#26 |
Member#: 326959
Vehicle:2004 wrx black |
Started on the sawp this evening
![]() Only a few things that were a pia. Getting the inlet back on and the oil drain. It was easier to remove it from the bottom near the motor rather then next to the turbo. But putting the clamp back on sucked until I thought of using a zip tie to hold the clamp open. Then it was easy to slide it over the hose and then cut the zip tie to release it into place. But got it all installed in about 2 hrs ![]() Tomorrow ill do the injectors and tune. Hopefully
#27 |
Member#: 326959
Turbo and injectors are installed
Overall not difficult more of a pia. Cobb ots map installed currently snd car is running good. But not really a noticeable hp increase over stage 2. Expecting to see better gains after protune. Only qurstion now is do I get the tune or wait and do ebcs and inlet first then tune. |
#28 |
Member#: 326959
Well today my HOA ebca arrived (thanks wtdash) and I got my stage 4 protune from Clark.
Only started it up and let it idle for tonight but fired up perfect and was as smooth as ever. Tomorrow I'll do some logging on my way to work and get any additional tweeks as needed from Clark. Next I need to hit the dyno and see where I'm at.. Maybe after the 1st of the year. |
#29 |
Member#: 326959
