Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 11-17-2012, 04:57 AM   #1
avikm289
Member#: 315748
2012 wrx
White pearl
Default how long you guy warm your car for?
is it detremental to let your car warm to the pont where the coolant is a few notches above the "c", or will a minute suffice and let it ride on idle and keep it under 2k rpm in 1-3? does not warming your car harm your engne?
avikm289 is offline   Reply With Quote
Old 11-17-2012, 05:19 AM   #2
Smooth_Puddin
Member#: 280392
2003 Jetta TDI Wagon
6 Speed
It gets warmer faster if you floor it.
Smooth_Puddin is offline   Reply With Quote
Old 11-17-2012, 05:20 AM   #3
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
I usually let it sit in the garage until the temp needle starts to move and then baby it out of my neighborhood. By the time I get to the road shes almost to full temp
DurtyB is offline   Reply With Quote
Old 11-17-2012, 05:35 AM   #4
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
~15 seconds to let the oil circulate around then casual light foot until it starts to warm up.
But you do not need to sit there idling for minutes for it to warm up. Waste of gas...
This is also climate specific but in general you can go pretty well right after startup.
Zefy is offline   Reply With Quote
Old 11-17-2012, 06:04 AM   #5
G.Mac
Member#: 134527
05 STi9 type UK
Urban Grey
I usually start mine and let it idle till I open my gates, then drive it on light throttle till oil tem is up to 70 degrees centegrade
G.Mac is offline   Reply With Quote
Old 11-17-2012, 06:18 AM   #6
don l
Member#: 334322
2013 Impreza Sport
Ice Silvef
Default Warm Up
I've got a 2013 Impreza 2.0 with the CVT transmission. When started COLD it takes 3-1/2 minutes before the idle comes down to 1000 rpm or so. When first started, the engine revs at 1800 for about 2 minutes...then drops to 1500 rpm for a minute...then slowly levels off to 1000 rpm or so. This is my first CVT transmission and I've been wondering if it is OK to just let it run for 30 seconds or so and then drop it into gear...anyone doing that or ?
Currently I let it run for the 3 minutes before I put it into gear...
Any suggestions on what others are doing would be appreciated...thanks!
don l is offline   Reply With Quote
Old 11-17-2012, 07:12 AM   #7
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
I let mine warm up for an hour with the heat cranked so when I get in it feels I'm in Hawaii. It's like a mini vacation.
nhmtns is offline   Reply With Quote
Old 11-17-2012, 07:26 AM   #8
turboterror99
Member#: 270910
2006 WRX Tr
^^You crack me up, man! You should get one of those tropical drinks from Sonic to top the experience off.
turboterror99 is offline   Reply With Quote
Old 11-17-2012, 07:38 AM   #9
prometheum
Member#: 92003
04 bicycle!
as long as it takes me to put my seat belt on, and adjust the radio
drive lightly until the needle makes 1/4 up the way
prometheum is offline   Reply With Quote
Old 11-17-2012, 08:02 AM   #10
mikeythejew
Member#: 141672
I never let my car warm up. I park my car in an attached garage and don't deal with scraping windows.
Regardless if it sits out at work and it's 8F, I start and immediately drive gently until it's warmed up. Letting your car sit around and warm up causes fuel dilution which isn't an ideal lubricant. Look at UOA's with high fuel dilution and the higher wear numbers that often go with it.
I've owned my WRX since new, long been stage 2 and has 118k miles of trouble free service.
mikeythejew is offline   Reply With Quote
Old 11-17-2012, 08:09 AM   #11
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Jubert69 is offline   Reply With Quote
Old 11-17-2012, 08:16 AM   #12
TurboTeggyBoy
Member#: 81247
2005 PSM WRX
TD04L-19T Stage 2ish
Is this not what the OP basically asks in post #1?
I don't. Start, back out garage, drive out neighborhood. Not needed.
TurboTeggyBoy is offline   Reply With Quote
Old 11-17-2012, 08:17 AM   #13
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Who guy? My guy? I don't have a guy. You must be mistaking someone else's guy.
tibug is offline   Reply With Quote
Old 11-17-2012, 08:24 AM   #14
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Is this really lost on you guys?
I warm my cars up zero. Nada, nothing.
Thank you, please play again
Old 11-17-2012, 08:31 AM   #15
CrashBandit
Member#: 329543
2003 WRX Wagon
Sonic Yellow
So from the few legit posts I've read about this topic, does it make a difference if it's say: 20*F outside? I will start my car >10 minutes before I leave in the mornings so it's warm inside and the temp gauge is at normal level. I live right off a busy highway, sometimes I have to "gun" it to pull off and get up to 55-60mph speedlimit. There are also mountains and hills on my way to work and it can be hard to stay out of boost unless I want to be in say 3rd going 40+mph..
CrashBandit is offline   Reply With Quote
Old 11-17-2012, 09:26 AM   #16
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
how come you guy don't understand
jak pls
Old 11-17-2012, 09:36 AM   #17
Riz98
Member#: 329344
2006 Sti
2-3 minutes
Riz98 is offline   Reply With Quote
Old 11-17-2012, 09:38 AM   #18
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
To answer the question OP, you don't need to. The only thing you should be worried about is high RPM/high throttle positions until it's at running coolant temperature for around 10 minutes(Oil usually reaches operating temperature around that time)
I've had my car for 90k miles(150k total milage on car) and I rarely ever warm it up.
Old 11-17-2012, 09:56 AM   #19
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
I only warm it up when it's 20F or lower outside. If I had to warm up every time I left work, that would just be dumb.
RM_2 is offline   Reply With Quote
Old 11-17-2012, 10:26 AM   #20
Riz98
Member#: 329344
2006 Sti
If my drive to work everyday was longer than 10 minutes I probably wouldnt let it run as long. Just trying to get the oil to operating temps for short trips.
Old 11-17-2012, 10:33 AM   #21
Vart
Member#: 325031
2014 Forester XT
X2
The only time I let it warm up any longer is if there is frost or ice on the windows that I am too lazy to scrape off.
Vart is offline   Reply With Quote
Old 11-17-2012, 10:40 AM   #22
lavid2002
Member#: 226864
Start it, wait about 5 seconds, then start driving. I try to keep it around 2.5k until it's hot. No higher than 3k. Once she's fully warmed up I open it up. Maybe I'll go to 4k as it's warming up but not 100%
Oil circulation is much more important than thermal expansion and other things that happen when the motor is hot. Oil circulation takes almost no time at all, it happens right when the car is started.
Old 11-17-2012, 10:53 AM   #23
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
I warm mine up for 5-10 minutes in the mornings, 3-4 in the afternoon. Depends on how long I want to hear piston slap.
Old 11-17-2012, 10:58 AM   #24
easterbran
Member#: 307359
'05 STi Stage II
I let my Sti idle for a minute, then drive for the first five minutes staying under 3K rpms and out of boost. Or at least until the temp reaches the first notch.
Old 11-17-2012, 11:01 AM   #25
SubieLuvin
Member#: 248202
2013 WRX Sedan
Run the piss out of it when it's cold.
Less heat soak
SubieLuvin is offline   Reply With Quote
