Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 11-16-2012, 04:05 PM   #1
Member#: 331564
Default 2013 impreza a/c cycling too much question
I have a 2013 sport hatch impreza (same as 2012). Why in the world does subaru run the a/c compressor sooo much. When I start the car its running, even if its 1 degree Celcius outside, it stays running until the car interior has thoroughly warmed up, whether the ventilation is set to floor, panel, or mix it doesn't matter. Anytime you put it on defrst the a/c runs. Why ?
This climate control system is the cars achilles heel. I love the car so much, but this is a deal breaker for me, I have to find a way to fix this issue or I'm changing the car. And the heat range sucks. If you set it 31.5 C and run low fan speed its sufficient on a cold morning, but if you go one click higher on the temperature dial it switched to "hi" and you're burning it gets so hot.
Any suggestions?
rebornr1 is offline   Reply With Quote
Old 11-16-2012, 04:26 PM   #2
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Defrost will force the A/C compressor on in order to dry out the interior.
31.5C is 89F. Do you really want your interior this hot?
The next time you're on a long drive, set the temperature to what you find comfortable and leave it there.
Cranking the knob on a cold start defeats the purpose of automatic climate control. The system does its best to bring the interior to where you want it based on available engine heat. The fastest way to warm up the interior is to drive the car.
Commander Keen is online now   Reply With Quote
Old 11-16-2012, 05:27 PM   #3
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
i love the impreza a/c that thing can crank out heat like nobodys business then again I don't have the auto air thingie I like my a/c stupid and manually operated.
Old 11-16-2012, 06:32 PM   #4
Member#: 299286
2017 Legacy Limited
ac will turn on whenever the setting is defrost or floor/defrost whether it is manual or auto climate control.
It does this to dry out the air, because A/C is more than for just cooling, it also helps disperse fogging of the windows.
If you want the AC off, turn off the defrost setting.
