Old 11-17-2012, 01:24 PM   #1
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
Default Installed Catless downpipe, creating lots of smoke now
I just installed a cat-less down pipe and it is creating a ton of smoke out of the tail pipe. No other mods currently. It's current only on stock map. Should I put it into stage two map? Since Running 3" catless downpipe = catback? Inputs? =D
IheartAWD is offline   Reply With Quote
Old 11-17-2012, 01:25 PM   #2
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
Stage 2 tune should have been the first thing you did before firing it up. Have you driven it much since installing the dp and noticing the smoke, or id it just start up smoke?
guroove is offline   Reply With Quote
Old 11-17-2012, 01:40 PM   #3
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
I just loaded the stage two map onto it. It still smoking =/ drove it around for 20-30 minutes and it smokes a lot still.
Old 11-17-2012, 02:09 PM   #4
guroove
Member#: 129833
2005 Forester XT
The stage 2 map isn't going to do anything to stop the smoking, it's just the right map for having a dp installed. What color is the smoke?
Old 11-17-2012, 03:44 PM   #5
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
droved for an hour straight, now it gone. I think it was the VHT coat I sprayed onto the downpipe. I think some might have got into the pipe when I was spraying it.
Old 11-17-2012, 04:19 PM   #6
ScoobySubyDoo
Member#: 329311
Satin Black
Glad to hear the problem fixed itself!
ScoobySubyDoo is offline   Reply With Quote
Old 11-17-2012, 05:53 PM   #7
IheartAWD
Member#: 329962
2016 WRX 6MT
Shadowmere
There's still a case of a decently loud rattle when I shift between gears or at 2400 RPM and up. I think it might be the bottom end of the turbo heat shield that I left on. Has nothing holding onto it from the top.
Old 11-18-2012, 12:14 AM   #8
SlverEJ20
Member#: 157158
05 WRX stage 2
Did you use all the mounting points for the dp ? sometimes people skip/forget to secure all the mounting points and this can cause a rattle.
SlverEJ20 is offline   Reply With Quote
Old 11-24-2012, 04:57 PM   #9
Tenament
Member#: 246813
^^ or very annoying squeaks! I forgot to bolt on 1 mounting point to my DP and for the months after was trying to chase around a horrible squeaking that I, at various times, thought it was the shocks, sway-bar, or anything else. Was funny to finally fix it so simply when taking the exhaust off to change the transmission >
Tenament is offline   Reply With Quote
