Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 03-30-2012, 06:48 PM   #551
Member#: 149806
2006 wrx tr
Cobb sfintake, cobb catless dp, cobb cat back, vf48, walboro 255, stock injectors , 2011 sti tmic
Tuned by chris at efi
19.5 lbs of boost tapering to 15
Wanted to get 300 hp but very happy with this tune wouldnt have it any other way
wrxstage2 is offline   Reply With Quote
Old 04-17-2012, 10:48 AM   #552
Member#: 268388
2005 Legacy Gt
05 legacy Gt Built 2.5, cams, +1 exhaust valves, GT35 .82 Tial hotside, 91 octane and tuned on a Cobb AP with their new speed density rom.
505legacy is offline   Reply With Quote
Old 04-17-2012, 11:18 AM   #553
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Event: Dyno Pull
Ambient Temp: 55F Outside, ~70F Inside
Elevation: ~1,000ft
Weather: Sunny and Cool Outside
Tires: Dunlop Start Spec 255/40R17
Car: 2011 WRX Hatch
Tuner: Nuke @ NF Performance
Dyno Info: Dynojet
Transmission: Stock 5 Speed
Gear: 3rd
Peak HP at RPM: 462 WHP @ 5,850 RPM
Peak Torque at RPM: 492 WTQ @ 4,650 RPM
Baseline hp/tq for a stock on same dyno: ~240WHP Stock
Target Boost: 27psi Peak to ~25psi Redline
Target AFR: High 11's to 12.0
Fuel: E85
Engine/Power Modifications:
  • STI Crank Balanced
  • STI Rods Balanced
  • Coated JE Billet Pistons
  • TGV Deletes
  • Stock Heads
  • Blouch 20G XT-R Turbo
  • Invidia Catless Downpipe
  • Stock Cat Back Exhaust
  • Tial MV-R 44mm EWG
  • KSTech 73mm Intake
  • AMR 3" Hard Inlet
  • GrimmSpeed MBC
  • Walbro 255 Fuel Pump
  • FiveO Motorsports 1200cc Injectors
Driveline Modifications:
  • ACT HD Pressure Plate
  • ACT Sprung 4 Puck Disc
  • ACT Street Light Flywheel
Suspension Modifications: BC Coilovers
Other Modifications: Mach V 17x9" Wheels
More info on the car here:
Here is the plot:
Here are the numbers from all 3 pulls.
  • 468WHP / 498WTQ @ 27.6psi
  • 462WHP / 492WTQ @ 28.0psi
  • 463WHP / 494WTQ @ 27.4psi
Here's the dyno video:
Torque is above 400ft-lb's between 4,000rpm's and 6,000rpm's, and power is above 400hp from 4,400rpm's to redline (7,100rpm's). Boost hits 20psi at 3,750rpm's. Enjoy!
Here's a quick video of me running through the gears.
It takes 4.42seconds to go from 50-100mph according to the video.
Old 05-27-2012, 11:12 AM   #554
Member#: 293121
2008 Legacy Spec.b
2005 wrx. for sale.
Facility: TurboXS
Type of Dyno:
Boost: 15.5
Fuel: 93
Peak HP at RPM: 5453
Peak Torque at RPM: 3870
Mods: built block, manley rods, cp pistons, sti oil pump, gates timing belt, ap head studs, upgraded gaskets, k&n panel filter, cobb access port, megan racing TBE.
05flat4 is offline   Reply With Quote
Old 06-27-2012, 11:57 PM   #555
Member#: 134331
2011 WRX STi
Default 2011 sti dyno
Facility: ESP in Sterling,MA
Type of Dyno: Mustang
Boost: 20.4
Fuel: 93 Sunoco
Target AFR: Cobb Stage 2 OTS
Peak HP at RPM: 293 @ 6100
Peak Torque at RPM: 314 @ 3800
tunertony is offline   Reply With Quote
Old 07-30-2012, 10:23 AM   #556
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
twin scroll 35r 1.06
engine fully built..
