Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 11-16-2012, 04:51 PM   #1
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Default Whats up with the timing belt?
Finally getting around to finishing up my unbelievably 3 year long over stretched build and I ran into a problem at the timing belt.
A quick rundown..
ej20k heads
Ej22T block
Stroked out 2.35L
cosworth 272's
.40" Cosmetic HG
So I have the crank on TDC with the belt marks in the right place..
I've got the cams aligned in their correct place..
Why aren't my marks for the cams lining up on the belt?
Would it have anything to do with my belt being for a USDM motor?
Does it matter if the marks aren't aligned if the crank and cams are?
Cbgrandtheftauto is offline   Reply With Quote
Old 11-16-2012, 06:09 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
Line the marks on the pulleys up with the marks on the belt. Nothing else matters.
You have the belt on backwards now.
Old 11-16-2012, 09:12 PM   #3
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
That's what I was thinking after I posted this, but figured it should be the same distance between the marks on each side. I haven't pulled the pin on the tensioner so I'll flip it around tomorrow.
Thanks for confirming I'm an idiot..lol
Old 11-17-2012, 12:37 AM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
yes you have the belt on backwards.
also bear in mind the cam marks will be off ever so slightly before you pull the pin on the tensioner. once you do that everything will settle into place so kinda plan ahead on that.
elislider is offline   Reply With Quote
Old 11-17-2012, 02:36 PM   #5
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Thanks E,
I flipped it over this morning and noticed blue arrows underneath "Subaru". Not sure how I missed them. Everything lined up right on. I did notice the cams moving as I played with the slack so I set them to the right place and once I pulled the pin everything was spot on.
I rotated the motor over to make sure everything was settled in and going to stay spot on, but after rotating the belt all the way around once the cams weren't in line. How many times does the belt have to go around before everything lines back up? or is it a one time deal as to why everything has to be lined up right the first time?
Old 11-17-2012, 02:49 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Originally Posted by Cbgrandtheftauto View Post
Thanks E,
As long as you had the marks on the belt lined up with the marks on the pulleys you have nothing to worry about at all. That's all that matters.
You'd have to spin it 200 and some times for everything to line up again.
Old 11-17-2012, 07:55 PM   #7
elislider
Member#: 133923
03 Legacy GT wagon
yeah the marks on the timing belt are only there for convenience of setting time. once you turn the engine, they are irrelevant, as long as the marks on the crank and cam gears all stay lined up, you're good
also technically you didnt have to turn the belt around. its symmetrical
Old 11-17-2012, 07:59 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Actually he did, the arrows are the direction of rotation. Something about how the belt is internally constructed, the cords are directional or something like that. Yeah it would have run, but why risk it?
Old 11-17-2012, 09:40 PM   #9
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Like a directional tire. If spun the wrong direction problems can and probably will occur.
