....there really is no need to pay a lot for a downpipe unless it's catted....and even then you can pay an exhaust shop to weld in a high flow magnaflow cat for pretty cheap.
gurusan is offline   Reply With Quote
