Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-15-2012, 03:58 PM   #1
subadict
Member#: 310017
2008 WRX Hatch
obsidian black
Default What is a race preped head ?
Hi guys. I am trying to understand what a race preped head stands for. I want you to help me see which parts are different and the effect. What I mean is :
· I understand porting and port matching
· I understand that it will have heat resistant valve et valve seat (like titanium for the valves and beryllium for the seats)
· Probably a hi performance gasket to avoid any leaks (plus maybe a O’RING)
· Springs are going to be stiffer
· They’ll probably have more aggressive cams.
· And probably beefed up studs to keep the head from popping
What else ? And what will differentiate a “hi performance” head vs “racing”. Is there something else than CFM flow and head resistance that’s improved ?
Are the heads sold by mainstream companies like cosworth race heads or hi perf heads ?
Thanks alot.
If you have any reference, please post the link and I’ll read it. No bashing : I did not know how to find a precise answer.
subadict is offline   Reply With Quote
Old 11-15-2012, 04:18 PM   #2
djdalaney
Member#: 301136
Race anything generally just means it is not meant for street use. A race prepped head is most likely going to be built with high RPM in mind and wouldn't be the best choice for a street driven car. You often trade low end torque for high RPM power when machining/building heads. Without a specific example, that's pretty much all I can tell you.
Also, I believe O-rings are installed into the block, not the heads.
djdalaney is offline   Reply With Quote
Old 11-15-2012, 04:18 PM   #3
biodude
Member#: 271720
its a catch phrase to get you to spend more money.
biodude is offline   Reply With Quote
Old 11-15-2012, 04:21 PM   #4
subadict
Member#: 310017
2008 WRX Hatch
obsidian black
How is the high rpm optic going to be accomplish ? What kind of machining / changes are going to be made ?
Thanks by the way
Old 11-15-2012, 05:26 PM   #5
djdalaney
Member#: 301136
Thanks by the way
Larger valves and larger ports mainly. These changes will decrease the velocity of the air, but allow it to flow a larger amount of air overall. The loss in air velocity will cause a loss in low end torque, but allow for more power in the top end due to more air flow.
Keep in mind, these are generalizations. I have no idea what head you are talking about, so I have no idea what was actually done or how it will perform.
Old 11-15-2012, 06:13 PM   #6
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
^^^Suddenly the usefulness of individual throttle bodies is apparent to me.
Old 11-15-2012, 11:52 PM   #7
subadict
Member#: 310017
2008 WRX Hatch
obsidian black
Pretty clear. Thanks !
Old 11-16-2012, 10:32 AM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
"race prepped" means whatever the shop building the heads wants it to mean. Don't become preoccupied by key words and tricky phrases. Find out what you want done to your heads and commission a quality shop to get it done. After that you can call them whatever you want.
Old 11-16-2012, 02:11 PM   #9
subadict
Member#: 310017
2008 WRX Hatch
obsidian black
I'll ask the question differently : what could be done to the head to improve performance and what are the upsides / downsides to it ? I know a little bit about components as I said above but I don't know much about machining and the effects it'll have. It may be a newbe question but I cannot find any search word on google / nasioc that'll give me more than "race prepped" heads the way you stated it.
If you have any link to help me, it would be much appreciated.
Old 11-16-2012, 03:25 PM   #10
biodude
Member#: 271720
Are you gathering info for a motor build or just for general knowledge?
If its for a build, state your goals and you will most likely get more specific replies as to the amount of work that is appropriate for your application
generally speaking, you want to do things to the heads that allow for smoother and more efficient air flow through the head. Valve jobs, bowl blending, porting and polishing, are examples of the types of work that is commonly done. I wont define each, they are common terms you can search for more detail.
On top of that there are things to you can do the the mechanisms themselves, such as changing cams, valves , valve springs, retainers etc. In my opinion this is where you begin to get into the 'raceprepped' category, once you begin to exceed the factory RPM and operating temps, you will need to start upgrading the hardware to meet those needs. For example if you wanted a higher RPM application, springs with higher seat pressures are needed and then along with that you need valves designed to withstand those higher pressures. Lighter spring retainers don't hurt either.
here is an old ad from ASF machine, with some pics of a mild and more extreme example of porting polishing and a multiangle valve job.
http://forums.nasioc.com/forums/show....php?t=2038614
there is some good reading in here by element tuning as to what they believe to be effective (scroll down for the head info)
http://elementtuning.com/competition-engines/
more on porting
http://forums.nasioc.com/forums/show....php?t=1728481
Old 11-17-2012, 12:59 PM   #11
subadict
Member#: 310017
2008 WRX Hatch
obsidian black
Thanks alot, much appreciated !
