Old 11-16-2012, 03:15 AM   #1
FireBlazed
Member#: 326599
2004 WRX STI
Default Fp green 3 inch install questions
Okay, I'm positive that this has been asked atleast once but ove gone through so many forums and couldn't find a straight answer...there is no clearance inlets gets blocked by manifold...my tuner says its not possible but idk...how have people gotten passed this impossible fitment
FireBlazed is offline   Reply With Quote
Old 11-16-2012, 11:22 AM   #2
OC_Nooby
Member#: 311781
2003 WRX w STI V8
My ATP GT3076R with a 3" inlet was a pain. Had to modify the uppipe so the inlet aligned properly with the turbo. Also you will have to remove the TGV motors.
Shove the 3" turbo inlet in. Se where the turbo sits and adjust. It's not fun. If you haven't done this. Just go rotated.
OC_Nooby is offline   Reply With Quote
Old 11-16-2012, 11:33 AM   #3
FireBlazed
Member#: 326599
2004 WRX STI
They're removed but idk if I can get this installed or if I need to go rotated...my tuners seem to be lost bc they Say its Impossible
Old 11-16-2012, 11:33 AM   #4
FireBlazed
Member#: 326599
2004 WRX STI
Inlet will b dimpled correct?
Old 11-16-2012, 12:45 PM   #5
OC_Nooby
Member#: 311781
2003 WRX w STI V8
My AMR inlet was dimpled for the power steering if that's what you mean? I think the problem lies with the header/uppipe. That's the only variable that can change between setups. That's why you see some people saying there turbo inlet fit perfectly and others say its impossible. No way could I have gotten the turbo inlet on and secured without modifying the uppipe (moved turbo half an inch towards the driver side).
As long as they look at it in a way that they will have to modify things it will work. If they look at the product and say it should fit but doesn't it will never fit. It might be pricey to make it fit though. Hence rotated. Do the math, see where it gets you.
Usually stock location turbo's sale for more then a rotated turbo, even if its a worse performer. Its the convenience factor.
Old 11-16-2012, 01:09 PM   #6
FireBlazed
Member#: 326599
2004 WRX STI
A better question then is what header and uppipe seem to be no problem with 3 inch green? I have a new agency power headers and invidia up, maybe some feedback as to what headers and up will work? I'm trying to figure how much going rotated is gonna cost and I'm really not liking that lol
Old 11-18-2012, 05:36 AM   #7
fr0st_wrx
Member#: 126717
2006 WRX
Did you try loosening up the header/up bolts and turbo brackets so it could have a little movement to it? and maybe try removing the power steering pump/dropping the alternator to have a little more movement on the inlet side.
fr0st_wrx is offline   Reply With Quote
