Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 02-23-2011, 05:55 PM   #51
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Installed RCE yellow today.
Front and rear gaps look about even with rear 1/4" saggy shim.
txl146 is offline   Reply With Quote
Old 02-23-2011, 07:03 PM   #52
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Your car sits high for sure. Here's a pic of a bugeye wagon with 3/8" spacers on the rear with yellows.
Tony
Old 02-23-2011, 07:39 PM   #53
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Tony, any idea as to why my car sits higher? I really like the way my car looks with RCE yellows. Hope my car won't drop like that wagon.
Old 02-24-2011, 10:02 AM   #54
Turn in Concepts
Member#: 93646
Many Track Records
Have you loosened any of the suspension pick up points? Maybe you have some binding in the bushings.
Tony
Old 02-24-2011, 12:11 PM   #55
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
No, I have not loosened any of the suspension pick up points. Maybe it will settle after several days.
Likely chance of bushings binding on all 4 corners seems unlikely.
Old 02-26-2011, 12:39 AM   #56
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
For those with RCE yellow on bugeye, anyone having similar fender gap as my car shown above? I drove for 2 days and fender gap hasn't changed much. I did make sure I install struts/springs correctly, so I find it kind of odd.
I honestly like the way my car look and don't my car to look like above yellow wagon (slammed look).
Old 05-13-2011, 10:34 PM   #57
POP3Y3
Member#: 149465
2003 2.5R(eal)S(low)
I FINALLY got around to installing my suspension stuff today with help from my dad. Pics will follow shortly. Planning to wash/wax tomorrow, so it won't be long.
I can say that after looking at mine this evening, then looking above at txl's pics, my car sits VERY similar and not slammed like the yellow wagon. I couldn't be happier!
POP3Y3 is online now   Reply With Quote
Old 05-16-2011, 05:40 PM   #58
POP3Y3
Member#: 149465
Without further adieu...
Struts: Tokico D-Specs
Springs: RCE Yellow
Tophats: Group N
Wheels: 17x7.5 Rota Torque
Tires: 225/45/17 BFGoodrich G-force Sport
Misc: Scooby921 strut spacers, Paranoid Fabrications 3/8" saggy butt spacers, Ingalls camber bolts (rear)
Old 05-17-2011, 01:15 AM   #59
BuggedWrx
Member#: 227893
Why is that wagon so low anyway, anyone know? Been trying to get a set of these springs.
BuggedWrx is offline   Reply With Quote
Old 11-17-2012, 08:40 AM   #60
chomdh
Member#: 147931
2004 Impreza WRX STi
World Rally Blue
This wagon sits perfet IMO. Nice work.
Tony
chomdh is offline   Reply With Quote
Old 01-22-2013, 02:44 AM   #61
jrasor
Member#: 293994
2008 STi
Springs: RCE Yellow
Tophats: Group N
I'm looking at doing this to my 02 wagon. With the 225/45 r17 tires do you get any fender rub without doing a fender roll? How much did the saggy butt spacers effect the rear height? Too stiff for a daily driver?
I was looking at getting RCE Yellows/Blacks, KYB AGX Adjustable Shocks, STI rear top hats, and Scooby921 strut spacers.
Thanks!
jrasor is offline   Reply With Quote
Old 01-22-2013, 06:48 AM   #62
POP3Y3
Member#: 149465
No fender rub whatsoever. I did not want to roll/pull my fenders since this is my DD.
I can't say definitively that the saggy butt spacers affected it a ton, but I thought the ride height looked perfect, front to back, with them installed.
And as I said, this is my daily driver, and though it's stiffer than stock, it doesn't rattle your fillings or your spine to the point of discomfort. I wouldn't want it any stiffer, but I like the firmness and the fact that there's very little body roll. I can take the interstate ramps pretty hard without roll, and I could also easily autoX with this setup, if only it wasn't so slow
Good luck and hope this info helps!
Old 01-22-2013, 08:50 PM   #63
jrasor
Member#: 293994
2008 STi
Thanks alot, i'm looking for the exact same thing. I love the look of that height and i'm looking for more performance out of my springs for the day to day. Could you give me a brief break down of the spacers? Did you place the scooby spacers F&R (two sets) and add the saggy butt spacers to the rear? Just making sure I order everything right the first time...
Thanks!
Old 01-23-2013, 06:23 AM   #64
POP3Y3
Member#: 149465
I'm fairly certain that all front tophats 02-07 are the same design. This means front tophats are interchangeable on any Impreza struts. It's the rears that must be correct, 02-03 or 04-07, depending on the model of spring you use, which dictates the model of rear tophat. The rear D-spec struts are the only ones that use the Scooby921 spacers, since they're technically for bugeyes only, so you'll only need a single pair.
As for the Paranoid Fab saggy butt spacers... one set, and each one literally just lays down over each fully-assembled rear suspension unit just before you mount it inside the rear strut tower.
Old 12-10-2014, 01:28 PM   #65
natew503
Member#: 401476
2003 WRX Wagon
Originally Posted by thrasher View Post
Here's a new one of mine with different wheels/tires...same suspension though:
RCE Blacks
Tokico D-Specs
RCE Lowering Camber Plates - f
04+ Group N Tophats - r
Sweet ride! Are the camber plates and tophats necessary? I have an 03 Wagon.
natew503 is offline   Reply With Quote
Old 12-10-2014, 08:53 PM   #66
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Thank you!! Well, the camber plates are not required. Some sort of tophat is necessary. I could have stuck with OEM tophats, but if I hadn't used the camber plates I would have at least used the firmer group n tophats all around.
thrasher is offline   Reply With Quote
Old 12-13-2014, 09:13 PM   #67
kparshin
Member#: 407344
Default sorry to bring this back from the dead xD but...
Springs: RCE Yellow
Tophats: Group N
I really like what you've done here and plan on getting the same suspension setup. I was wondering if anyone could tell me whether these are the right parts:
Tokico DSpecs: http://thmotorsports.com/i-526460.as...OWkaAttc8P8HAQ
RCE Yellow Springs: http://www.rallysportdirect.com/Race...wering-Springs
group N tophats: http://www.rallysportdirect.com/STI-...r-Strut-Mounts
scooby921 strut spacers: http://www.fastwrx.com/products/tic-...-strut-spacers
saggy but spacers: http://www.paranoidfabrications.com/...-impreza-hdpe/
ingalls camber bolts (rear):
http://www.flatironstuning.com/p-178...ber-bolts.aspx
or maybe these instead:
http://www.rallysportdirect.com/Whit...2-2011-WRX-STI
Thanks!
kparshin is offline   Reply With Quote
Old 12-14-2014, 04:50 AM   #68
hghjgjh
Member#: 408548
figured it out. thanks for your help guys
hghjgjh is offline   Reply With Quote
Old 12-14-2014, 11:27 AM   #69
xgvnxgh
Member#: 408559
Anyone else? Am I just looking in the wrong spot?
xgvnxgh is offline   Reply With Quote
RCE Black and Yellow Springs and RCE Swaybar PACKAGES!!! GTWORX.com Suspension/Brakes/Handling 60 10-29-2009 05:10 PM
Want to see your V1 lip on 02-03 Ryan314 Member's Car Gallery 38 01-13-2006 04:33 PM
I want to see your lowered 4dr RS's Jaredm82 Brakes, Steering & Suspension 0 04-08-2004 09:09 PM
The super AFC post- I want to see your AFCs. NickWRX Member's Car Gallery 4 08-16-2002 03:55 PM
Want to see your Snow Drivin' PICs' MichiganRS General Forum Archive 14 12-23-2000 10:43 PM
