Old 11-01-2012, 03:37 PM   #1
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
Default Transmission mount recommendations?
Hey everyone, I have a rear main seal leak starting, and a throwout bearing on the way out, so I'm going to drop the tranny and replace along with the oil seperator plate.... I figured i should replace the transmission mounts while the trans is out. Any recommendations? I'm only asking as i see a huge difference in prices on aftermarket ones. I'm not running any huge power numbers, so i don't think the priciest ones are necessary... any experiences or recommendations?
VTSubieRS is offline   Reply With Quote
Old 11-01-2012, 03:48 PM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I put in a group N (solid rubber) mount and crossmember bushings in (whiteline I think) when I did mine..
Old 11-01-2012, 03:51 PM   #3
Big-E
Member#: 123843
2016 STI LTD CWP w/
blade wing from factory
Go with OEM or a Group-N mount: http://turninconcepts.com/product_in...roducts_id=620
Also upgrade the transmission crossmember bushings: http://turninconcepts.com/product_in...roducts_id=310
Or you could do a driveline upgrade (package) of the engine and transmission mounts (both Group-N) as well as for the transmission crossmember bushings: http://turninconcepts.com/product_in...oducts_id=1083
Big-E is offline   Reply With Quote
Old 11-01-2012, 04:22 PM   #4
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
thanks for the links Big-E. That stage 2 kit looks like a good price and upgrade from oem.
Old 11-16-2012, 08:04 PM   #5
zman519
Member#: 118086
Did you install it? How do you like it? i am thinking about geting it
zman519 is offline   Reply With Quote
Old 11-16-2012, 08:14 PM   #6
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
installing tomorrow. i've heard nothing but good things about the group n mount upgrades. the transmission crossmember bushings are supposed to help. i had a big issue with turn in concepts this time around, but you can order the group n stuff other places. either way i'll let you know after the install.
Old 11-17-2012, 02:51 PM   #7
zman519
Member#: 118086
Ok Thanks.
Hope its going well today. Its a grate day by me to be working outside