278/282 cams
fuel was e85
tuned on cobb speed density
hot as hell... around 100 degrees
the boost falls off because the ewg springs are too soft
shilohb is offline   Reply With Quote
Old 08-13-2012, 08:58 PM   #557
Member#: 196842
02 WRX Wagon
02 WRX Wagon
368awhp/375awtq E85
310awhp/287awtq 91 octane
Blouch TDO5H 16g
Walbro 255lph
820cc witchhunter modded injectors
bigger TMIC
forge motorsports recirculating BOV
mishimoto silicone intercooler hoses
silicone inlet
tgv deletes
AP fuel rails, lines and distribution block
SPT short ram intake
custom air filter cover plate
reinforced transmission mount
reinforced engine mounts
kartboy pitchstop
snorkus chop
oil catch can
cocktail in the transmission
hardened gears or a unicorn in my transmission?
HKS downpipe
HKS hi-power catback
fishawrx is offline   Reply With Quote
Old 08-14-2012, 08:32 PM   #558
Member#: 281793
2004 STi
2006 WRX Ltd
Facility: iAG Performance
Fully built bottom end
bored over & sleeved
99.75 mahle pistons & rods
FHI Updated crank - bearings etc
SPT Short Ram Intake
Perrin Inlet pipe
Godspeed Downpipe (lol i know but it fits perfect and for 99$ how bad can you kUcf up a pipe right ?)
HKS Carbon Ti Catback
: ( stock TD04 stock topmount ... target boost 20.5psi tapering down to 17.5psi
Tuned by Jorge (RiftsWRX) on a Balls hot day with 85% + humidity
217whp 293wtq - going off memory but its damn close - dyno sheet to follow when i get to my work computer.
Last edited by 06rexLTD; 08-14-2012 at 08:40 PM. Reason: posted by accident before done
06rexLTD is offline   Reply With Quote
Old 08-14-2012, 08:57 PM   #559
Member#: 244539
2015 WRX Limited
Ice Silver Metallic
2007 WRX TR
Kinetic Motor Works
Walbro 255
NGK One Step Colder Plugs
VF43 Turbocharger
Invidia Catless Turbo-back exhaust
Perrin Short-Ram intake
Grimmspeed EBCS
93 Octane
295.7whp @ 5450rpm
Stevieb_812 is offline   Reply With Quote
Old 08-30-2012, 12:45 AM   #560
Member#: 330624
2009 WRX Prem Sedan
2009 WRX Premium sedan
Mustang dyno
Front mount intercooler
K&N/short ram intake
Tsudo cat-back exhaust
CNT downpipe
OS tune
92 octane
salemchase is offline   Reply With Quote
Old 09-06-2012, 11:44 PM   #561
Member#: 288372
So-Ofxt is offline   Reply With Quote
Old 09-10-2012, 07:40 PM   #562
Member#: 309842
Rally Blue
2012 WRX Hatch:
Invidia Q300 Catback
AEM Intake
Cobb Access Port
Custom Tune
whp: 304
wtq: 336
synaZaur is offline   Reply With Quote
Old 09-21-2012, 03:14 AM   #563
Member#: 307236
good numbers
Ray_21 is offline   Reply With Quote
Old 09-21-2012, 12:07 PM   #564
Member#: 271720
Default vf34 02 Wagon 331whp/320wtq
Oh why not, here's mine
Car: 2002 WRX Wagon
Tuner: STi Mikey
Transmission: one unhappy 122K mile 5 sp
Gear: 3rd
Peak HP at RPM: 331.6whp @ ~6k
Peak Torque at RPM: 320ish wtq @ ~4.8k
Target Boost: 21psi
Target AFR: I forgot to ask Mikey
Fuel: 93
Phase 1 EJ22 NA block
stock EJ22 Crank
MPS 4340 H beam long rods +2mm
Custom JE Pistons 97mm (basically standard dish made for the rods)
Small port V7 heads, (deshrouded for the EJ22 bore, valve job, etc)
Kelford V2-199B's (264's)
V7 Ecu running AVCS
FMS TMIC (meh, I ran out of $$)
Borla UEQ header with a few extra welds
bosal up and down pipes that I bought 9yrs ago (the rest is still stock)
Fuel pump, TGV's deletes, stock intake, silicone inlet, blah, blah, etc. etc.
biodude is offline   Reply With Quote
Old 10-15-2012, 11:00 PM   #565
Member#: 274708
05 Saab 9-2x
Long-time lurker, first time poster.
