#101 | |
Member#: 74167
NESIC
Vehicle:2011 WRX Sedan WRB Cobb Stage 2 OTS |
So, bump, hopefully people have more insight to this problem.
#102 |
Member#: 333423
NWIC
Vehicle:2012 WRX Hatch Dark Gray Metallic |
No one has discovered the cause of this problem? I have no squeek but starting yesterday I had a vibration mid travel when pushing the clutch both in and out. '12 WRX with 1950 miles. Seemed to be decreased the next day. Pumping seems to help but I don't want this to continue!!!
#103 |
Member#: 268957
Tri-State
Vehicle:2011 WRX 5 door gray |
#104 |
Member#: 281510
TXIC
Vehicle:2009 Rex |
Just a shot..but have you checked the spot welds that secure the pedal assembly to the firewall ?? These have been coming apart like crazy and this causes a nice squeaky popping noise .. Might help with one of ur squeaks
http://www.wrxforums.com/forums/84-d...t-style-5.html |
#105 |
Member#: 150494
SCIC
Vehicle:11 WRX SWP Torqued Stg II |
Just bought a 2011 wrx and have both issues as well. At 30k miles right now. The pedal vibrating is the one that worries me.
#106 |
Member#: 313930
Looking into this problem aswell on my 09
#107 |
Member#: 184772
South East
Vehicle:2004 Crazy Slow WRX World Rally Blue |
I just fixed a buddies 09 WRX, 3 spot welds broke on the bracket. He had just over 60k so warranty was out of the question. We drilled out the oem spot welds and put grade 8 bolts, washers and nuts on to fix it.
We found this out after removing the wiper cowl and having someone press on the clutch pedal. You could see the spot welds moving almost 1/4 inch. |
#108 |
Member#: 221885
NWIC
Vehicle:09 Ivory Tower Ivory...duh |
Since I saw the thread just thought I would update, squealing noise went away about a year an a half ago, nothing since.
#109 |
Member#: 337169
I haven't had this problem on my subie but I heard of this a few times already and it seems to me like previously stated above that it's the spot welds and they should be a cheap and easy fix
#110 |
Member#: 307355
Vehicle:2009 WRX Hatch |
I had the firewall welds repaired under warranty, and had a new clutch installed the same time around 300 miles ago. Today I started feeling vibration in the clutch while getting off of the freeway....needless to say I am frustrated. Has anyone found out the cause of the vibrating clutch pedal? Is it serious? I will go take a drive on my lunch today to see if it has changed. Any info is appreciated.
#111 |
Member#: 307355
Went for a drive and the vibration is gone.....not sure what is up
#112 |
Member#: 219100
Tri-State
Vehicle:'09 WRX Premium 5dr SWP Bilstein'd COBB Stg2+ |
Subscribed. I have a squeaky clutch but no noticeable vibrations. Yes, I would call my clutch pedal stiff. I read they changed that in 2011+.
Might make a call to the dealership and see if they can do some investigating. Last time I tried to make a warranty claim (battery died), they gave me a load of crap for my mods. (I have an extended warranty). |
#113 |
Member#: 261730
MAIC
Vehicle:2011 WRX hatch WRB |
Squeaky-ness and stiffness (imo) have to do with the throw-out bearing. I went in due to squeaks and the head tech said it looked like there was very little lubricant on the bearing. Many people have mentioned this in this thread. Busted firewall welds also contribute
The clutch assembly seems to be finicky and I think it just doesn't allow for sloppy driving. I also experienced pedal vibrations after a hard pull... but I don't get it anymore. A couple people hinted that mistiming clutch release and throttle position can cause this vibration. The easiest first step is to take it into the dealer if you have a constant issue like squeaking. For the vibration issue, I think its mostly in shifting technique. A lot of us new-gen wrx owners are first time wrx drivers so perhaps it takes time to get used to shifting properly. I honestly don't get any of the vibrations in the clutch pedal anymore. |
#114 |
Member#: 280297
I posted in this thread before and just came across it again so I'll post a follow-up.
I'm up to almost ~120k miles on my 08 WRX now. I had the clutch "clicking" sound for the longest time when releasing the clutch pedal. I found it to be associated with the clutch linkage as stated above. It went away eventually. The odd time it came back, I found that kicking the clutch pedal laterally in the direction of the brake and gas pedal made the problem go away. Now that I see it could be popped welds, I'll look into fixing it myself. I also had the vibrating clutch pedal problem intermittently but it hasn't happened in the last 6 months. When it did happen, I only felt it at the top 1 inch of travel. My clutch has always been stiff unlike many of the newer subies I drove. I have not replaced any clutch-related components on the car (mostly because I went through the warranty period in under 2 years). I found it more annoying than anything and I'm glad the problem went away. |
#115 |
Member#: 255232
MWSOC
Vehicle:2011 WRX Sedan SS |
I am getting shaking in the clutch pedal but it seems to only happen when i'm going from a stop into first and even more so when i'm turning while engaging. Anybody else have a similar case? It just started happening a few days ago. It's been very and humid since then. I thought that might have something to do with it.
#116 |
Member#: 301701
SCIC
Vehicle:2012 WRX 5-Door SWP |
I get the shaking in the clutch under hard acceleration and also have to pump it a few times for it to go away. 22k miles on my '12 WRX going to the dealership today to see what the issue is.
| Thread Tools | |
| Display Modes | |
| Clutch pedal vibration | Dave99 | Transmission (AT/MT) & Driveline | 18 | 12-10-2010 12:07 PM |
| Clutch pedal vibration | Cinna696 | Transmission (AT/MT) & Driveline | 0 | 10-27-2008 11:54 PM |
| 06 WRX Clutch Pedal Squeaking | suBooneru | Warranty Issues & SOA Problems | 4 | 02-08-2006 08:56 AM |
| clutch pedal vibration | HS WRB-rex | Transmission (AT/MT) & Driveline | 5 | 12-28-2002 04:49 AM |
| clutch pedal vibration | OMAHA2.5RS | Transmission (AT/MT) & Driveline | 0 | 03-08-2002 03:52 AM |
