#1 |
Member#: 309974
Guys i have 07 impreza and unfortunately it didnt come with a rear sway bar ( yes it didnt) in my country . so i was asking if i could fit one . I know that i will need endlinks, bushings and brackets any thing else ?
But my question is would i be able to fit it because when i had a look under the car i didnt find that piece that the endlink should be attached to . I know u might not understand me put i'll take a picture to show what iam talking about
#2 |
Member#: 309974
#3 |
Member#: 142029
Tri-State
Vehicle:2013 Fozz 2004 STi, 1991 Miata BRG |
I don't see mounting points for the endlinks on the control arms. My guess is that you could swap in WRX or USDM Impreza control arms that have the endlink mounting points. I'd research that first.
The other question is do you have the threaded holes for the sway bar mount brackets? |
#4 | |
Member#: 289846
Vehicle:2002 Wrx Blue |
For the rear, the endlinks mount on the rear Lateral Arm, so buy some usdm rear lateral arms, or weld on some brackets. Also make sure you do have the threaded 8x1.25 holes for the mounting brackets as stated above. |
#5 |
Member#: 309974
Thxx guyss . Do u think it would be a good idea to weld it or should i buy 2 new lateral links ?
I'll make sure that i have holes for the upper bracket but if i didnt is there also a solution flr that ? |
#6 |
Member#: 309974
Also is there any way i could fit it without changing the lateral arms
#7 |
Member#: 309974
Any help ?
#8 | ||
Member#: 97135
NWIC
there is absolutely no need to bump a thread every hour. it takes time to get responses. |