Spun a bearing on the stock setup. This is the first tune after a rebuilt shortblock and other mods.
Car: 2005 Saab 9-2x Aero
Tuner: Ron RS Motors
Gear: 3rd (I believe)
Peak HP at RPM: 237whp @ ~5.7K
Peak Torque at RPM: 234 wtq @ ~4.4k
Boost: 17psi
AFR: 13.5
Fuel: 91
Stock 2.0L Longblock
FP Big 16G Evo
Grimmspeed Catless Uppipe
2.5" Catless downpipe into stock exhaust
~850cc Injectors
Walbro fuel pump
Sorry about using the iphone scanner, will update tomorrow after using the color scanner at work.
TJ914 is offline   Reply With Quote
Old 10-17-2012, 10:12 PM   #566
Member#: 322736
1996 legacy (sti)
Blaster2900 is offline   Reply With Quote
Old 11-04-2012, 04:32 PM   #567
Member#: 169443
2008 WRX with VF-52
I had a VF52 installed and tuned in my 2008 WRX made 314whp and 337wtq on CDN 91oct (I normally run US 92 but I wanted to be tuned on the worst gas available)
Here is a video from one of the earlier runs when she was backfiring under boost due to a slight boost leak
Engine modifications:
COBB Tuning AccessPORT V2
Invidia Q300 Cat Back Exhaust
PERRIN Catted Downpipe
PERRIN turbo inlet
Process West Top Mount Intercooler
Studebaker83 is offline   Reply With Quote
Old 11-07-2012, 06:07 PM   #568
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Might as well add mine to the list.
2002 bugeye wagon.
Oem rebuilt 2.5 legacy gt block
Oem 2.0 heads (all stock)
Blouch 20gxt 8cm2^ 2.4 inlet
DW 750 injectors.
TGV deletes. DIY
gt spec header and up pipe. 3 bolt
Catless bell mouth downpipe
Modified full 3 inch spt cat back
APS DR725 black FMIC
PERRIN inlet
Dual Peterson fluid systems catch cans.
Walboro 255
Ngk 1 step colder copper plugs
I am sure there are some other things I forgot.
Oh and it has a USDM 2007 sti six speed swap with the original wrx r160
Tuned by Dan @ Mach v motorsports.
Dyno jet dyno.
93 octane
367 whp
355 wtq
mrjcotten is offline   Reply With Quote
Old 11-15-2012, 08:01 PM   #569
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Who: my car and I
What: protune
Where: Kaizen Tuning, Boxborough, MA
When: Today
Why: get tuned???
i'm not even going to pretend i know everything. but i'm pretty happy with this for Stage 2.
eta: had a leak at the BPV and the inlet. was not surprised because i took that IC on/off at least 6 times messing with this car. so it's cool. after that, the smoke test was good.
MODS: Cobb SF intake + Box, Cobb Catted Downpipe.
it's a long story. see this: http://forums.nasioc.com/forums/show....php?t=2409331
ChesterWRX is offline   Reply With Quote
Old 11-16-2012, 03:02 PM   #570
Member#: 107170
2002 ver 7 EJ207 WRX
Default 02 WRX Ver 7 EJ207
Here is mine:
Event: Protune
Ambient Temp: 65C
Elevation: 10-20 feet above sea level
Weather: cloudy, cool
Car: 2002 WRX
Tuner: Ed
Transmission: Stock 5spd
Gear: 3rd/4th?
Peak HP at RPM: 272.1 HP @ 6400
Peak Torque at RPM: 245.0 ft-lbs @ 5100
Target Boost: Conservative 17 psi
Target AFR: ?
