Old 11-16-2012, 02:03 PM   #26
vtdave
Member#: 181001
2012 Impreza WRX 5DR
Rally Blue
Just change the oil when you do the timing belt or when it gets milky white. Should be no big deal. I use 0w-20 with Wesson SuperCurlyFry technology.
Just kidding.
Oil can be complicated or simple. If you want to keep it simple, just do a T6 oil change now.
vtdave is offline   Reply With Quote
Old 11-16-2012, 06:05 PM   #27
bluesubie
Member#: 767
04 FXT
Originally Posted by mingstah
Mobil does make good oil but when I used Mobil 1 high mileage 10w-30 my car burned through like 4 quarts of oil within 3500 miles.
How many intervals did you run it? I'm not sure that was a problem with the oil. It's European ACEA A3 and the viscosity is close to a 40 weight. Just like GC. It also uses a lot of magnesium like Rotella does. I've burned through a quart in about 4k miles which is normal for me.
-Dennis
Old 11-16-2012, 06:10 PM   #28
bluesubie
Member#: 767
04 FXT
Originally Posted by tegulizard13
I've been using AMSOIL 5w-30 with my bugeye for normal and aggressive street driving with little or no burning over a 3k period. It still looks and feels good after a regular oil change interval. 10w-40 for track use I saw only a small amount of oil consumption.
Looks and feels good?
If you want a good Amsoil 5W-30 use the Series 3000 HDD. Similar additive package to the 10W-40 which is as high as the old Rotella API SL/Ci4+ oil. The TBN is also very high so you could probably do 7,500 miles easy.
-Dennis
Old 11-16-2012, 07:44 PM   #29
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Originally Posted by mingstah View Post
He's highly respected in this area. He's also highly recommended on nasioc too.
then he needs to wake the **** up and realize that maybe he dont know as much as he thinks about oil
Old 11-16-2012, 07:46 PM   #30
Uncle Scotty
OK buy Nates beans
and i cant MAKE my car burn any of my rotella t6/racing 4t mix
even driving 1000 miles on the highway at 90mph with a full load and the ac on at 95*F
Old 11-16-2012, 08:28 PM   #31
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
ive been using royal purple 5w-30 for years. i know theres mixed reviews on the RP, but it has been fine for me.
VTSubieRS is offline   Reply With Quote
Old 11-16-2012, 10:24 PM   #32
CalvinT
Member#: 329025
2002 WRX Wagon
Over the years I've seen a lot of cars that have been driven without regular oil changes. Over the long term it will shorten the life of the engine. But doing it once shouldn't be a problem.
I've been using Mobil 1 5w-30 in my 2002 bugeye wagon ever since I bought it new. I followed the interval in the owner's manual until the warranty expired. The dealer was willing to do the labor and provide the filter for free just for the chance to hunt for extra work on the car.
Since then I've continued with Mobil 1 but switched to the Pure One oil filter. Two years ago I went to extended intervals. I change it once a year whether it needs it or not. I figure if BMW can warranty their cars for one year 15,000 miles between changes when using an approved synthetic, then I should be able to go one year and 5,000 miles.
After the first year I sent a sample off to Blackstone. They suggested I extend farther. My Subie is low mileage. I just went past 50,000 miles last week. The only time I have to put oil in is when I change it.
On a side note. I just went Stage One with a COBB access port. I have plans to make some conservative mods.
CalvinT is offline   Reply With Quote
Old 11-16-2012, 10:49 PM   #33
Uncle Scotty
OK buy Nates beans
you are VERY a-typical and your results are really invalid for any comparison, here
Old 11-16-2012, 10:50 PM   #34
Uncle Scotty
OK buy Nates beans
and your results are quite a-typical as well
you must drive like my dead grandma...like not much at all
Old 11-17-2012, 10:27 AM   #35
Tripintaz
Member#: 245218
2013 STI Limited
I can't put any 5w30 in my 2010 WRX. The engine just eats it up like candy and I have to top it off every couple of fuel fill ups. Doesn't matter the brand, just eats it right up. So I made the switch to T6 a while back and now I barely have to top it off every 1500-2000 miles. Of course I drive my modded WRX hard unlike some of the sissy's I hear.
PS Mobil 1 5w30 was the worst oil ever for my WRX....however my Z06 loved it. Its not a bad oil.....its just not very good for turbo Subaru's.
Old 11-17-2012, 04:39 PM   #36
mingstah
Member#: 272307
2002 wrx impreza
-Dennis
Ran with it for 4 intervals. Went from 5w-30 full synthetic Mobil 1, 10w-30, and then 10w-30 extended high mileage. They all burned a ton.
mingstah is offline   Reply With Quote
Old 11-17-2012, 04:42 PM   #37
mingstah
Member#: 272307
2002 wrx impreza
Running the simple castrol gtx 10w-30 regular right now. It's been good so far for about 500 miles.
Old 11-17-2012, 06:04 PM   #38
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Way to search out the 100s of thread on this topic!
Old 11-18-2012, 02:46 AM   #39
Uncle Scotty
OK buy Nates beans
did ya change the pcv valve???
Old 11-18-2012, 10:37 AM   #40
bluesubie
Member#: 767
04 FXT
Nothing has changed here in 13 years.
-Dennis
Old 11-18-2012, 11:31 AM   #41
bluesubie
Member#: 767
04 FXT
Ok. Did you try 10W-40 High Mileage, Turbo Diesel Truck 5W-40, or Mobil1 0W-40?
-Dennis
Old 11-18-2012, 07:20 PM   #42
Uncle Scotty
OK buy Nates beans
-Dennis
nah...hes gonna listen to some d00000000d who he thinks knows what he's talking about....but dont know ****
Old 11-19-2012, 03:38 AM   #43
subi400
Member#: 216984
1996 Impreza outback
Green
Yeah^^^, some of these or most mechanics are still living in the dinosaur era... Times have changed One thing that I am seeing a lot more of is subaru ej25 NA engines spinning bearings and Scotty take a guess on what they are running for oil...?? I suspect poor maintenance and wrong oil but as you know using the "right" oil has a lot to do with it.
Whether it is a subaru turbo or NA engine, oil is definitely one of the top priorities but most people don't know jack about jack.... so they are SOL
To the one guy in here who thinks his mechanic is top notch needs to rethink that....If people don't know the "real" info then anything that is said sounds good enough or "great", they go on not knowing the right info and in the process keep getting screwed over right Scotty??
subi400 is offline   Reply With Quote
Old 11-21-2012, 09:20 PM   #44
yjoo27
Member#: 274578
mobil 1 full synthetic is the best in my opinion
yjoo27 is offline   Reply With Quote
Old 11-21-2012, 11:25 PM   #45
Uncle Scotty
OK buy Nates beans
your opinion is as meaningless as it is worthless
