#1 |
Member#: 184639
SWIC
Vehicle:2006 Imbreza WRX STI Steel Gray Metallic |
Alright so I just ordered a version 2.0 AccessPort for my 2006 WRX right? Needless to say I'm very excited. Anyway, I've seen a few pictures online of AccessPorts mounted in guy's cabs and so far I'm under the impression that cell phone holders are pretty much the way to go. My question is how to run the USB cable and conceal it as best possible so after I get the pig nose re-flashed I can have a clean set up and run live data while I drive. Thank you in advance for any suggestions. Instructions and/or pictures would be great.
-Bailey
#2 |
Member#: 182744
My friend just picked up one of those adjustable cell phone holders he picked up at napa auto parts and uses that to display his accessport. Looks good and works fine
#3 |
Member#: 182744
sorry I didnt read your full post before replying. He just leaves the accessport pluged in all the time and runs the cords underneath the steering wheel. Sorry if I didnt help out much
#4 |
Member#: 184639
SWIC
Yeah no biggie man. That's probably what I'll wind up doing at first but I'm gonna try to figure something else out in the long run. It'd be nice if I could find a way to run the cable under the dash or something and then maybe unhook the port and hide it somewhere, only if I can do so securely though. I'll play around with it.
#5 |
Member#: 99653
Tri-State
Vehicle:05 WRX silver |
What is the purpose of mounting an AP? You will risk damaging the OBD plug or the AP connector. Plus it'll be annoying...
#6 |
Member#: 184639
SWIC
Yeah that's why I'm looking to find a way to hide the cable and maybe unclip the ODB port, so as to get it out of the way. I'd like to mount it so I can take full advantage of the live data features man.
#7 |
Member#: 86459
Tri-State
Vehicle:2013 BRZ SWP |
i believe there is a thread with a bunch of people who have already done this. you can pop out the obd port, and ziptie it out of the way underneath. as for the wire, just run it behind the dash somewhere, and use a clip of some sort maybe on the vent. something of that sort.
#8 |
Member#: 99653
Tri-State
#9 |
Member#: 170790
BAIC
Vehicle:2006 wrx cobb stg. 2 cgm |
Dude you don't need to be all complicated and use all that cellphone crap that makes your accessport stick out and look ugly. I mounted it with velcro, so that way you can take it off easily and hide it when ever you go somewhere. You're probably thinking that velcro isn't strong enough, but it is.
#10 | |
Member#: 184639
SWIC
#11 | |
Member#: 184639
SWIC
#12 |
Member#: 170790
BAIC
I did this http://forums.nasioc.com/forums/show...1167789&page=3
Look on post #73. You should definitely relocate your OBD connector because it really gets in the way with the accessport plugged in. I let a friend repark my car and he ended up breaking the obd 2 connector. Luckely Cobb replaced it for free. My whole wire is hidden under the plastics except for the little part where it actually plugs into the accessport. |
#13 |
Member#: 164939
Vehicle:02 Tacoma TRD 04SV650, 06R6, 01XR250 |
Here is how I have mine.
![]() Cable disappears into the dash never to be seen again. ![]() I also ran the usb cable through a switch so I could turn the AP on and off without unplugging things. ![]() |
#14 |
Member#: 18707
NWIC
Vehicle:2002 WRX Wagon Platinum Silver Metallic |
If you pull the bottom half of the drivers side dash it's pretty damn easy to run the wire up and around and have it come out of an inconspicuous location. I am in the process of hardwiring my Accessport USB cable with a switch in one of the blanks next to the fogs/cruise switches. I've also relocated the OBD-II port so I could stop smacking my shins on the dongle. Being tall has it's downsides. Haha.
#15 |
Member#: 161682
Vehicle:2003 wrx psm |
how did you wire up the switch? i have heard of/read about splicing the red? wire in the usb cable, and there is some company that makes a switched usb cable, just wondering how you did it??? thanks
#16 |
Member#: 164939
That's it. Just open up the USB cable and run the red wire through a switch. I think there are switched USB cable, but you would be foolish to buy when you could just make it for way cheaper AND use any switch you like. |
#17 |
Member#: 158779
Vehicle:2008 WRX Stg2Protune Black |
What about a fuse? What if a short occurs? what blows? your accessport?
#18 |
Member#: 229617
Tri-State
Vehicle:2002 WRX, 1998 OBS Black |
bumpin an old thread. i want to do this with my ap but the obdII connector runs a wire to the ap directly (non usb basically) what wire would i have to put a switch on in order for it to go off. i was prob going to use a relay and just have it turn on with the car but im unsure of which wire i should splice into
this is my connector http://www.cobbtuning.com/products/?id=5653 |
#19 |
Member#: 1575
South East
Vehicle:2011 WRX Premium Blackest Black |
I don't get these threads. I thought you don't need the AP plugged in at all once you reflash?
#20 |
Member#: 229617
Tri-State
its nice to use the features
#21 |
Member#: 187179
International
Vehicle:5 Golden Rings |
you don't and i think its dumb to have it out in the open. Buy a damn boost gauge. I mean im sure 98% of you are using for that reason. You are not data logging every day and it also just gives someone a reason to steal it so u can post a thread " OMG some one stole my AP thats married to my car what do i do help please"
#22 |
Member#: 328794
NESIC
Vehicle:2012 WRX Premium Ice Silver Metal |
Go pro mount ftw!
![]() If you have a gopro, get the vehicle mount kit and work some magic. . Use your imagination. Any quality GPS mount will work, but this is solid. ![]() ![]() ![]() |
#23 |
Member#: 274252
W. Canada
Vehicle:2002 WRX Sedan 6 speed PSM |
Just get one of these:
http://www.rallysportdirect.com/Prot...er-Mount-Black I got one back in July and love it. No more messing around with crappy cell phone holders, this one is made for the accessport v2. |
#24 |
Member#: 336376
MAIC
Vehicle:2006 WRX-AP Stage 2 CGM |
i searched this thread for a min., but didn't see where i can get a mount for my ap. help
#25 | |
Member#: 328794
NESIC
I took my gopro hero2 vehicle kit and added a mount to the back of my AP to make it work with the mount. Some people are happy with velcro, others with cell phone holders, universal vent clips ect. |
| Thread Tools | |
| Display Modes | |
| FS : Brand New Cobb Accessport AP-SUB-002 -$500 | twinturbozs | Engine/Power/Exhaust | 3 | 06-08-2010 08:04 PM |
| Delete | haro15 | Tri-State Area Private Classifieds | 5 | 06-06-2010 10:36 PM |
| FS/FT NY: APS Top Mount Intercool TMIC, Greddy BOV, Cobb Accessport v2 | cjelley | Engine/Power/Exhaust | 13 | 09-17-2009 10:00 PM |
| Cobb Tuning Accessport Version I Cobb Accessport | WRX0520 | Engine/Power/Exhaust | 0 | 07-18-2007 03:02 AM |
| FS: Cobb turboback, ssac tmic, cobb accessport, and cobb springs | wrx/zzr | Engine/Power/Exhaust | 15 | 09-13-2006 02:33 PM |