Fuel: 91 Unleaded Chevron
V7 EJ207 Stock VF30
JDM scoop and splitter
One Step colder NGK
Stock Pink injectors
K&N Drop In filter
Walboro 255 fuel pump
Invidia catless DP
Helix uppipe
Cobb catback exhaust
KoyoRad radiator
AVCS wired up, but there is short somewhere as the signal was erratic according to the tuner, advance only up to 5 only
I will be purchasing a Tactrix cable to do some datalogging while I troubleshoot the source of my AVCS woes. Plans in the future:
This is my daily driver and I would like to crack the 300WHP barrier:
Swap out the VF30 with the hairline wasteline crack
Turbo Inlet
Cobb Catted DP (gotta think the environment and my kids' health)
Intake + aft MAF hose
efiniluvr is offline   Reply With Quote
Old 11-17-2012, 11:40 PM   #571
Member#: 338184
Default 2012 Wrx
2012 WRX 318 AWHP/350 AWTQ
Process West TMIC
Invidia Catted Downpipe
Invidia Q300
Forge recirc valve
DW65C fuel pump
Custom Dyno tune
KartBoy Short Throw Shifter
blu-blz is offline   Reply With Quote
Old 12-17-2012, 11:49 PM   #572
Member#: 187304
Originally Posted by Gabriel~ View Post
Facility:Cobb Tuning Plano
Boost: 19.9
Fuel: 93 octane
Peak HP at RPM: 346 @ 5850
Peak Torque at RPM: 354 @ 4250
Mods: COBB Tuning AccessPORT, MXP TBE, AEM CAI, Grimmspeed up-pipe with Tial 38mm EWG, Perrin EBCS, Perrin FMIC, Perrin Turbo Inlet, walboro 255, 850 cc deatschwerks injectors, Blouch 20g-xt 10cm
Dyno sheet up in a few minutes. Very happy with this turbo, headers in the future and TGV deletes will be done soon.
This is not a 10cm , who installed this you or a shop?
REDCHARGE is offline   Reply With Quote
Old 12-18-2012, 08:17 PM   #573
Member#: 249852
1998 2.5rs
blue ridge pearl
Default rs
98 rs coupe
Originally did a 05 wrx swap then spun 3 out out of the 4 cyl rod bearings. Then came the good part!
2011 sti short block
99.5 Mahle pistons 8.5:1
2.0l heads machined to match chambers and compression
arp head studs
272/272 crower cams
titanium valve spring retainers and springs
11mm oil pump
killer b oil pick up
gms intake spacers
spt short ram air intake
gms manual boost controller
08 wrx 565cc injectors
walboro fuel pump
light weight crank pulley
ebay tmic
DC sports header and up pipe
buschur down pipe
was a megan cat back but changed the axle back to a spt bosal
The dyno chart is my base pull at 11psi. I'm now at 19psi. I do not have a second pull chart because my rear diff stopped cooperating. I have the oe rs 5spd trans with a stage 3 clutch masters clutch. Thats the next thing that will go in, a six speed swap. I currently have to replace the rear diff since I think its completely gone. just have to find the time to do it. My tuner loved it because it absolutely had no lag and the cams held the power all the way to the end of the rpm band.
perez8608 is offline   Reply With Quote
Old 12-18-2012, 11:48 PM   #574
Member#: 331899
John Shafer tuned
2012 wrx base sedan
Facility: Akuma Motorsports
Boost: 19.1 psi
Fuel: 93 pump
Peak HP at RPM: 302 @6000
Peak Torque at RPM: 338 @4200
Mods: Invidia catless TBE, Process West TMIC, AEM CAI, DW65c fuel pump, FIC 900cc fuel injectors
robsuerto is offline   Reply With Quote
Old 12-20-2012, 07:56 AM   #575
Member#: 294709
2005 wrx sti
obsedian black pearl
Going on dyno in 2 hrs!!!!! Post as soon as sheet is available
mmbaylis is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
