Old 11-12-2012, 09:30 PM   #351
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Originally Posted by Bones702
Great numbers man. My dom4 is at that but I'm at a lot higher elevation. These turbos are fantastic.
I've been very happy with mine! After I build up the motor I'm going to push it up to 30 psi
jnorth85 is offline   Reply With Quote
Old 11-12-2012, 09:44 PM   #352
Bones702
Member#: 205115
06 Sti Dom4.0XTR
I look forward to the numbers, I hit [email protected] Maybe after winter ill get it tuned again at some higher boost and put the built motor threw its paces and see what happens.
Bones702 is offline   Reply With Quote
Old 11-12-2012, 09:55 PM   #353
scoobiesnacks22
Member#: 154113
2006 WRX Wagon
spinningallfour
If you run ur car on that same dyno and same elevation I bet you put down over 600hp!
scoobiesnacks22 is offline   Reply With Quote
Old 11-12-2012, 10:02 PM   #354
Bones702
Member#: 205115
06 Sti Dom4.0XTR
That would be intense. I love the power now so another 100whp would be crazy.
Old 11-12-2012, 10:19 PM   #355
scoobiesnacks22
Member#: 154113
2006 WRX Wagon
spinningallfour
You wouldn't gain any HP, every dyno reads differant and that one must read high. I put down 380 mustang dyno with the same setup and elevation with 27 psi on vp109. 140 HP difference is a lot?!?!?
Old 11-12-2012, 10:41 PM   #356
Bones702
Member#: 205115
06 Sti Dom4.0XTR
Every car is different this is true. But when it was being tuned I didn't want to push it. And the tune was just getting going. Granted you could be right I won't make much more power... But on the other hand there is more left in the turbo and motor
Old 11-12-2012, 10:42 PM   #357
jnorth85
Member#: 76785
SRP
It reads about right. I've had my car on 2 different dyno jet's and they read about the same.
Old 11-13-2012, 12:10 AM   #358
scoobiesnacks22
Member#: 154113
2006 WRX Wagon
spinningallfour
Then those are some great numbers!! That thing must pull like a monster!
Old 11-13-2012, 07:30 AM   #359
jnorth85
Member#: 76785
SRP
It sure does! And the 2800lb chassis helps too
Old 11-14-2012, 08:39 PM   #360
robotskillhumans
Member#: 155244
06 ice cream sti
I must be doing something wrong. I have a Dom 4 with a built shortblock at 21 psi with all the supporting mods and I'm only making 360 whp. Anyone have any recommendations?
That's on pump gas and meth. I haven't gotten it tuned on race gas yet.
robotskillhumans is offline   Reply With Quote
Old 11-14-2012, 09:00 PM   #361
Bones702
Member#: 205115
06 Sti Dom4.0XTR
I was at that power level on pump 18@ psi. The turbo really comes alive with higher boost and race fuel helps. My final pump map at 21 psi was 400whp. Built block. Some cars react different to the fuel and so on. I bet the tuner wanted a safe tune for you. But I'm only assuming that.
Old 11-14-2012, 11:16 PM   #362
robotskillhumans
Member#: 155244
06 ice cream sti
Well yes they definitely went with a tune on the safe side. I can tell that my tune is on the rich side. All I wanted was 400whp on pump.
Old 11-14-2012, 11:29 PM   #363
jnorth85
Member#: 76785
SRP
On pump I was around 350whp on the DOM3 you should be close on the 4.
I wasn't happy with the low numbers on such a big turbo, that's why I chose to switch to E85
Old 11-17-2012, 11:05 AM   #364
scoobiesnacks22
Member#: 154113
2006 WRX Wagon
spinningallfour
Yea I put down 340 on pump on a mustang, but I only put down another 40-50 on higher boost not another 150!!
Old 11-17-2012, 11:11 AM   #365
jnorth85
Member#: 76785
SRP
A lot of my additional power comes from both AVCS tuning and the additional timing you can run with E85. During tuning I saw numbers come up as much as 30hp from small timing adjustments alone.
Old 11-17-2012, 11:21 AM   #366
scoobiesnacks22
Member#: 154113
2006 WRX Wagon
spinningallfour
What size injectors did you use? I was told that I would need 2000cc injectors to run e85
Old 11-17-2012, 11:24 AM   #367
jnorth85
Member#: 76785
SRP
I'm on 1400cc injectors. But I also have -8 feed lines and a fuelab 600lph pump. The back half really helped keep my IDC's low
Old 11-17-2012, 12:04 PM   #368
scoobiesnacks22
Member#: 154113
2006 WRX Wagon
spinningallfour
Wow that's a nice setup!!
Old 11-17-2012, 12:35 PM   #369
jnorth85
Member#: 76785
SRP
You can read up on my build here
http://www.rs25.com/forums/f145/7429...-begins-7.html
Old 11-17-2012, 03:31 PM   #370
st205wrx
Member#: 193253
08 wrx 322/352
wrb
I am running id 1000 cc and was told I can run e85
st205wrx is offline   Reply With Quote
Old 11-17-2012, 03:45 PM   #371
jnorth85
Member#: 76785
SRP
What Turbo and power level are you going for?
Old 11-17-2012, 03:46 PM   #372
Blacksheep6
Member#: 239945
You can if you don't plan on running any more then low 20's psi boost range. I ran out of fuel (e85) on a dom 3xtr with a hardwire aero 340 fuel pump at 65 pds base fuel pressure and 23.5 psi boost.
Blacksheep6 is offline   Reply With Quote
Old 12-04-2012, 02:41 AM   #373
zakeswrx
Member#: 337169
2010 wrx
obsidian black
I don't think I've read any charts where someone had heads and cams done running the Dom 3.0xtr I'm thinking that will make a pretty decent increase in power
zakeswrx is offline   Reply With Quote
Old 12-04-2012, 03:23 AM   #374
rexblake
Member#: 178426
2010 S4
Gray
I had headwork and cams.
Old 12-04-2012, 08:13 AM   #375
jnorth85
Member#: 76785
SRP
I'm at 521whp now I have heads with +1mm valves and GSC S1 cams going in this winter.
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 10:58 PM
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 06-07-2010 12:04 AM
Dom 3.0XT-R and Dom 4.0XT-R Now Available Blouchturbo Engine/Power/Exhaust 17 02-04-2010 02:01 AM
Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts GTBGUY Normally Aspirated Powertrain 85 05-24-2001 07:33 AM
