#26 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
#27 |
Member#: 314216
did you replace the exhaust gaskets?
#28 |
Member#: 319157
MAIC
Vehicle:2012 Impreza 4DR 5MT |
No, they fell right off.
#29 |
Member#: 314216
but you didn't replace the gaskets when you put it back together? i ordered all 3 just in case, pretty cheap, 20.00 overall for all 3.
#30 |
Member#: 319157
MAIC
I put the same ones back. No problems.
#31 |
Member#: 314216
well i have them coming with the block heater, won't hurt to change them for peace of mind. 137.00 today for the new style heater, all 3 gaskets, and 5 oil filters, not too bad i guess. gotta love 20% off at subaru parts warehouse.
#32 |
Member#: 314216
One last question, were you able to remove the header by itself, or did you have to remove the center pipe as the instructions dictate?
#33 |
Member#: 319157
MAIC
I didn't remove the center pipe. I just removed the three nuts on each manifold securing them to the heads.
#34 |
Member#: 314216
#35 |
Member#: 314216
i did this today. ended up removing the exhaust as the instructions say just because i didn't want to deal with coolant all over the exhaust and it made it easier to tighten up the heater. I did use the new style heater because it has better heat shielding and is much further from the exhaust. I forgot to take a pic of the clearance but it is close to 2" of clearance
![]() and this is where i routed my cord too because I have a timer i use at work and it is easier to leave it under the hood. ![]() |
#36 |
Member#: 319157
MAIC
Nice install. I have my cable zip tied to the lower grille a few inches behind the plug. When I'm done with it, I just toss it behind the grille and it disappears.
I'm thinking about a hood liner for acoustic and thermal reasons. A lot of heat leaks out through the hood, and now that it's colder, I notice the engine sometimes has trouble maintaining 195F. |
#37 | |
Member#: 314216
#38 | |
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
#39 |
Member#: 319157
MAIC
Dynamat is good at deadening vibration, but not so much at absorbing sound. I'll have to do some research, but most likely it will be something thick, good at pulling noise out of the air and a good insulator.
The CVTs have an under-hood liner from the factory, but I'm sure there are better after market products. |
#40 | |
Member#: 313093
VIC
#41 | |
Member#: 314216
#42 |
Member#: 313093
VIC
#43 | |
Member#: 314216
#44 |
Member#: 313093
VIC
#45 | |
Member#: 314216
#46 |
Member#: 313093
VIC
I meant when your car remains stationary idling in traffic, which is the same thing as what you said.
#47 |
Member#: 319157
MAIC
The radiator is very capable of keeping the engine cool enough.
Insulating the engine bay won't change the thermostat opening temperature. |
#48 | |
Member#: 314216
#49 | |
Member#: 319157
MAIC
I don't think the difference would be significant. Warm air tends to improve economy a bit anyway. In any case, It's not a difficult thing to monitor. |
#50 | |
Member#: 314216
| Thread Tools | |
| Display Modes | |
| FS: WRX short block, heads, oil pan, and intake manifold | mikebdubsuby | SCIC Private Classifieds | 29 | 12-10-2009 12:22 PM |
| EJ20 block, heads, oil pan, intake mani, and coil packs | mikebdubsuby | Engine/Power/Exhaust | 39 | 12-10-2009 12:21 PM |
| 06 wrx. oil leaking from block above oil pan. | seventhsign | Factory 2.5L Turbo Powertrain | 2 | 07-24-2009 05:19 PM |
| Wanted EJ257 block and oil pan. | ihadmail | Private 'Wanted' Classifieds | 0 | 05-06-2008 10:16 PM |
