Old 07-31-2012, 10:09 PM   #26
Crazymonk88
Member#: 200532
05 Legacy
GRP
Originally Posted by V8 GTFO Lesbic WGN View Post
It is nearly impossible to find a reputable exhaust shop, I would just try one of those Super Trapp contraptions.
You are not living life!!! I hit boost everyday at least for a couple of seconds haha.
Crazymonk88 is offline   Reply With Quote
Old 08-06-2012, 04:49 PM   #27
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
I don't agree with plumbing it back in to the downpipe. Why did you go external in the first place then? Why not go back to IWG? The benefit of external is that you bypass the primary exhaust....
If you don't like the noise of external, put a muffler on it or go back to IWG...
thefoos is offline   Reply With Quote
Old 08-08-2012, 04:46 PM   #28
galntvr4
Member#: 328492
EWGs provide superior boost control -- I'd plumb it back into the down pipe. Just my $0.02.
galntvr4 is offline   Reply With Quote
Old 08-08-2012, 06:08 PM   #29
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
^very difficult to get a quality weld job, that won't last and will compromise your downpipe, also why reintroduce exhaust into the system. EWG muffler is the best alternative in terms of cost, performance and reliability, it is a no brainer. A virgin downpipe will be easier to unload too at the classifieds.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 08-08-2012, 11:51 PM   #30
nitsuj
Member#: 87081
05 PSM STi
05 AW XTi
another alternative: get a bigger turbo that takes longer to spool, then you wont need to hear it all the time, just when you want a good kick in the pants
nitsuj is offline   Reply With Quote
Old 08-08-2012, 11:55 PM   #31
jrigby
Member#: 256134
2005 Baja Turbo 6MT
Plumb it back in to the intake
Sorry couldn't help myself.
jrigby is offline   Reply With Quote
Old 08-09-2012, 10:59 AM   #32
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
I have used the Supertrapp on a bunch of rotated turbo kit Subarus for customers and it has worked exactly as intended every time. I've never had an instance where boost becomes uncontrollable due to restricted flow. The only difficult part is that the inlet into the muffler is not the same size as TiAL's outlet tube so you need a reducer pipe.
-Ty
AMS is offline   Reply With Quote
Old 09-14-2012, 01:54 PM   #33
shooting
Member#: 82720
1993 any 93 + subaru
dirty or snowy
its just too fun running someone just under gate pressure then letting the gate open... GRRRRRRRRRRRRRRRRRRRRR !!!! she growls when the gates open. learn to drive JUST under the gate opening.. only when needed do you "unleash the beast!"
shooting is offline   Reply With Quote
Old 09-14-2012, 02:40 PM   #34
sjs0433
Member#: 86061
How much does the supertrap drop the noise level? Would you say it's cut in half? more/less?
sjs0433 is offline   Reply With Quote
Old 09-14-2012, 04:22 PM   #36
sjs0433
Member#: 86061
At work now but will definitely check those out when I get home. Thanks!
Old 09-14-2012, 07:12 PM   #37
ThunderousProduction
Member#: 282899
If the sound of the EWG is annoying and as a daily driver you aren't committed to it then get rid of it. Its purpose is to dispose of those gases and as so the noise is made, it is simple physics that it makes that noise. If you wanna quiet the cabin do so with sound deadening material but don't alter flow to block noise if your car truly needs a EWG then it needs to not be tampered with and in all reality, blatantness, and honesty I would say get used to the sound of fine mechanics or remove it.
ThunderousProduction is offline   Reply With Quote
Old 09-14-2012, 07:14 PM   #38
68Cadillac
Member#: 95901
The Supertrapps look simple, easy, and judging by the videos effective. So affordable at ~$60.
68Cadillac is offline   Reply With Quote
Old 09-14-2012, 11:06 PM   #39
Swagon_Wagon
Member#: 294424
1999 RSti
white as ****.
you could always extend the pipe to its not dumpped right below your feet. You know like aim it to side or farther back behind you. let the sound out around the bottom of the left or right b pillar.
Swagon_Wagon is offline   Reply With Quote
Old 09-15-2012, 12:03 AM   #40
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^too much strain at the welds having a long pipe.
Old 09-17-2012, 02:18 PM   #41
DeleriousZ
Member#: 323869
2000 ST-outback
White/Grey
wat?
Any professional welder should be able to do a fine job plumbing the ewg dump back into the exhaust.
Running a small flex pipe alleviates the extra stresses put onto the downpipe by running the dump back into it.
Also, as long as it's plumbed back in far enough into the dp and at the correct angle, it won't affect flow that much. Hell, if it's designed correctly it might even help flow at high rpm's.
DeleriousZ is offline   Reply With Quote
Old 09-17-2012, 03:48 PM   #42
besthaticouldo
Member#: 279660
wtf, seriously? i love the noise.
besthaticouldo is online now   Reply With Quote
Old 09-25-2012, 01:24 PM   #43
04ScoobyWtf
Member#: 287974
Plumb it all the way to the back ad make It look like you have duels haha
04ScoobyWtf is offline   Reply With Quote
Old 09-25-2012, 02:15 PM   #44
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^There is an Sti with a dump tube on the front fender, can't find the pic but you get the idea.
Old 09-26-2012, 06:20 PM   #45
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Wow guys, what's it like to go through life with so much ignorance and yet so much confidence?
Another benefit of an EWG is that you get an actuator with top and bottom ports, for better boost control. You can hook up the solenoid in ways that aren't possible with a regular single-port IWG actuator. You can run more boost with the same-strength WG spring, or you can run a lighter WG spring and have better part-throttle driveability.
Another benefit of an EWG is that you get a bigger wastegate port to fix boost creep.
Another benefit of an EWG is that you can control boost, which is a real problem when your turbine housing doesn't even have an internal wastegate.
(And as for me, personally, I'm going to switch to one just because removing my IWG will allow me to clock the compressor cover, and that will allow me to run a shorter charge pipe, with fewer bends between the turbo and the intercooler core.)
Old 11-13-2012, 09:11 PM   #46
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Putting these traps on the EWG will be like making your W/G smaller better chances of boost creep on a high power setup.
Best bet would be to buy the perrin dual tube CBE and run your EWG to the smaller second tube!
Old 11-13-2012, 10:29 PM   #47
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^you are still routing the gases to a back pressure environment.
Old 11-17-2012, 03:17 PM   #48
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Old 01-20-2013, 07:49 PM   #49
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Now just need to find a competent fabricator.
Mock-up dump tube using PVC pipe and Gorilla tape.
Old 01-27-2013, 06:46 PM   #50
paulpat
Member#: 237145
02 WRX
12 FXT
^ how much black soot are u going to find near the super trap?
paulpat is offline   Reply With Quote
Quieting Down an Exhaust digitalboy40 Newbies & FAQs 13 06-14-2007 03:05 PM
How much will a small muffler quiet down an EWG? scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-22-2007 01:16 PM
Anyone to quiet down an exhaust system? schooby Normally Aspirated Powertrain 21 09-19-2006 12:00 AM
How to quiet down a TBE? WRB4U Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-06-2003 08:55 PM
What can I do to quiet down my new exhaust? Robmat South East Region Forum 4 07-06-2001 12:18 PM
