Old 10-23-2012, 12:37 PM   #26
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by Commander Keen
Post above edited. I guess I can't embed these.
Thanks. That's looks a little too close to me. The new block heater loss like it is more than a plug change, the whole thing looks smaller externally.
Old 10-29-2012, 01:15 PM   #27
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
did you replace the exhaust gaskets?
Old 10-29-2012, 02:36 PM   #28
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
No, they fell right off.
Commander Keen is online now   Reply With Quote
Old 10-29-2012, 04:50 PM   #29
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
but you didn't replace the gaskets when you put it back together? i ordered all 3 just in case, pretty cheap, 20.00 overall for all 3.
Old 10-29-2012, 07:55 PM   #30
Commander Keen
Member#: 319157
I put the same ones back. No problems.
Old 10-29-2012, 10:22 PM   #31
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
well i have them coming with the block heater, won't hurt to change them for peace of mind. 137.00 today for the new style heater, all 3 gaskets, and 5 oil filters, not too bad i guess. gotta love 20% off at subaru parts warehouse.
Old 11-16-2012, 11:53 AM   #32
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
One last question, were you able to remove the header by itself, or did you have to remove the center pipe as the instructions dictate?
Old 11-16-2012, 01:12 PM   #33
Commander Keen
Member#: 319157
I didn't remove the center pipe. I just removed the three nuts on each manifold securing them to the heads.
Old 11-16-2012, 01:28 PM   #34
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
thanks, that does seem much easier, i will be doing this tomorrow morning.
Old 11-17-2012, 09:07 PM   #35
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i did this today. ended up removing the exhaust as the instructions say just because i didn't want to deal with coolant all over the exhaust and it made it easier to tighten up the heater. I did use the new style heater because it has better heat shielding and is much further from the exhaust. I forgot to take a pic of the clearance but it is close to 2" of clearance
and this is where i routed my cord too because I have a timer i use at work and it is easier to leave it under the hood.
Old 11-17-2012, 09:59 PM   #36
Commander Keen
Member#: 319157
Nice install. I have my cable zip tied to the lower grille a few inches behind the plug. When I'm done with it, I just toss it behind the grille and it disappears.
I'm thinking about a hood liner for acoustic and thermal reasons. A lot of heat leaks out through the hood, and now that it's colder, I notice the engine sometimes has trouble maintaining 195F.
Old 11-17-2012, 11:09 PM   #37
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'd be interested in a liner, where will you get one?
Old 11-18-2012, 12:27 AM   #38
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
You can use sound deadener like FatMat or Dynamat to do that, I would assume.
Old 11-18-2012, 12:34 AM   #39
Commander Keen
Member#: 319157
Dynamat is good at deadening vibration, but not so much at absorbing sound. I'll have to do some research, but most likely it will be something thick, good at pulling noise out of the air and a good insulator.
The CVTs have an under-hood liner from the factory, but I'm sure there are better after market products.
Old 11-18-2012, 12:46 AM   #40
pkL
Member#: 313093
2012 Impreza 2.0i
Does the 5MT have the under-hood liner as well, just kind of curious even though I have the CVT? I bought some Rattle Trap and was looking to deaden my doors, hatch, and underneath the hood.
Old 11-18-2012, 01:28 AM   #41
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Nope, just bare metal
Old 11-18-2012, 02:38 AM   #42
pkL
Member#: 313093
2012 Impreza 2.0i
Oh I didn't know that, maybe the CVT has it to mask the whining noise it makes.
Old 11-18-2012, 09:41 AM   #43
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Probably, usually that liner is for sound deadening and not heat retention
Old 11-21-2012, 01:58 AM   #44
pkL
Member#: 313093
2012 Impreza 2.0i
Well the engine bay gets plenty warm on its own, so any sort of additional insulation would cause the car to bog down.
Old 11-21-2012, 06:47 AM   #45
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I don't agree with that. There is enough airflow that it shouldn't. Really only at idle and not moving would you see temps rise a few degrees. It's not a performance car so I don't think you would notice the difference
Old 11-24-2012, 11:40 PM   #46
pkL
Member#: 313093
2012 Impreza 2.0i
I meant when your car remains stationary idling in traffic, which is the same thing as what you said.
Old 11-25-2012, 11:46 AM   #47
Commander Keen
Member#: 319157
The radiator is very capable of keeping the engine cool enough.
Insulating the engine bay won't change the thermostat opening temperature.
Old 11-25-2012, 02:32 PM   #48
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
No, but it would change the air intake temp. Not a real big deal in our cars though
Old 11-25-2012, 02:47 PM   #49
Commander Keen
Member#: 319157
It's a very short intake that draws directly from the grille.
I don't think the difference would be significant. Warm air tends to improve economy a bit anyway.
In any case, It's not a difficult thing to monitor.
Old 11-25-2012, 10:57 PM   #50
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
My Buick has an intake of similar length that draws air from the fender wall. In traffic the temps rise about 20F, which is pretty significant
FS: WRX short block, heads, oil pan, and intake manifold mikebdubsuby SCIC Private Classifieds 29 12-10-2009 12:22 PM
EJ20 block, heads, oil pan, intake mani, and coil packs mikebdubsuby Engine/Power/Exhaust 39 12-10-2009 12:21 PM
06 wrx. oil leaking from block above oil pan. seventhsign Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-24-2009 05:19 PM
Wanted EJ257 block and oil pan. ihadmail Private 'Wanted' Classifieds 0 05-06-2008 10:16 PM
