Old 09-03-2011, 11:07 AM   #126
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Originally Posted by newblue View Post
For everyone who did this with top feed and needed an adapter, how did you route the line from the adapter to the rail? I have an gimmick silicone inlet and It seems to route the injection hose I will have to have a very long hose go above the inlet to the line so that it doesnt kink. Anyone have some insight on this? Will the extended hose be a problem?
Over the top of the intake manifold. I zip tied it to stay in place with proper hood clearance. I have rails now and run a long line to the distro block and relocated FPR (on top of the dogbone) for the air pressure line (which stock is right next to the fpr on the rail). It seems like a long line to reference 1:1 rising rate fuel pressure, but it works just fine. Also, the return line is rather long from the FPR because it has to take a U turn over the turbo. Still, it works just fine.
gabedude is offline   Reply With Quote
Old 09-03-2011, 03:00 PM   #127
newblue
Member#: 115019
2002 Impreza WRX
Perfect, appreciate the feedback gabe!
newblue is offline   Reply With Quote
Old 03-30-2012, 10:28 PM   #128
wrxkyle
Member#: 199635
02-4 rSTI
Im doing this now, but converting to top feeds and topfeed tgv's in the process, stock wrx rails, sti fpr.
A note, make sure the total length, ie metal line on fuel rail and soft fuel line, is the same for feed and feed on both sides and return an ld return on both sides, 02 wrx rails the passenger rail has a significant ammount of extra metal fuel line to run through than any of the others. Ill take measurments when im done for an easy diy
wrxkyle is offline   Reply With Quote
Old 04-16-2012, 11:48 AM   #129
twist4
Member#: 291800
Thank you very much for the detailed pics and your work. It's much appreciated!
twist4 is offline   Reply With Quote
Old 05-08-2012, 06:13 PM   #130
paulpat
Member#: 237145
02 WRX
12 FXT
bump! any update for how the fpr is done and connected for a WRX?
paulpat is offline   Reply With Quote
Old 10-03-2012, 03:06 PM   #131
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
bump for my own reference :P
Old 11-16-2012, 10:16 PM   #132
eicandanedo
Member#: 230364
2004 Sti
wrb
What size line is on the fpr. It's never mentioned and I doubt the stock one is long enough?
eicandanedo is offline   Reply With Quote
Old 07-12-2013, 06:27 PM   #133
Ishart
Member#: 332001
After much reading I'm still confused so maybe an Internet engineer can explain this to me. As far as fuel lines to/from the rail (parallel setup), I have read that some believe that they need to be equal length. It seems that the fpr will create the same amount of pressure for each return line regardless of length so long as the line doesn't run dry, but in that case the motor would be well past blown up. Someone drop some knowledge.
Edit: I realize there will be no hard data unless someone has a 4 wideband setup but hopefully someone knows a sound and proven engineering theory that would apply.
Ishart is offline   Reply With Quote
Old 10-07-2015, 02:54 PM   #134
hottyturcotty
Member#: 238791
2008 IMPREZA STi
Obsedian Black Pearl
Originally Posted by DuckStu View Post
*And roughly 7 feet of 5/16" fuel injection hose. (About $1.29 a foot, or $9.00)
I just want to point out, there is no way you got 5/16" fuel INJECTION hose for 1.29 a foot. Maybe transfer hose, good to about 50-80 psi depending on quality, but not high pressure injection hose.
anyways, doing this today on my 08 sti, should be interesting with the routing...
hottyturcotty is offline   Reply With Quote
Perrin Fuel Rails V2: Fuel Line Routing WRXCJS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-11-2012 08:31 PM
06 STi Top Feed Conversion - Custom Fuel Line Routing HELP guru_method Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-28-2010 08:07 AM
catch can line routing with aps inlet? 06-wrx-tr Rocky Mountains Impreza Club Forum -- RMIC 3 02-24-2010 10:49 PM
My Twin Walbro 255 Fuel Pump Set up. Pictures and Info STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-09-2006 03:22 PM
repost: My Twin Walbro 255 Fuel Pump Set up. Pictures and Info calib17a Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 09-19-2005 02:17 PM
