Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 11-18-2012, 02:07 AM   #1
CommonJoe
Member#: 281408
2007 Impreza WRX STi
Gray
Unhappy Update: Pictures added - Poured Synthetic diesel oil in my 2007 WRX STi - Stock
Subject : Subaru Wrx STi 2007 Stock 45,xxx miles
Made a stupid mistake and panicking about what I did.
I was such in rush that i bought 2 big jugs of Shell Rotella T6 5w40 Full synthetic for Diesel engines.
Poured 4.7 quarts of Shell Rotella T6 5w40 Full synthetic for diesel engines and have been driving for 200 miles so far. Have I caused any major damage to my turbo or engine? So far my mpg has decreased down to 15mpg.
I meant to buy Rotella T6 5W40 Synthetic for Gasoline Engines but i didn't take the time to read everything properly.
This is my plan, change my oil with the correct oil, change it again in 100 miles and replace it again in 200 miles.
What is the difference between regular Gasoline motor oil and diesel motor oil?
Thanks everyone.
CommonJoe is offline   Reply With Quote
Old 11-18-2012, 02:11 AM   #2
SplatWRX
Member#: 85932
2005 STi / 2013 STi
2005 Forester XTi
You are fine. As long as the oil holds the spec that your vehicle requires, you are golden.
The T6 is a commonly used oil by a lot of people in both gas and diesel applications.
SplatWRX is offline   Reply With Quote
Old 11-18-2012, 02:14 AM   #3
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Don't quote me but I think your ok. I think you bought the right one. Wait for someone else to chim in though. I could be giving you false news.
OC_Nooby is offline   Reply With Quote
Old 11-18-2012, 02:36 AM   #4
LastResort
Member#: 99289
Marketing. If the specs match the application (IE, meets Subaru's requirements) , you're good to go.
LastResort is offline   Reply With Quote
Old 11-18-2012, 03:02 AM   #5
esteve
Member#: 28716
2006 STI
So you bought the older Rotella T 5W-40 that also came in a blue jug? If so, don't worry about it...I read on BITOG that the new T6 formulation is still very similar but with some slight additive variation. If anything, most of the change was marketing (new look and name).
I wouldn't change it out early, that'd be a waste of perfectly good oil. Lots of us were using that first anyway because of how good it is. I'm still running it because I have a small stash of it and want to use that up first.
esteve is online now   Reply With Quote
Old 11-18-2012, 03:17 AM   #6
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
There is only 1 Shell Rotella T6, so you got the right one. Yes its a diesel oil but it works very well in turbo Subarus. As the others stated it meets the requirements for a gasoline engine.
181stLeader is online now   Reply With Quote
Old 11-18-2012, 03:43 AM   #7
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
yergunnaDIE-DIE-DIEahorribledeathfromtoomanyeelsinyourhovercraft
oh the humanity......think of all the humanity....
Old 11-18-2012, 05:07 AM   #8
SubieGsR
Member#: 84401
2007 Sti Limited
Urban Gray Metallic
This. I've been running this oil for almost two years now with no problems.
SubieGsR is offline   Reply With Quote
Old 11-18-2012, 09:45 AM   #9
some dude
Member#: 100300
06 WRX
CGM
Yeah, it says diesel on it but that is the oil you want. Don't let the diesel wording fool you. You car should love this stuff. Only 1 kind. There is no gasoline version.
some dude is offline   Reply With Quote
Old 11-18-2012, 09:49 AM   #10
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
^This, this, and this. There's only one T6. You're fine.
Old 11-18-2012, 11:37 AM   #11
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
wow, that is a story! lol. seriously, op take a break and relax. do some searching about t6. you wil see alot of subaru owners use t6. its a great oil and is backed up by testing to boot. i use it myself. 50k miles to date and ive never been to the dealer for anything but a broken sunvisor!
Old 11-18-2012, 12:18 PM   #12
Subiezilla
Member#: 280543
Ding Ding Ding +1
Subiezilla is offline   Reply With Quote
Old 11-18-2012, 12:31 PM   #13
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Don't do what now?
Old 11-18-2012, 12:49 PM   #14
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
To those that said there's only 1 T6 oil, you're wrong. There's the 5/40 and the 15/40...yeah, I accidentally ran 15/40 for a bit...and I have a busted motor, but I don't know how much that contributed, if at all.
Old 11-18-2012, 01:08 PM   #15
Kevwa451
Member#: 314408
2011 WRX Stage 2
You'll be fine, stuff holds up just fine to 14000rpms in my CBR while also being ran through the transmission gears and the 8 clutch plates. I use it in my WRX as well, it came out looking much better than the dealership oil I replaced it with. I know visual appearance doesn't mean much but it makes me feel better.
Kevwa451 is offline   Reply With Quote
Old 11-18-2012, 01:53 PM   #16
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I've been running T6 for a few years now.. great oil..
Old 11-18-2012, 02:42 PM   #17
bluesubie
Member#: 767
04 FXT
No you're wrong. The 15W-40 is Rotella T not T6.
Rotella T
http://www-static.shell.com/static/c...protection.pdf
Rotella T6
http://www.epc.shell.com/Docs/GPCDOC...US)_TDS_v1.pdf
-Dennis
Old 11-18-2012, 02:54 PM   #18
CommonJoe
Member#: 281408
Gray
Angry
Here is some evidence.
Oil I used from Walmart, Minneapolis, Minnesota
$21.99/Jug
Oil I bought from Pepboys
$29.99/Jug
Old 11-18-2012, 03:11 PM   #19
esteve
Member#: 28716
2006 STI
That's interesting, it looks like they either mislabeled some jugs or are tweaking the marketing slightly by adding "diesel." Either way, it's the same oil with the same ratings so don't worry about it.
Old 11-18-2012, 04:20 PM   #20
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Rotella T
Rotella T6
-Dennis
Exsqueeze me??
I'm "wrong" about what???
I know what's in my car, and I know what the OP put in HIS car, what I DON'T know is WTF you are talking about and why you are saying it to ME...
Thanks everyone.
Old 11-18-2012, 04:24 PM   #21
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
$21.99/Jug
$29.99/Jug
OMG it's going to EXPLODE...!!
Old 11-18-2012, 04:27 PM   #22
LastResort
Member#: 99289
Originally Posted by Aaron'z 2.5RS View Post
Exsqueeze me??
Breath dude. He was responding to drewvdw, who claimed that there 15W40 type of Rotella T6.
Old 11-18-2012, 05:39 PM   #23
bluesubie
Member#: 767
04 FXT
$21.99/Jug
$29.99/Jug
It's a mixed fleet gasoline/diesel oil.
Specifications, Approvals & Recommendations
· API: CJ-4, CI-4 PLUS, CI-4, CH-4, CG-4, CF-4, CF ·API: SM, SL, SJ, SH
API "C" specifications are for diesels and "S" specifications are for gasoline engine. Check your owner's manual. It will say API SM.
-Dennis
Old 11-18-2012, 06:27 PM   #24
bluesubie
Member#: 767
04 FXT
Thank you. Apparently there was a reading fail by Aaron.
-Dennis
Old 11-18-2012, 08:17 PM   #25
Uncle Scotty
OK buy Nates beans
$21.99/Jug
$29.99/Jug
sweetie...;pull the tampon and take a midol and it will be ok in a couple days
THERE IS NO POSSIBLE ISSUE WITH USING EITHER OF THE OILS YOU HAVE PICTURED ABOVE
jesus h ****ing christ these kids are getting dumber and dumber every ****ing DAY, here
